1970 Ebody Convertible cracking #345079
06/12/09 05:15 PM
06/12/09 05:15 PM
Milford PA
benny Offline OP
benny  Offline OP
Milford PA
In the area of the upper corners above the trunk there is a re occurring crack thru the paint. I believe several years ago someone posted a cure for this problem, but i cannot find it . Anyone got any solutions to this problem ?
Re: 1970 Ebody Convertible cracking [Re: benny] #345080
06/12/09 06:22 PM
06/12/09 06:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You'll hear ten different ideas.. Good Luck figuring out what works... I've done all kinds of fillers, polyester, fiberglass, all metal... In the end tig welded it solid, cut a piece of sheetmetal to fit in the trought, tig welded it in solid, then filled the majority of the remaining area with lead... Throughly tinned, throughtly neutralized everything.. Sealed the lead then did final finishing with Polyester finishing putty... Did two Challengers this way, three of the four seams are perfect, one has a small crack showing, I suspect I missed some contaimination under the lead..
Re: 1970 Ebody Convertible cracking [Re: benny] #345081
06/12/09 07:50 PM
06/12/09 07:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Before you re=do any work,....some QUALITY frame connectors, and other body mods go along way in stabilizing the shell, before doing body work
Re: 1970 Ebody Convertible cracking [Re: DAYCLONA] #345082
06/12/09 10:21 PM
06/12/09 10:21 PM
MERRILLVILLE, INDIANA
sunroof446 Offline
sunroof446  Offline
I did a challenger over two years ago. It is still fine. I always weld that seam in solid. If you don't it will crack.
Re: 1970 Ebody Convertible cracking [Re: sunroof446] #345083
06/13/09 10:41 AM
06/13/09 10:41 AM
The way the factory did it, it will always crack. It is a weak point that flexes. I have always seen convertibles, even our 71 Buick GS convert, cracked in the same location.
Re: 1970 Ebody Convertible cracking [Re: ] #345084
06/13/09 06:49 PM
06/13/09 06:49 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Yep! Known as the "factory installed crack". Even with frame connectors mine has them. Maybe the 440-6 is the culprit!
Re: 1970 Ebody Convertible cracking [Re: Classof70Chally] #345085
06/13/09 07:54 PM
06/13/09 07:54 PM
ha ha. Thats good. I will have to remember that one...... "factory installed crack"
Re: 1970 Ebody Convertible cracking [Re: ] #345086
06/13/09 08:48 PM
06/13/09 08:48 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Even though my bodyman "fixed it", mine cracked about six months later (about the time I started driving it) Yep it's kind of like concrete work, the only guarantee you get is that it WILL crack.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 1970 Ebody Convertible cracking [Re: benny] #345087
06/14/09 05:14 PM
06/14/09 05:14 PM
Chicagoland
cudastruction Offline
Chicagoland
Can someone attach a picture of this crack?
Al
Re: 1970 Ebody Convertible cracking [Re: cudastruction] #345088
06/14/09 09:27 PM
06/14/09 09:27 PM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
Al
on hard tops the place is very visable and a groove. on vets it is filled in.
It is where the quater panel meets the section forward of the trunk.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: 1970 Ebody Convertible cracking [Re: cudastruction] #345089
06/15/09 10:22 AM
06/15/09 10:22 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Al
My 69 rr vert has these cracks, but momma told me not to reveal my crack in public.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 1970 Ebody Convertible cracking [Re: benny] #345090
06/15/09 10:30 AM
06/15/09 10:30 AM
Millersville, PA
HemiChallenger Offline
Millersville, PA
My dads hemi we used seem sealer then using your finger spread thinner over it and pull all the excess out. They it looks just like the factory and it held on that car for 8 years...And it had 600 ponies that did get used
Re: 1970 Ebody Convertible cracking [Re: cudastruction] #345091
06/17/09 01:32 AM
06/17/09 01:32 AM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
71 Challenger
Re: 1970 Ebody Convertible cracking [Re: Steve340] #345092
06/17/09 10:35 AM
06/17/09 10:35 AM
Chicagoland
Chicagoland
Thanks for the pic...
Re: 1970 Ebody Convertible cracking [Re: cudastruction] #345093
06/17/09 10:46 AM
06/17/09 10:46 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I guess I didn't realize that the convert had that area "filled" in. What was the reason for doing it that way. Did it have to do with the convert boot when the top was down?
Re: 1970 Ebody Convertible cracking [Re: burdar] #345094
06/17/09 02:30 PM
06/17/09 02:30 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Who knows that's just the way a vert is made and that is the way they crack.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
