Broke last nite. What caused it? (pics) #346757
06/14/09 04:29 PM
06/14/09 04:29 PM
southwest Alabama
challenger73400 Offline OP
southwest Alabama
As I launched, this broke. 1.40 60ft in a 2800lb truck in this heat. This is a OEM pc with spicer 7260 u-joints. All the u-joints look and feel fine. The drive line angle at the front u-joint is about 2 degress off but I would think the u-joint would have failed if that was a facor.
It also took out the tail housing of the trans. I'll have to pull the trans and check the sprag and the output shaft.
When it hit the drive shaft loop, it put some dings in the drive shaft so I will build a new drive shaft.
What should I do? Build a drive shaft with 1350s and billet yokes or use OEM parts? Thanks, Scott.
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346758
06/14/09 04:39 PM
06/14/09 04:39 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
If it broke once buy good stuff the second time. Yes, 1350 u-joints and a billet yolk. Sorry to see the bad luck.
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346759
06/14/09 04:44 PM
06/14/09 04:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What is it, a 40 year old cast yoke.... go with a
good billet piece
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346760
06/14/09 05:05 PM
06/14/09 05:05 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
your lucky it lasted this long.
Re: Broke last nite. What caused it? (pics) [Re: MR_P_BODY] #346761
06/14/09 05:08 PM
06/14/09 05:08 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We bust the good ones , the stock ones dont stand a chance, nothing worse than huntin for driveline parts in the mud
Re: Broke last nite. What caused it? (pics) [Re: Rodney] #346762
06/14/09 05:08 PM
06/14/09 05:08 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
And check your over running clutch or sprage if you are running a 727 tranny.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346763
06/14/09 05:46 PM
06/14/09 05:46 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Wll let's see--a 40yr old piece,in a car your beating on. My guess would be age and perhaps a worn trans insulator mount which allowed it to move too much?
Re: Broke last nite. What caused it? (pics) [Re: Rodney] #346764
06/14/09 06:11 PM
06/14/09 06:11 PM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
Overkill the drivetrain. Billet yoke, SOLID 1350 joints coupled with the best driveshaft you can afford. 300 to 400 dollars spent on that will save your Trans.
Sorry to see the damage
At least you did not get hurt
Big Anthony ANTHONYinIRAQ@gmail.com
1984 B150 Ram Wagon
1978 D100 ClubCab
Re: Broke last nite. What caused it? (pics) [Re: amixon] #346765
06/14/09 06:27 PM
06/14/09 06:27 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
Can I make a suggestion , when you go to billet front yoke go for the billet pinion yoke too......ask me how I know the ride isnt fun . John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Broke last nite. What caused it? (pics) [Re: amixon] #346766
06/14/09 06:34 PM
06/14/09 06:34 PM
southwest Alabama
southwest Alabama
I guess it's time to dig deep on these parts. I've just never seen a failer of the slip yoke before. Who do you get to build your driveshafts?
I guess I could get a driveshaft from a junk yard that takes 1350s, cut it down myself and put good u-joints and billet yokes on it. Will that be strong enough?
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346767
06/14/09 06:39 PM
06/14/09 06:39 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
You can't cut it down unless you can balance it. Have a good shop build a heavy wall shaft or go with moly or alum. Most heavy duty truck shops have a drive line shop and can build custom driveshafts.
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346768
06/14/09 06:42 PM
06/14/09 06:42 PM
Big Chicago
amixon Offline
amixon  Offline
Big Chicago
sure, cause all of those OEM driveshafts are designed to handle those huge shock loads your car is making!
Don't cut corners here.
Check a few driveshafts shops, Mark Williams, Strange, Moser, Performance Driveline, Denny's Driveshafts ect...
1984 B150 Ram Wagon
1978 D100 ClubCab
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346769
06/14/09 07:30 PM
06/14/09 07:30 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Ouch
Re: Broke last nite. What caused it? (pics) [Re: emarine01] #346770
06/14/09 07:48 PM
06/14/09 07:48 PM
NC
440Jim Offline
440Jim  Offline
NC
The casting and history of use (abuse) of 30+ year old parts can vary a lot. My car has a factory drive shaft yoke, and it is holding up, things just break. Now, my car is a pure footbrake racer, trans breaks will "break" things with less power...
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346771
06/14/09 09:41 PM
06/14/09 09:41 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Never seen a trans yoke break apart like that, i have twisted the 1350 empire yoke in my a-833 to the point of beating it off the trans with a 4lb. hammer. Old mopar yoke like yours slid right on as did a new 1350 yoke. Billet is the way to go if you can find one.
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346772
06/14/09 09:54 PM
06/14/09 09:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
1.40 60 ft and you want to use OEM parts ??? NO
and correct your driveline angle
Re: Broke last nite. What caused it? (pics) [Re: JohnRR] #346773
06/14/09 10:08 PM
06/14/09 10:08 PM
southwest Alabama
southwest Alabama
OK, point taken. I'll put after market parts in it.
Correcting the drive angle will be a big job, I set it up like that on purpose. I put the motor over to the pass side about 1-1/2" for a number of reasons but everything is built around it.
I've been a best of 1.34 60ft set up just like this, guess my luck ran out.
Re: Broke last nite. What caused it? (pics) [Re: challenger73400] #346774
06/14/09 10:38 PM
06/14/09 10:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes , only a matter of time , hopefully it wasn't to costly. When during the run did it break ?
