Coolant leak from header bolts #350803
06/18/09 08:49 AM
06/18/09 08:49 AM
Illinois
saukvillage Offline OP
Illinois
Started new 440ci motor for the first time and after after running to about 200 degree I cut the motor off. Started checking for leaks and I notice coolant coming out the header bolt near the fire wall. So, what can be done to fix this problem,
Thanks.
Re: Coolant leak from header bolts [Re: saukvillage] #350804
06/18/09 08:55 AM
06/18/09 08:55 AM
NY usa
540challenger Offline
NY usa
Thanks.
Some guys like to use studs but in many cases when using headers that is not an option.
You need to put sealant on the header bolts. Some guys use silcone, pipe sealant etc...
Also make sure that you have the correct length bolt some header have an extra thick flange on them.
You might want to drain the block to avoid making a mess.
Re: Coolant leak from header bolts [Re: saukvillage] #350805
06/18/09 08:57 AM
06/18/09 08:57 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Did you use stainless steel bolts? Pull the studs and put sealant on them. I they aren't stainless they will rust shut.
Re: Coolant leak from header bolts [Re: moparpollack] #350806
06/18/09 10:45 AM
06/18/09 10:45 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We use antisieze on them and no leaks.I went back to studs even though the aluminum heads are dry.We use studs wher ever they fit in all our heads.Rocky
Chrysler Firepower
Re: Coolant leak from header bolts [Re: therocks] #350807
06/18/09 12:08 PM
06/18/09 12:08 PM
Canada
Mofopar Offline
Mofopar  Offline
Canada
Only thing I'd add is to brush the threads clean and spray with brake cleaner before applying the silicone.
Re: Coolant leak from header bolts [Re: saukvillage] #350808
06/18/09 01:27 PM
06/18/09 01:27 PM
Saint Charles, MO
P
pleasantk Offline
pleasantk  Offline
P
Saint Charles, MO
Had the same problem last fall on the back driver side. I have studs on mine and after talking to my builder, he recommended running a can of K&W through the cooling system. No leaks since and no issues with temp. Just make sure to follow instructions EXACTLY as written. Want to make sure coolant and K&W don't mix.
Re: Coolant leak from header bolts [Re: pleasantk] #350809
06/18/09 01:59 PM
06/18/09 01:59 PM
vashon island washington
hunterstroble Offline
I huse loctite teflon pipe sealant, and Have used studs and bolts. Works great. Studs are better but sometimes you don't have the room.
1969 Dodge dart 500 stroker 1973 Dodge Challenger 440
Re: Coolant leak from header bolts [Re: hunterstroble] #350810
06/19/09 11:25 AM
06/19/09 11:25 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
What's happening here is your are trying to seal a straight thread. That was NEVER meant to be done.
Studs with a shoulder between the 2 threads or...
Silicones is your best option here.
Teflon tape, pipe paste, pipe thread sealant are for lubricating and sealing tapered threads.
Re: Coolant leak from header bolts [Re: saukvillage] #350811
06/19/09 11:35 PM
06/19/09 11:35 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Gray high temp RTV, SS bolts
I want my fair share
Re: Coolant leak from header bolts [Re: SomeCarGuy] #350812
06/19/09 11:41 PM
06/19/09 11:41 PM
as said the shouldered stud is the best & can trim the outer(fine thread) end for clearance, only need enough threads for the nut to be flush
Re: Coolant leak from header bolts [Re: RapidRobert] #350813
06/20/09 10:39 PM
06/20/09 10:39 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
very common problem. Most header bolts break the wall into coolant channel. Wall is very thin in that area. I use a good high temp sealent when ever i install headers.It's nothing to worry about just a pain to do. Make sure you clean the coolant out of hole before you reinstall the bolts with sealent.
Re: Coolant leak from header bolts [Re: Dougsmopars] #350814
06/21/09 08:18 AM
06/21/09 08:18 AM
NY
old340dog Offline
old340dog  Offline
NY
Will I experiance this problems with my 340 also?We just dropped motor back in yesterday and got headers bolted up. I haven't put any coolant in yet. I'm using Edlebrock RPM performer heads. So should I take the header bolts out at back of motor and put some sort of thread sealant in? Or do all of the header bolts?
old340dog
Re: Coolant leak from header bolts [Re: old340dog] #350815
06/21/09 08:33 AM
06/21/09 08:33 AM
only the 4 corner bolts are wet on a SB & if the trimmed shouldered studs will work there I would use them(w sealant)& if not I would pump the rad up to 15 lbs of air & see if no leaks(that stant pump kit does come in handy at times) and pull the 4 corners & seal them.
