Ultrabell or adapter plate for PG? #344487
06/11/09 10:49 PM
06/11/09 10:49 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
I am told the Ultrabell makes the pump leak no matter what since the pump bolts hold it in place, and they also vibrte loose. If I use the adapter plate, it may have to be trimmed down a lot for header clearance which is no big deal, but not crazy about having to cut the factory GM bellhousing to fit the starter, unless there is a starter I could use that would eliminate the . Both seem to have +'s and -'s, just looking for some opinions based on actual experience. The UB just seems to be a much cleaner approach, and I already have a case that is cut.
Re: Ultrabell or adapter plate for PG? [Re: Scamp451] #344488
06/11/09 10:55 PM
06/11/09 10:55 PM
PA
moparacer Offline
moparacer  Offline
PA
I just put a ultra bell/power glide behind a big block in a dart.
No leaks or problems what so ever.
I was going to use a ATI adapter plate but the starter location was right where the drag link was on my 68 Dart...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Ultrabell or adapter plate for PG? [Re: Scamp451] #344489
06/11/09 10:56 PM
06/11/09 10:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have done both...if you are gonna use a plate use an adapter version, mine is from TCI. That way you can run a GM tranny, read less money. The starter is an issue unless you either one cut the nose off a Mopar mini starter or run something like a Powermaster. I had a stock mini with no nose, it got dropped off my tool box so I had a Powermaster and installed it. The bells can leak and many do, but IMO it is from improper installation or not using orings to seal it. FWIW I have a removable Ultrabell on my glides.
Post deleted by Defbob [Re: Al_Alguire] #344490
06/11/09 10:58 PM
06/11/09 10:58 PM
Re: Ultrabell or adapter plate for PG? #344491
06/11/09 11:01 PM
06/11/09 11:01 PM
Chi-Town
PlumCrazyCharger Offline
Chi-Town
We have 3 PG with JW ultra bells and 1 with a Reid case. No problems with any of them. Fit great and no leaks ever.
Sean
Re: Ultrabell or adapter plate for PG? [Re: Scamp451] #344492
06/11/09 11:02 PM
06/11/09 11:02 PM
iowa
wesw Offline
wesw  Offline
iowa
i have a complete J.W. trans in my car. i have never had the bell housing come loose or the front pump leak. it's nine years old now. we just freshen the trans once a year. go with the ultra bell
598 ci predator
Re: Ultrabell or adapter plate for PG? [Re: Scamp451] #344493
06/11/09 11:04 PM
06/11/09 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a Ultrabell for my glide for my BB... I have
finished my engine so I havent used it yet
Re: Ultrabell or adapter plate for PG? [Re: MR_P_BODY] #344494
06/12/09 12:48 AM
06/12/09 12:48 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use a JW bell on my turbo 400. No problems or leaks here. As for a starter i use a autoparts store durango one.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ultrabell or adapter plate for PG? [Re: bigtimeauto] #344495
06/12/09 12:56 AM
06/12/09 12:56 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
i have used both with no problems, and have two brand new adapter kits with bolts and fly wheels, spacers, etc. all new 175.00 plus shipping or i would bring to a race. 615-573-2738
