440 question #347518
06/15/09 02:40 AM
06/15/09 02:40 AM
granite bay ca
dodgeguy7714 Offline OP
granite bay ca
so what happened is i mixed up a couple pistons when i pulled apart a motor i had laying around and for some reason a couple the pistons didnt get marked for location what hole they came out of . so the have the notches to show direction they face to frt of block but does one side of the rod face down .not sure if im asking this right .will i have a problem with oiling if they wind up in the wrong hole left to right bank.i realize the marks go to frt thats a given. a little help please
Re: 440 question [Re: dodgeguy7714] #347519
06/15/09 07:42 AM
06/15/09 07:42 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
As long as you didn't mix the caps up, and the notches all face forward, it should be okay as long as they're flat top pistons. But, you should pay attention to the big end of rod for correct arrangement of bearing lock tabs and the chamfer areas. The oiling won't be a problem, but the wider chamfers of con rod need to face away from each other on crankpin in most cases. I've taken a few engines apart that had a couple rods in wrong locations that still caused no problem.
Re: 440 question [Re: buildanother] #347520
06/15/09 08:40 AM
06/15/09 08:40 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Rods don't care what side that they are on. Like said above make sure that the pistons are facing the right direction The the big end should be right too.
