Page 1 of 3 1 2 3
headers vs. manifolds #350955
06/18/09 01:18 PM
06/18/09 01:18 PM
North Central Florida
E
eightlitermopar Offline OP
E
Ok, getting ready to put a 440 in my 71 RR.
I have headers and I have manifolds, either way I can get a TTI setup that I can run out the back of the car.
I am not trying to shave tenths of a second off of my ET or anything like that.
I know manifolds can cost power, but how much?
Headers are hot, leak, noisy etc etc etc
Manifolds choke up the engine, but easy to set up compared to getting headers in....
So, maybe I am just getting older and like to do things easy, but I want to do it right also.
So what do you think..and why? Defend your stand on headers or manifolds..
thanks!!!
eight
Mopar or no car
Re: headers vs. manifolds [Re: eightlitermopar] #350956
06/18/09 01:21 PM
06/18/09 01:21 PM
places
79powerwagon Offline
places
After several vehicles with headers, I built my 440 for my Charger with manifolds. I just don't want to mess with headers anymore.
Re: headers vs. manifolds [Re: 79powerwagon] #350957
06/18/09 01:32 PM
06/18/09 01:32 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I put headers on everything, even my daily driver has shorty street rod style headers.
If you buy good fitting headers and prep the mating surfaces before installation you shouldn't have any gasket issues. I have been running on the same set of white paper gaskets for well over a year now.
The only drawback to headers, even the good ones, is the lack of ground clearance. I put the block hugger headers on my truck since I didn't want to worry about smashing the collectors over speed bumps or railroad crossings.
Re: headers vs. manifolds [Re: 79powerwagon] #350958
06/18/09 01:33 PM
06/18/09 01:33 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Depends if the hassle of headers is worth the 10-15%
increase in power they provide, only you can decide.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: headers vs. manifolds [Re: HemiRick] #350959
06/18/09 01:36 PM
06/18/09 01:36 PM
places
places
On drivers (as I use them), headers don't last very long. Manifolds last a good, long time!
Re: headers vs. manifolds [Re: 79powerwagon] #350960
06/18/09 02:27 PM
06/18/09 02:27 PM
michigan woods
imfixinmopars426 Offline
michigan woods
cheap headers or mainfolds=manifolds.tti headers or manifolds=tti. depends what your gunna do w/ the car.if you can afford 20-40 hp,go manifolds.if you can afford 750 for headers,go headers...oh..daily drivers here in michgan never have headers....for long..lol..blat blat blat tic tic blat..
Re: headers vs. manifolds [Re: imfixinmopars426] #350961
06/18/09 02:30 PM
06/18/09 02:30 PM
I dunno,
I bought a CHEAP pair of Walker headers through Summit for my BB E-body and they were the best headers I've ever purchased!
$99.00 and they fit like a glove!
Only ONE tube required cleance around the steering shaft and they had nice thick flanges. The other thing I liked is they tucked up nicely under the car (the deep sump tranny pan was lower!) yet didn't come too close to the floorboards.
As I get older, though, manifolds really look appealing...
Re: headers vs. manifolds #350962
06/18/09 02:34 PM
06/18/09 02:34 PM
(Central) PA
Runner2go Offline
Runner2go  Offline
(Central) PA
I dunno,
And the day your starter finally dies... those manifolds are going to be looking a hell of a lot better.
1966 383, 4-sp Charger 38yrs
1970 440+6, 4-sp Road Runner 36yrs
1974 360, auto Challenger 25yrs,in Family 41yrs
2003 Ram 2500 QCLB 4x4 Cummins HO
2010 5.7L R/T 6sp Challenger - Mopar10
2018 392 Daytona Charger
Re: headers vs. manifolds [Re: 79powerwagon] #350963
06/18/09 02:43 PM
06/18/09 02:43 PM
Joplin, MO
734x4PW Offline
734x4PW  Offline
Joplin, MO
I just got rid of my headers. Once I eliminated years of header gasket leaks (by using flat copper and Hi-temp Copper RTV), my collectors started blowing out regularly. Copper won't seal rust-pitted flanges well...
I recently put 360 manifolds on my 318 and love them. The larger chamber caused my exhaust note to change deeper (resonance) and stronger, too. Performance-wise there's not much difference. Of course it's only a 318.
Mark
Re: headers vs. manifolds [Re: 734x4PW] #350964
06/18/09 03:19 PM
06/18/09 03:19 PM
tti headers...
Re: headers vs. manifolds [Re: 734x4PW] #350965
06/18/09 03:19 PM
06/18/09 03:19 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I'm REALLY thinking manifolds over my TTI headers.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: headers vs. manifolds [Re: eightlitermopar] #350966
06/18/09 03:57 PM
06/18/09 03:57 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
thanks!!!
eight
numbers don't lie
compare column #2 & #3 (HP mani's and extrude honed mani's) vs. column #4 (1 7/8" headers) 24 peak HP increase, 25-30lb ft peak increase (heck, 20-30 lb ft increase from 2600-5600 RPM)...with a stock 440 magnum cam.
peak HP increase might be a little less, peak torque increase might be a little more (but fall off quicker) with 1 3/4" headers. if it were me, I'd use the hedman 78038 elite headers. goes over the steering, ceramic coated, 14 gage tube (should be quieter), 3/8" thick flanges (should seal better), ball and socket collectors (eliminating collector gasket blowout) and $350.
2017 Grand Cherokee Overland
Re: headers vs. manifolds [Re: 71TA] #350967
06/18/09 03:58 PM
06/18/09 03:58 PM
MN
W
Willie68coronet Offline
W
MN
I have never had a problem with my hedman headers. I have the same gaskets that came with them and the car has been running since "02, and about 4 of those years were daily driven in the warm months. They were cheap only $150. But yeah the starter would be a bit of a pain and the spark plugs take longer but its worth the sound and performance to me. And there is ample ground clearance with them.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: headers vs. manifolds [Re: imfixinmopars426] #350968
06/18/09 04:01 PM
06/18/09 04:01 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
have had hedman cheapies on my 5th ave daily driver since 2003. driven in winter since 2006. header pipes are still solid (reducers are another story). only had one collector gasket blow.....also, the starter is easier to get off with the headers (just need to turn the steering wheel hard left) than with the stock tri-cat exhaust.
Re: headers vs. manifolds [Re: patrick] #350969
06/18/09 04:24 PM
06/18/09 04:24 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Spendy, but I think if you're worried about ground clearance, checkout Schumacher's tri-ys
or Headman shorties
Re: headers vs. manifolds [Re: patrick] #350970
06/18/09 04:27 PM
06/18/09 04:27 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
There is no right answer to this question;
- yes, headers will generate more power. Significantly? That depends what you mean. Even the advantages and disadvantages get weighed differently by different people. For some people, 25hp is 25hp and headers are a cheap enough way to get it. For others, they can meet their target of 500hp (or whatever)using manifolds and are happy with that.
- I'm using manifolds because I wanted to be Pure Stock legal and because I prefer a stock look under the hood. One thing I will say is that I'd be very interested in a dyno test between my setup (stock hp manifolds with 2 1/2 TTI Mandrel bent pipes and Dynomax Ultraflows) vs. a generic set of headers with the stock 2 1/4" compression bent pipes and stock mufflers.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: headers vs. manifolds [Re: DPelletier] #350971
06/18/09 04:35 PM
06/18/09 04:35 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
ding ding ding .... WINNER
Re: headers vs. manifolds [Re: 2fast4yourBrain] #350972
06/18/09 04:47 PM
06/18/09 04:47 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Re: headers vs. manifolds [Re: eightlitermopar] #350973
06/18/09 05:26 PM
06/18/09 05:26 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
"I am not trying to shave tenths of a second off of my ET or anything like that."
Manifolds. They look better and have no issues that effect daily driveability.
Sheldon
Re: headers vs. manifolds [Re: RUNCHARGER] #350974
06/18/09 06:43 PM
06/18/09 06:43 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Canceled my TTI order with Mancini on the 10th. Ordered HP Manifolds from Year One and they arrived yesterday. Installed them on the motor today and did a small mock up of all attachments and accessories. I am now officially ready to install the 383. Can you say engine party....
Page 1 of 3 1 2 3
