Re: Broke last nite. What caused it? (pics)
[Re: challenger73400]
#346758
06/14/09 04:39 PM
06/14/09 04:39 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
If it broke once buy good stuff the second time. Yes, 1350 u-joints and a billet yolk. Sorry to see the bad luck.
[Re: Rodney]
#346762
06/14/09 05:08 PM
06/14/09 05:08 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
And check your over running clutch or sprage if you are running a 727 tranny.
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: Rodney]
#346764
06/14/09 06:11 PM
06/14/09 06:11 PM
Posts: 470 Big Chicago
amixon
Big Chicago
your lucky it lasted this long.
Overkill the drivetrain. Billet yoke, SOLID 1350 joints coupled with the best driveshaft you can afford. 300 to 400 dollars spent on that will save your Trans.
Sorry to see the damage
At least you did not get hurt
[Re: amixon]
#346765
06/14/09 06:27 PM
06/14/09 06:27 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
Can I make a suggestion , when you go to billet front yoke go for the billet pinion yoke too......ask me how I know the ride isnt fun . John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
#346767
06/14/09 06:39 PM
06/14/09 06:39 PM
Bigcube
Upstate NY
I guess it's time to dig deep on these parts. I've just never seen a failer of the slip yoke before. Who do you get to build your driveshafts? I guess I could get a driveshaft from a junk yard that takes 1350s, cut it down myself and put good u-joints and billet yokes on it. Will that be strong enough?
You can't cut it down unless you can balance it. Have a good shop build a heavy wall shaft or go with moly or alum. Most heavy duty truck shops have a drive line shop and can build custom driveshafts.
#346768
06/14/09 06:42 PM
06/14/09 06:42 PM
amixon
Big Chicago
sure, cause all of those OEM driveshafts are designed to handle those huge shock loads your car is making! Don't cut corners here. Check a few driveshafts shops, Mark Williams, Strange, Moser, Performance Driveline, Denny's Driveshafts ect...
#346772
06/14/09 09:54 PM
06/14/09 09:54 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
As I launched, this broke. 1.40 60ft in a 2800lb truck in this heat. This is a OEM pc with spicer 7260 u-joints. All the u-joints look and feel fine. The drive line angle at the front u-joint is about 2 degress off but I would think the u-joint would have failed if that was a facor. It also took out the tail housing of the trans. I'll have to pull the trans and check the sprag and the output shaft. When it hit the drive shaft loop, it put some dings in the drive shaft so I will build a new drive shaft. What should I do? Build a drive shaft with 1350s and billet yokes or use OEM parts? Thanks, Scott.
1.40 60 ft and you want to use OEM parts ??? NO
and correct your driveline angle
[Re: JohnRR]
#346773
06/14/09 10:08 PM
06/14/09 10:08 PM
Posts: 303 southwest Alabama
challenger73400
southwest Alabama
OK, point taken. I'll put after market parts in it. Correcting the drive angle will be a big job, I set it up like that on purpose. I put the motor over to the pass side about 1-1/2" for a number of reasons but everything is built around it. I've been a best of 1.34 60ft set up just like this, guess my luck ran out.
#346774
06/14/09 10:38 PM
06/14/09 10:38 PM
JohnRR
U.S.S.A.
Yes , only a matter of time , hopefully it wasn't to costly. When during the run did it break ?
