msd ignition
#351365
06/18/09 10:50 PM
06/18/09 10:50 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i am putting a msd blaster box on my 68 coronet, i am putting under the dash , i want to keep my original wires in place, i currently have mopar electric ign. with a chrome box , has anyone done this, i want the original in place and ready for backup use in case something goes wrong with the msd box, does anybody have any ideas and pictures wld be great. thanks
Re: msd ignition
[Re: mark7171]
#351368
06/18/09 11:38 PM
06/18/09 11:38 PM
Posts: 4,280 Medford OR
FrankenScamp
Medford OR
It will buzz.
Why's it do that? mine does too. At 1st I thought I wired my fan "on" all the time or something.
Re: msd ignition
[Re: FrankenScamp]
#351369
06/18/09 11:59 PM
06/18/09 11:59 PM
Posts: 171 Indy
moparman89
Indy
i dont suggest putting it under the dash. It will buzz and will get annoying.
School of Automotive Machinists Racing
Re: msd ignition
[Re: cornet684me]
#351370
06/19/09 01:57 AM
06/19/09 01:57 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I'd run two msd systems if you are going to run two systems with one as a backup. Look at the Circle track guys they run two systems. With a single-pole, double throw transfer switch, two msds, two coils and one of these You will have basically two systems and one pick up. One goes bad just flip the switch. If you need two pickups they make a dual pickup distributor for the mopar maybe you can rig something for that too. here.. http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Products/Distributors/83923_instructions.pdfHere is the diagram to run with just one pick up. I guess you can run it with the stock ignition, you just need a way to isolate both the start signal and the run signal. Maybe use a double pole single throw switch. http://www.msdignition.com/uploadedfiles/MSDIgnitioncom/Products/Coils/8210_instructions.pdf
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: msd ignition
[Re: HealthServices]
#351371
06/19/09 03:44 AM
06/19/09 03:44 AM
Posts: 7,759 So Cal
HealthServices
So Cal
If you really want to run two ignition systems one MSD and one Factory try this. Click picture for larger view then click pop up for a even larger view. Someone please double check my wiring as I just did this around midnight, Thanks.
Allen
Re: msd ignition
#351373
06/19/09 09:16 PM
06/19/09 09:16 PM
cornet684me
Brandon, Ms
i really do not want to run 2 systems , i want to unplug the factory system and leave it there, then plug in the msd, if something happened, i could just plug the factory up? and the bluzzing sound, you mean if i put this msd under the dash , i will here it when the car is running? my 440 , headers and flowmaster is pretty loud already.
Re: msd ignition
[Re: cornet684me]
#351374
06/19/09 09:21 PM
06/19/09 09:21 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I don't hear the buzing in mine but I have a TTI exhaust. As far as your other concern if you don't want a switch just carry a extra coil ignitor and ballast. The hook up I wrote up, is actually very simple and not as complicated as it appears. you could even wire two stock ignition setups this way.
