Re: rebuilding 727 need some input on my parts list
[Re: dvw]
#352599
06/20/09 04:27 PM
06/20/09 04:27 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Call A and A trans. Tell them what you have, and they will recommend the best stuff for you. They are board sponsors. I bought my stuff there, aftetr I came within 1 roller of a sprague explosion. Great service and advice. Is that turbo action VB a LBA?
[Re: dvw]
#352600
06/21/09 11:33 AM
06/21/09 11:33 AM
Posts: 16,925 NC
440Jim
NC
If you have a late model servo (5/8" pin) take it apart and install a couple of input/output thrust washers as spacers to make it solid.
Pic with spacer. The older style solid servo (smaller pin) is nicer because it has two springs, but this is a cheap improvement.
[Re: 440Jim]
#352602
07/07/09 06:40 PM
07/07/09 06:40 PM
Posts: 782 Minnesota
skep419
Minnesota
I talked with turbo action today and I'm planning on using there full manual valve body with lba. He said I should buy the better servo and use a 5.0 lever. How much better is the servo over the washer improved unit.
[Re: skep419]
#352603
07/07/09 06:43 PM
07/07/09 06:43 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
the solid billet servos are a much better piece but I prefer the 4.2 lever over the 5.0
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#352604
07/08/09 09:48 AM
07/08/09 09:48 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
check with member mr.randyj he has the servos you want , great price and good guy to deal with , get both the front and the rear , and don't use a 5.0 lever .
[Re: JohnRR]
#352605
07/08/09 11:41 AM
07/08/09 11:41 AM
Posts: 140 sweden
street_dart
sweden
I am also re building my 727. Why should I not use a 5.0 kickdown lever?
Dodge Dart-67
Dodge Custom Royal Lancer-55
Dodge Dakota 4.7 -05
[Re: street_dart]
#352606
07/08/09 12:07 PM
07/08/09 12:07 PM
dusturbd340W5
Kissimmee Fl.
to much problems with shift overlap
[Re: 440Jim]
#352608
07/08/09 01:08 PM
07/08/09 01:08 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Small Hijack Great thread, I am also rebuilding a 727 for My Hemi project. So let me add to this thread, what are the feelings of a factory 3 pinion planet, Vs a HD factory 4 pinion planet? I was told by HP trans builder specializing in 727 that he was building 727 with these planets and kept breaking them. He went back to 3 pinion and the problem went away. This was due to triangulation etc. And if upgrading go with the 5 pinion, or stay with the three... I would love to hear 440Jim's thoughts on this..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: dave571]
#352611
07/10/09 01:47 PM
07/10/09 01:47 PM
skep419
Minnesota
The part number I have listed (17680) does not have LBA. The 17675 does. Turbo action said the 17680 will go a tenth faster in the quarter but for street use not a good idea.
