Let's talk Fuel Injection. Which is best?
#342908
06/09/09 11:43 PM
06/09/09 11:43 PM
Posts: 571 Western NC
68Bullit
Western NC
Been looking on the affordable fuel injection site and been thinking about a FI conversion for the Charger. Just getting a little tired of tuning carbs, and all of the problems that carbs have while fuel injection is turn key and go. Not to mention rich idles and eyes watering, etc http://www.affordable-fuel-injection.com/store.php?crn=214Would this complete Mopar kit give me everything needed, or are there intake mods that need to take place? I have a Weiand Stealth dual plane on a mild 360. Would TBI be okay or is MPFI better? Thanks
Re: Let's talk Fuel Injection. Which is best?
[Re: Mr.Yuck]
#342911
06/10/09 09:52 AM
06/10/09 09:52 AM
68Bullit
Western NC
"Been looking on the affordable fuel injection" No such thing. For the cost of the EFI set up you could have a nice big block in the car. You think carbs are hard to set-up, try messing with the computer, bungs, sensors involved for EFI, not to mention the fab work...unless you buy a Mopar pre-fab kit and those are $$$$$$$.
What exactly needs to be done for fabrication? I thought that unit was already set up for bolt-on to a SB Mopar application.....
And how much do you think it would be, total cost? What would you pay for a "nice big block?"
[Re: 68Bullit]
#342914
06/10/09 10:13 AM
06/10/09 10:13 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I'd guess you'd have around $2500 into the system and that's if you can do most of the work yourself. Now if you want to go w/ an old school Holley Pro-jection that's abot $1200. You could sell your 360 and get into a nice big block for around 3k. It's not like you can just slap on t he injection rails, injectors and go. You have multipul sensors, electronics and a computer to install. I'd think if you want to go injected I'd grab a complete system off a 360 magnum and go form there.
[Re: Mr.Yuck]
#342915
06/10/09 12:08 PM
06/10/09 12:08 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
... Just getting a little tired of tuning carbs, and all of the problems that carbs have ...
So how does buying a new bigblock solve carburetor problems???
The Affordable kit is a GM ECU and TB. I'll speak in some generalities here: The 'standard' kit includes teh 305/350-sized TB, which is good for about 250 HP of airflow. The stock 454 TB and injectors (which they list for the 'over 360 kit') will be limited to maybe 300-325 hp based on the throttle body and injectors they use. They reprogam the chip to match the engine specs you give them. If you mod your engine too much, it may no longer perform as well. Sure, you could then adjust fuel pressure and put some specially-sized resistors on the sensors to trick the ECU, but personally I'd rather have one I could tune via a laptop.
As mentioned, Megasquirt (MS) is a good item for those that want to tune their own, or want near-infinite flexibility if they ever modify their engine down the road. MS (and probably the others, too) allow ECU 'learning' via wideband O2 sensor (that is above/beyond mere closed-loop corrections!). Try that with your carburetor! MS will allow you to control spark if you want, too – you could do fuel first and spark later (or vise versa).
Setting up the hardware, whether it be TBI or port EFI, depends on your budget, HP target and how much you are willing to do yourself. Low HP systems have lots more options (like the TBI or the Magnum beerbarrel) while higher HP gets more expensive (as usual).
68Bullit - I'm gonna PM you some info...
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Fury Fan]
#342916
06/10/09 12:21 PM
06/10/09 12:21 PM
Posts: 411 Texas
vynn3
Texas
That was my thought...?
vm
[Re: Fury Fan]
#342917
06/10/09 12:23 PM
06/10/09 12:23 PM
Mr.Yuck
Brookeville, Md
it doesn't but thinking you can just throw a EFi set-up together and start driving isn't logical. Plus all b-bodys should have big blocks.
[Re: Mr.Yuck]
#342918
06/10/09 12:56 PM
06/10/09 12:56 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
another vendor who seems to know what he's doing with the GM TBI/TPI system: http://customefis.com/he's modded GM computers to be able to use a flash chip, that allows for tuning on the fly, and doesn't require a chip burner.
[Re: patrick]
#342919
06/10/09 01:31 PM
06/10/09 01:31 PM
Posts: 2,255 IL
furious70
IL
In the process of tuning my FAST sequential system now on my Fury (Classic FAST, not XFI). I farmed out the intake conversion but did all the other work myself in my garage. It's very doable, but you need to devote some serious time to it. I have not had much chance to drive/tune the car (4 month old baby), but it's going to take some time to get it so I can do more than go around the block. Depending on where you live, you can pay to have tuning done of course. I bought my stuff used or very good deal new over several years and pulled some favors on the fab work. IMO it's much easier to get a carb working correctly, but I'm working towards other long range goals with mine.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Mr.Yuck]
#342920
06/10/09 01:43 PM
06/10/09 01:43 PM
Fury Fan
Indiana
x2 on the bigblock!
Yes, EFI will take a bit of tweaking, just like most any other bolt-on-part shakedown. Probably more tweaking, but tweaking can be far faster, and if done via laptop can be done any time you drive the car, without opening the hood.
One HUGE benefit I see to EFI, though, is that it is far faster and easier to make fueling/spark changes than with a carb. If you have the knowledge/experience to know what an engine needs, it is easier to modify the system than with a carb (if you're computer savvy, anyway). No rods, jets, air bleeds, choke adjustments, distributor curves – all are changed electronically (some of them while you drive!).
I have a wideband O2 gauge on one of my carbureted cars. I can tell where/when it is lean/rich, but even the smoothest tune is a compromise somewhere, either in MPG or HP or idle quality. It also loves more timing advance when cold, but fights against it when hot. I use an MSD Timing Computer with to handle that, but that’s a crude compromise, too. With EFI it's adjusted via intake air and coolant temp parameters.
Yes, it can be pretty straightforward to slap on a carb and get to work, but there's no learning or envelope-pushing involved there.
Parts I seek:
Send a PM.
[Re: 68Bullit]
#342921
06/10/09 01:46 PM
06/10/09 01:46 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
My web site has some generic EFI information and system comparisons about EFI systems. Check it out. www.fastmanefi.comI also have been selling the EZ-EFI system and I have some comments about how they are doing.
[Re: Jerry]
#342924
06/10/09 03:57 PM
06/10/09 03:57 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
in reality it would be cheaper to pay a competent carb tuner to tune what you have than it will be to install and tune an EFI setup.
Mega dittos to THIS !
And maybe get a carb that is as close to FI as you can get ... a Plastic Fantastic aka ThermoQuad !!
