Re: Results of Cal Trac adjustments. Pics included
[Re: rt66jim]
#348441
06/15/09 10:32 PM
06/15/09 10:32 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
a video from behind the car would be more helpfull
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#348442
06/16/09 12:31 AM
06/16/09 12:31 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
what do you have your bars set at? looks like your in the top hole, whats the combo, and what are you leaving at?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: rt66jim]
#348445
06/16/09 09:48 PM
06/16/09 09:48 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Bars are in the lower hole. 2 flats of preload on the left and 4 on the right. Jim
Isn't that a lot more preload than most run?
[Re: cudarex]
#348447
06/17/09 11:39 AM
06/17/09 11:39 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
every car is different,my car only runs 11.70 at 4,129lbs and i just preload till they touch on both sides,launches perfect.but with this heavy of a car i measure my 60,s on the calendar.
[Re: Quicksilver440]
#348448
06/17/09 12:52 PM
06/17/09 12:52 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
I believe it may be. It was a suggested setting made by someone else who runs them. The 1st time out with it I had an 1/8" gap. This time it carried the wheels a little higher and farther. However, the 60's were the same but the ET's were off. I think that was because the weather was different. Jim
