rebuilding 727 need some input on my parts list #352595
06/20/09 12:45 PM
06/20/09 12:45 PM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
turbo action 17680 forward pattern valve body
coan 42801 billit super sprag
full metal jacket drum mrek123900as steel sleeved aluminum drum.
Which rebuild kit?
turbo action tranz box 17395f-1
mancini race mre014
b&m 10229
Street Strip small block
Re: rebuilding 727 need some input on my parts list [Re: skep419] #352596
06/20/09 01:25 PM
06/20/09 01:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: rebuilding 727 need some input on my parts list [Re: 70AARcuda] #352597
06/20/09 01:45 PM
06/20/09 01:45 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Re: rebuilding 727 need some input on my parts list [Re: skep419] #352598
06/20/09 02:05 PM
06/20/09 02:05 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A standard rebuild kit with Borg Warner or Rabestos tan clutchs will work fine. I like solid bands with Kevlar. The stock low roller clutch is fine. Check the inner race,rollers and springs. Replace as nec. Make sure you have a 4 plate high drum. If you have a late model servo (5/8" pin) take it apart and install a couple of input/output thrust washers as spacers to make it solid. Grind the feed hole in the stator support for additional oil flow (see the CRT website for instuctions). Use a 3.8 or 4.2 lever and you'll be good to go. If you like the saftey factor of the aftermaket drum ,go for it. I buy all of these parts (including gaskets,rings,seals,filter) at my local trans wholesale house for less than $100 not including the drum.
Doug
Re: rebuilding 727 need some input on my parts list [Re: dvw] #352599
06/20/09 04:27 PM
06/20/09 04:27 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Call A and A trans. Tell them what you have, and they will recommend the best stuff for you.
They are board sponsors.
I bought my stuff there, aftetr I came within 1 roller of a sprague explosion. Great service and advice.
Is that turbo action VB a LBA?
Re: rebuilding 727 need some input on my parts list [Re: dvw] #352600
06/21/09 11:33 AM
06/21/09 11:33 AM
NC
440Jim Offline
440Jim  Offline
NC
Pic with spacer. The older style solid servo (smaller pin) is nicer because it has two springs, but this is a cheap improvement.
Re: rebuilding 727 need some input on my parts list [Re: 440Jim] #352601
06/21/09 02:46 PM
06/21/09 02:46 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Billitt front drum and 5 pinion steel
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: rebuilding 727 need some input on my parts list [Re: 440Jim] #352602
07/07/09 06:40 PM
07/07/09 06:40 PM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
I talked with turbo action today and I'm planning on using there full manual valve body with lba. He said I should buy the better servo and use a 5.0 lever. How much better is the servo over the washer improved unit.
Re: rebuilding 727 need some input on my parts list [Re: skep419] #352603
07/07/09 06:43 PM
07/07/09 06:43 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
the solid billet servos are a much better piece but I prefer the 4.2 lever over the 5.0
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: rebuilding 727 need some input on my parts list [Re: dusturbd340W5] #352604
07/08/09 09:48 AM
07/08/09 09:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
check with member mr.randyj he has the servos you want , great price and good guy to deal with , get both the front and the rear , and don't use a 5.0 lever .
Re: rebuilding 727 need some input on my parts list [Re: JohnRR] #352605
07/08/09 11:41 AM
07/08/09 11:41 AM
sweden
street_dart Offline
street_dart  Offline
sweden
I am also re building my 727. Why should I not use a 5.0 kickdown lever?
Dodge Dart-67 Dodge Custom Royal Lancer-55 Dodge Dakota 4.7 -05
Re: rebuilding 727 need some input on my parts list [Re: street_dart] #352606
07/08/09 12:07 PM
07/08/09 12:07 PM
Kissimmee Fl.
Kissimmee Fl.
to much problems with shift overlap
Re: rebuilding 727 need some input on my parts list [Re: street_dart] #352607
07/08/09 12:13 PM
07/08/09 12:13 PM
NC
440Jim Offline
440Jim  Offline
NC
The 5.0 level does give more holding power in 2nd gear. However, with increased line pressure of a manual valve body, there is no need for it, the pressure does the job. The 5.0 lever will be slower releasing during the 2-3 shift and can contribute to shift overlap (binding). For a 727, especially with a manual valve body, I prefer the 3.8 or 4.2 lever.
Re: rebuilding 727 need some input on my parts list [Re: 440Jim] #352608
07/08/09 01:08 PM
07/08/09 01:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Small Hijack
Great thread, I am also rebuilding a 727 for My Hemi project.
So let me add to this thread, what are the feelings of a factory 3 pinion planet, Vs a HD factory 4 pinion planet?
I was told by HP trans builder specializing in 727 that he was building 727 with these planets and kept breaking them. He went back to 3 pinion and the problem went away. This was due to triangulation etc. And if upgrading go with the 5 pinion, or stay with the three...
I would love to hear 440Jim's thoughts on this..
Re: rebuilding 727 need some input on my parts list [Re: Bob_Coomer] #352609
07/08/09 02:53 PM
07/08/09 02:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'd be interested to know where they were "breaking".
If one wanted to use the triangulation argument, then the more pinions the better the lateral stability.
Re: rebuilding 727 need some input on my parts list [Re: John_Kunkel] #352610
07/09/09 09:46 AM
07/09/09 09:46 AM
Oregon,USA
RAT PATROL Offline
RAT PATROL  Offline
Oregon,USA
"The Black Mistress" runs four pinion planetaries, they've held up fine. Driver is the weak link in my running gear.
Re: rebuilding 727 need some input on my parts list [Re: dave571] #352611
07/10/09 01:47 PM
07/10/09 01:47 PM
Minnesota
skep419 Offline OP
skep419  Offline OP
Minnesota
The part number I have listed (17680) does not have LBA. The 17675 does. Turbo action said the 17680 will go a tenth faster in the quarter but for street use not a good idea.
