Page 2 of 3 1 2 3
Re: Convertor bolts with lock tight? [Re: MR_P_BODY] #346219
06/14/09 11:27 AM
06/14/09 11:27 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
I use the red locktite and I can get my impact on them
(in the starter area without the starter in) and get
them good and tight. Same thing when I take them out
I thought there was a torque limit on the bolts....you don't want to tighten them to the point of stretch....you will weaken them....I would think the locktite and proper torque would be OK....
71 440-6 4spd & 69 Hemi 4spd
Re: Convertor bolts with lock tight? [Re: hemi_doug] #346220
06/14/09 11:38 AM
06/14/09 11:38 AM
i really couldnt see how to use a torque wrench on converter bolts, its tough enough getting a open end in there. i notched the bottom of my trans. case to get a better angle and placement on the bolts.
Re: Convertor bolts with lock tight? [Re: hemi_doug] #346221
06/14/09 12:00 PM
06/14/09 12:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its the way I do it, 7/16 fine thread bolt has a
pretty good torque to it and I'm sure I dont get near
stretching it.... never had any come loose doing it
this way
Re: Convertor bolts with lock tight? [Re: MR_P_BODY] #346222
06/14/09 01:06 PM
06/14/09 01:06 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Man stretch a converter bolt , those pups are about as thick as long and hard as hell, you can stretch one without stripin it
Re: Convertor bolts with lock tight? [Re: emarine01] #346223
06/14/09 01:38 PM
06/14/09 01:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Exactly
Re: Convertor bolts with lock tight? [Re: emarine01] #346224
06/14/09 01:57 PM
06/14/09 01:57 PM
fullmetaljacket Offline OP
Okay, so whats the torque rating on the bolts? Last I believe it calls for 35 foot pounds or some thing like that.
Re: Convertor bolts with lock tight? [Re: MR_P_BODY] #346225
06/14/09 02:02 PM
06/14/09 02:02 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
I have used both Blue and Red at different times.
I still have "check Converter bolts" on my check sheet as even with the Red they can come loose.
http://www.loctiteproducts.com/products/subcategory.asp?CatID=10&SubID=48
Use either, but check regularily...
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Convertor bolts with lock tight? [Re: fullmetaljacket] #346226
06/14/09 02:03 PM
06/14/09 02:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
270 in lbs... converter to flex plate
Re: Convertor bolts with lock tight? [Re: MR_P_BODY] #346227
06/14/09 02:09 PM
06/14/09 02:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
270 in lbs = 22.5 ft lbs. Is that 7/16" or 5/16" bolts?
Re: Convertor bolts with lock tight? #346228
06/14/09 02:09 PM
06/14/09 02:09 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Shorten a 3/8 socket and you can use a 3/8 torque wrench. That is how I do it.
I have loosened the bolts a couple of times. Once I started using blue Loctite and torquing to 50 ft/lb, no issues.
Factory spec is 55 ft/lb, but I am not sure on the friction modifier. Don't know if that is a dry or wet torque, so I am kind of guessing on what the torque should actually be.
BTW - - I use ARP bolts.
Re: Convertor bolts with lock tight? [Re: markz528] #346229
06/14/09 02:23 PM
06/14/09 02:23 PM
SWEET HOME ALABAMA
I
ITSDUSTA416 Offline
ITSDUSTA416  Offline
I
SWEET HOME ALABAMA
I use red loctite & to take them out I heat the bolt a little with a torch and they come out like there not even tight. Never had one back out with RED LOCTITE 271.MY
71 DUSTER 416 ET 6.33 @ 107 1.33 60FT
Re: Convertor bolts with lock tight? [Re: justinp61] #346230
06/14/09 02:58 PM
06/14/09 02:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Production bolts (spec is from Munroe's 727 trans handbook)
Re: Convertor bolts with lock tight? [Re: ITSDUSTA416] #346231
06/14/09 03:05 PM
06/14/09 03:05 PM
MN
hemidup Offline
hemidup  Offline
MN
I use red Loctite. Thanks for the tip about using a torch for removal.
I just entered that one in my hair covered computer.
Jerry Williams.
Re: Convertor bolts with lock tight? [Re: hemidup] #346232
06/14/09 03:17 PM
06/14/09 03:17 PM
south louisiana
lowell66dart Offline
south louisiana
I use a long handle 3/8 rachet. I rotate the bolt up to the area where the oil pan meets the block on the oposite side of the starter. Plenty of room to work.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Convertor bolts with lock tight? [Re: lowell66dart] #346233
06/14/09 03:57 PM
06/14/09 03:57 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Too bad you cant get a shake proof washer in there. Red Locktite on mine.
Re: Convertor bolts with lock tight? [Re: MR_P_BODY] #346234
06/14/09 11:01 PM
06/14/09 11:01 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
270 in/lb is for the 5/16 bolts. 55 ft/lb is the factory spec for 7/16 bolts.
Re: Convertor bolts with lock tight? [Re: bobby66] #346235
06/14/09 11:08 PM
06/14/09 11:08 PM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
Now, I've got some perspective on this as I just grenaded another flex plate. When this problem first cropped up, I tried all the colors of Loc-Tite to no avail. Finally, I tried an old trick I learned a long time ago from a millwright and wrapped the bolts in Teflon tape. I checked the bolts frequently after that, and found them to be holding perfectly, and eventually left them be. I did a cursory check this spring and found to be apparently okay, so I didn't check them again after the first outing. Sure enough, yesterday morning I put down an 11.45 on the footbrake, and an hour later pulled in for my first t-brake launch. I detected a funny clatter when I fired it up in the lanes, and made a mental note to crawl underneath and check things out after this pass. Sure enough, foot to the floor, tree coming down, and all of a sudden she hits the rev limiter. Scratch one flex plate. I'll crawl under it later this week and see if I've wounded a convertor. If I have, it might be a season fore me, if I need a new convertor, as I've just recently become self-employed. Oh, well. That's racing.
Re: Convertor bolts with lock tight? [Re: dvw] #346236
06/14/09 11:11 PM
06/14/09 11:11 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I've used both. Red is diffucult to remove. A few thoughts. The torque applied with a impact gun to a 3/8" bolt would probably be excessive. Why don't converter bolts come loose on a high milage street car without locktite? I locktite mine and have over torqued them also. Just wondering why they tend to come loose in a drag racing application.
Doug
Almost all the "factory" bolts that go in the minivans, trucks, cars, mopar instructors tell us to put either blue, or red. I use red on everything either 727, 904, or 545RFE.
I have never had any issues with red. I did run out of red once and all I had was the gree penetrating stuff. This was in a buddies 4x4,,, Well when it came time to get them back out they were very tough, I had to heat with a propain torch.
kasey
Re: Convertor bolts with lock tight? [Re: bill_greenwood] #346237
06/14/09 11:16 PM
06/14/09 11:16 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i use the blue or red . Mine dont come loose anymore . The teflon tape trick did NOT work on my car .
Re: Convertor bolts with lock tight? [Re: 493_DART] #346238
06/15/09 12:08 AM
06/15/09 12:08 AM
While we're on this, what pounds do you guys set the flexplate to crank bolts? They are also 7/16 in size.
Page 2 of 3 1 2 3
