Fastest 318 based motor on Moaprts? #344614
06/12/09 08:51 AM
06/12/09 08:51 AM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
With any luck I should have my little 341 motor together and it just got me curious to see if any other 318 based motors are out there.
3.91" bore "seems" small but it doesn't seem to be an issue with the LS1 chavy which at 346" is almost dimensionally identical to this motor that (I must admit) seems 'tiny' after building so many 500+ inch motors over the years.
I know smallblock questions on 'Race only' sink off the front page pretty quickly, but let's see if anybody is out there. 318's seem to be pretty popular with the A body crowd, I suppose it's (naturally) because it's getting tough to find any 340 or 360 35+ years on that hasn't been punched to the max. 3.91 seems small but it's 97.7% of a 4" bore and with the much better heads we have today the big bore isn't as critical to good VE and cylinder filling as it was back in the old days.
WIZE
In Car:
Re: Fastest 318 based motor on Moaprts? [Re: Streetwize] #344615
06/12/09 09:07 AM
06/12/09 09:07 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
W5DART66
3.94 bore 3.51 stroke.3000lb race weight 4.56 gear 904 6000RPM converter low gear set.best pass 9.84 @ 136
+.030" 318 w/MP 3.51" crank, W-5 heads, roller.......
Re: Fastest 318 based motor on Moaprts? [Re: S/ST 3040] #344616
06/12/09 09:44 AM
06/12/09 09:44 AM
detroit area
moderncylinder Offline
detroit area
i have a buddy that has been 9.84 at 134 at 2850lbs with a std stroke, .030 over 318 with factory ported iron heads and a thermoquad in a daytona,, 9/1 comp or so.. roller cam...
its a super stock car.. has record in ss/ga, ss/ha, and i think still ss/ia
Re: Fastest 318 based motor on Moaprts? [Re: moderncylinder] #344617
06/12/09 09:56 AM
06/12/09 09:56 AM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
[quote
GT/GA, GT/HA, GT/IA; correction my friend...
Re: Fastest 318 based motor on Moaprts? [Re: SuperStocker] #344618
06/12/09 10:17 AM
06/12/09 10:17 AM
detroit area
detroit area
yeah,,, sorry how much does a good stocker 340 make??? hp wise,, i have a customer that just built one
Re: Fastest 318 based motor on Moaprts? [Re: moderncylinder] #344619
06/12/09 10:23 AM
06/12/09 10:23 AM
south louisiana
lowell66dart Offline
south louisiana
Over on A bodys only there was someone that was using a Mopar 4 inch 318/340 main crank, 340 standard bore (4.04) pistons,aka dirt cheap, and a stock rod. I want an X block but haven't found any that are close or affordable. The combo above is something I'm going to look hard at in the future.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Fastest 318 based motor on Moaprts? [Re: lowell66dart] #344620
06/12/09 07:13 PM
06/12/09 07:13 PM
Weddington, N.C.
Weddington, N.C.
Trying to find out only about 318 Block based motors on this thread...any more???
WIZE
In Car:
Re: Fastest 318 based motor on Moaprts? [Re: Streetwize] #344621
06/12/09 07:33 PM
06/12/09 07:33 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Moparts Member Wade Metzinger just built a 318 stroker for his Wifes 68 Barracuda and its been 11.6ish IIRC here recently.
68 Barracuda Formula S 340
Re: Fastest 318 based motor on Moaprts? [Re: Bad340fish] #344622
06/12/09 07:47 PM
06/12/09 07:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
There is a guy on here I think his is poked and stroked to 438ish and runs mid elevens with factory iron heads, he has lots more in it but I think no cage. I think he is StrokerAspen.
He has I think, a 68 block bored to 4.030 and a 4.25 or so crank.
Re: Fastest 318 based motor on Moaprts? [Re: Streetwize] #344623
06/12/09 08:10 PM
06/12/09 08:10 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Mines got a 318. All stock bottom end. Block, rods, crank, oil pan. Its the original engine (bottom part). 360 heads from a junk yard car. Lapped the valves & bolted em on. MP oil pump & mild cam. Stock converter. Trannys seen some attention cause it died & I had my tranny guy build it right. I only turn it to 4500 cause of its 40 year old internals. Runs 8.90 to 9.00 in the 1/8 th. One of these days I'll drop a 440 or something in it. To darn busy working on other cars to mess with it. Besides it runs good & wins rounds.
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: Fastest 318 based motor on Moaprts? [Re: rockerbob] #344624
06/12/09 08:25 PM
06/12/09 08:25 PM
Petersburg, Va
Darrell Offline
Darrell  Offline
Petersburg, Va
I'll through mine out there, 2850 with me in it. 318 30 over, 360 heads, 8.2 cr with a 450 hydr. cam and tight convert.. Best 11.70@116.40. Been running it for 7 years now with no problems.
Re: Fastest 318 based motor on Moaprts? [Re: Darrell] #344625
06/12/09 10:21 PM
06/12/09 10:21 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Darell, may I ask what your 60 ft time is?
Re: Fastest 318 based motor on Moaprts? [Re: Darrell] #344626
06/12/09 10:24 PM
06/12/09 10:24 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
one of the bracket cars i sponsor had a stock stroke 318 last year that was running 6's in the 1/8mi. on real pump gas.
Re: Fastest 318 based motor on Moaprts? [Re: tjmarcus1] #344627
06/21/09 10:53 PM
06/21/09 10:53 PM
Weddington, N.C.
Weddington, N.C.
Got the short block together, looking good. I didn't like the way KB did the symmetrical intake Eyebrows on the slugs...the pocket left for a very thin relief on either side of the piston that would have surely broken a small piece of the slug in no time...I did a preemtive strike by whittling them down with the trusty dremel, small detail but something to be aware of with the standard bore size KB167's, the .030 overs would probably be thick enough.
What I've got is basically a 600+ hp bottom end that I'll be pushing to ~460 or so....but I figure I could always spray it
WIZE
In Car:
Re: Fastest 318 based motor on Moaprts? [Re: Streetwize] #344628
06/22/09 12:32 AM
06/22/09 12:32 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Not really what your looking for but my .030 over 318 is decent for the junk top end parts its got so far... Although it is boosted
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Fastest 318 based motor on Moaprts? [Re: topfueldart] #344629
06/26/09 05:32 PM
06/26/09 05:32 PM
Weddington, N.C.
Weddington, N.C.
I updated my Youtube Build log on the motor, you can view it here:
http://www.youtube.com/user/wizerulz
WIZE
In Car:
Re: Fastest 318 based motor on Moaprts? [Re: Streetwize] #344630
06/26/09 05:35 PM
06/26/09 05:35 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Several years ago there was a black Cuda that came to my local track running 5.90's with a 318 with W2's and a Lenco. Was one of the coolest cars I have ever seen.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
