what size stall for my 440? #345057
06/12/09 05:14 PM
06/12/09 05:14 PM
nc
Racerwill1 Offline OP
nc
What size stall would be good for my 440? Its in a 74 challenger. 906 heads, .509 purple shaft, 750 holley. It's not for the track, just driving on the weekends and around town. Thanks
Re: what size stall for my 440? [Re: Racerwill1] #345058
06/12/09 05:19 PM
06/12/09 05:19 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Nice sized cam for just a weekend driver.
2200-2400 is all it should need.
Any more stall and you just waste fuel.
Snap your neck, mega G-force launch, is all I want!
Re: what size stall for my 440? [Re: BDS871Cuda] #345059
06/12/09 05:26 PM
06/12/09 05:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would use alot more then 2500 with the MP .509 cam. What gears are you running ? I use a 9.5 Dynamic that works great for me. Drives like a regular converter but flashes about 4200 at the track. Ron
Re: what size stall for my 440? [Re: 383man] #345060
06/12/09 05:35 PM
06/12/09 05:35 PM
nc
nc
Just 355s right now. So do I need something in the 3000 range?
Re: what size stall for my 440? [Re: Racerwill1] #345061
06/12/09 05:38 PM
06/12/09 05:38 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Do you want to be able to nail the throttle and bust tires loose but good? I'd stick the ptc 9.5 in there.
Re: what size stall for my 440? [Re: buildanother] #345062
06/12/09 05:41 PM
06/12/09 05:41 PM
nc
nc
Yea every now and then, but I also want to be able to drive around with no issues.
Re: what size stall for my 440? [Re: Racerwill1] #345063
06/12/09 05:52 PM
06/12/09 05:52 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
With that combo I would say go with 3000 RPM stall.
Re: what size stall for my 440? [Re: anmracing] #345064
06/12/09 06:06 PM
06/12/09 06:06 PM
nc
nc
Thanks for the help guys.
Re: what size stall for my 440? [Re: anmracing] #345065
06/12/09 06:31 PM
06/12/09 06:31 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
3000 stall and install the cam at 102 to 104
Re: what size stall for my 440? [Re: Racerwill1] #345066
06/12/09 07:38 PM
06/12/09 07:38 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
mopar 509 is about 250 duration at .050 i believe. needs a good 4000. 383man has some good advice. I have a 9.5 dynamic in my 3500 lb satellite. no problems on the street, even with 3.23 gears. been in there for years and gets driven alot.
Re: what size stall for my 440? [Re: forphorty] #345067
06/12/09 07:46 PM
06/12/09 07:46 PM
Melbourne, FL
dwbiggs Offline
super gas
dwbiggs  Offline
super gas
Melbourne, FL
For God's sakes don't skimp on the converter...get a quality one...you won't regret it.
Re: what size stall for my 440? [Re: dwbiggs] #345068
06/12/09 08:01 PM
06/12/09 08:01 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Quote: "For God's sakes don't skimp on the converter...get a quality one...you won't regret it."
umm. I'm running a 3800lb 69 B-body with a 496 stroker, beefed up 727 rev. manual valve body with external cooler, 3:23's, M/T drag radials that hook real nice and running high 11's...
This combo also includes a very cheapo Mopar Performance "Economy Hi-stall" 2200rpm (factory 340 hi-stall?) converter bought for $240 new 3 years ago and performs great.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: what size stall for my 440? [Re: Hoof Hearted] #345069
06/12/09 11:11 PM
06/12/09 11:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What cam and what size rear tires are you running ?? Ron
Re: what size stall for my 440? [Re: Hoof Hearted] #345070
06/13/09 05:38 AM
06/13/09 05:38 AM
BDS871Cuda Offline
BDS871Cuda  Offline
I thought I said 2200-2400? I guess Hoof
is the only one to understand.
Wasn't this just a street car. I would of picked
a smaller cam, but the 509 will work.
On the street it doesn't matter what stall you have
(with in reason) or what the gears are because it never hooks.
Yes the bigger stall is better at the track, but it
sucks for freeway cruisen when matched up with
low gears.
Re: what size stall for my 440? [Re: BDS871Cuda] #345071
06/13/09 02:33 PM
06/13/09 02:33 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
low gears.
hoof has a 496, the original poster has a 440. i do agree with you somewhat in that with typical hard street tires it might not hook up anyway no matter what convertor. But he might get the urge to go racing someday and that 509 will be a dog out of the hole with a 2400 stall. I agree that if it is just a street cruiser he ought to just put a smaller cam in it, about 230 at .050 or thereabouts, along with your recommended 2400 convertor . As far as Roofs cheapo MP convertor, i've got one behind a mild 400 and like it but i might be a bit leery of running one with a high output motor for fear it might not last long.
Re: what size stall for my 440? [Re: Racerwill1] #345072
06/13/09 04:03 PM
06/13/09 04:03 PM
Seymour,IN.
HoosierGTX Offline
HoosierGTX  Offline
Seymour,IN.
I am running the exact same setup you have in a 69 gtx with 430 gears and I am using a 10" 3500 TCI converter,go ahead and spend the money on a good converter you won't be sorry!
Re: what size stall for my 440? [Re: anmracing] #345073
06/13/09 08:49 PM
06/13/09 08:49 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
for a street car, I agree...
More would be ideal, but a 440 is pretty forgiving with anything 3K or more.
Re: what size stall for my 440? [Re: Racerwill1] #345074
06/14/09 12:39 AM
06/14/09 12:39 AM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
hi
there are 2 509 cams , whitch one do yyou have ??
Re: what size stall for my 440? [Re: Racerwill1] #345075
06/14/09 01:11 AM
06/14/09 01:11 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Ran the .509 for years....and I can tell you that there is NO way a 2400 rpm convertor is a choice at all!!
3000 - 3400 is what you need. And if you're worried about not being able to "cruise" you're worrying too much!!!
My Challenger was a tad "loose" under 40 MPH with a 3800 B&M Holeshot, but on the highway it was no problem. No difference in mileage to speak of.
Don't waste the time with a low stall convertor...get one that will make use of the cam.
That .509 is a great cam.
Re: what size stall for my 440? [Re: superwrench] #345076
06/14/09 08:00 AM
06/14/09 08:00 AM
nc
nc
Thanks for all the great help. I think i'm going with a 3000. I'm going to be driving it from Ohio to North Carolina next week. Wish me luck!!!
