comp roller lifters? #345867
06/13/09 04:35 PM
06/13/09 04:35 PM
KY
juicedcuda Offline OP
KY
What are the correct Comp roller lifters for a bushed big block w/ pushrod oiling? I have a set of 829-16's and I remember member OU812 was offering another newer design, but I don't have the part #?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: comp roller lifters? [Re: juicedcuda] #345868
06/13/09 04:41 PM
06/13/09 04:41 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I use the comp 892-c lifters (c=centerd)
Re: comp roller lifters? [Re: juicedcuda] #345869
06/13/09 05:49 PM
06/13/09 05:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How can you have p/rod oiling if the lifter bores are bushed??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: comp roller lifters? [Re: hemi-itis] #345870
06/13/09 06:57 PM
06/13/09 06:57 PM
KY
KY
bushings drilled in lifter bores?
Re: comp roller lifters? [Re: hemi-itis] #345871
06/13/09 07:05 PM
06/13/09 07:05 PM
KY
KY
By chance, do you know the part # of the lifters pictured?
Re: comp roller lifters? [Re: juicedcuda] #345872
06/13/09 07:16 PM
06/13/09 07:16 PM
hemi-itis Offline
hemi-itis  Offline
Those are comp 829's without EDM oiling.I now use the 848's in my hemi and Brian's wedge.Sent oil up the exhaust side only on the hemi and all 16 on the wedge.Oil pressure was 15lbs less with these lifters.
Re: comp roller lifters? [Re: hemi-itis] #345873
06/14/09 09:50 AM
06/14/09 09:50 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Not to highjack but. What is the difference between Comp 892 and 829?
Doug
Re: comp roller lifters? [Re: dvw] #345874
06/14/09 10:27 AM
06/14/09 10:27 AM
San Jose Ca.
San Jose Ca.
the comp 892 lifter is a p.r. oiling lifter where a 829 is not!
Re: comp roller lifters? [Re: juicedcuda] #345875
06/14/09 11:32 AM
06/14/09 11:32 AM
SoCal
Brian Hafliger Offline
SoCal
I still offer them, the body design is a little different than what comp sells.
I have them in centered and offset.
Brian
Brian Hafliger
