Results of Cal Trac adjustments. Pics included #348440
06/15/09 10:24 PM
06/15/09 10:24 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Well I got to the track Saturday. It ran a 1.48 60' off the trailer at 10.74. This was .15 slower than the last outing in April. It was 10* warmer and the DA was 1000' higher. I hope that is what slowed it down. The pics from this weekend are here.http://www.erikandersondesigns.com/images/2009/06-13-MokanAllOut/0008/imagepages/image13.html I believe this was my second run. And That this was just after the 1st pic. http://www.erikandersondesigns.com/images/2009/06-13-MokanAllOut/0008/imagepages/image14.html And this would have been in April. http://www.erikandersondesigns.com/images/2009/04-11-MoparsInvade/0001/imagepages/image7.html I believe it needed more air preasure this time 12.5 versus 13.5 in April. As always comments are appreciated. Jim
Re: Results of Cal Trac adjustments. Pics included [Re: rt66jim] #348441
06/15/09 10:32 PM
06/15/09 10:32 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
a video from behind the car would be more helpfull
Re: Results of Cal Trac adjustments. Pics included [Re: sixpackgut] #348442
06/16/09 12:31 AM
06/16/09 12:31 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
what do you have your bars set at? looks like your in the top hole, whats the combo, and what are you leaving at?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Results of Cal Trac adjustments. Pics included [Re: Stroker Scamp] #348443
06/16/09 09:03 AM
06/16/09 09:03 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Bars are in the lower hole. 2 flats of preload on the left and 4 on the right. Jim
Re: Results of Cal Trac adjustments. Pics included [Re: rt66jim] #348444
06/16/09 09:25 PM
06/16/09 09:25 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
This vid wasn't taken from the rear. It's all I've got right now. Really can't tell much. Jim http://www.youtube.com/watch?v=3_HixCIVFDQ
Re: Results of Cal Trac adjustments. Pics included [Re: rt66jim] #348445
06/16/09 09:48 PM
06/16/09 09:48 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Isn't that a lot more preload than most run?
Re: Results of Cal Trac adjustments. Pics included [Re: Quicksilver440] #348446
06/17/09 11:22 AM
06/17/09 11:22 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Would 2 flats be equal to 1/4 turn? Mine works best at 1/4 turn both sides. Shocks on 5, Bottom hole.
Re: Results of Cal Trac adjustments. Pics included [Re: cudarex] #348447
06/17/09 11:39 AM
06/17/09 11:39 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
every car is different,my car only runs 11.70 at 4,129lbs and i just preload till they touch on both sides,launches perfect.but with this heavy of a car i measure my 60,s on the calendar.
Re: Results of Cal Trac adjustments. Pics included [Re: Quicksilver440] #348448
06/17/09 12:52 PM
06/17/09 12:52 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I believe it may be. It was a suggested setting made by someone else who runs them. The 1st time out with it I had an 1/8" gap. This time it carried the wheels a little higher and farther. However, the 60's were the same but the ET's were off. I think that was because the weather was different. Jim
