Let's talk Fuel Injection. Which is best? #342908
06/09/09 11:43 PM
06/09/09 11:43 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Been looking on the affordable fuel injection site and been thinking about a FI conversion for the Charger. Just getting a little tired of tuning carbs, and all of the problems that carbs have while fuel injection is turn key and go. Not to mention rich idles and eyes watering, etc
http://www.affordable-fuel-injection.com/store.php?crn=214
Would this complete Mopar kit give me everything needed, or are there intake mods that need to take place? I have a Weiand Stealth dual plane on a mild 360. Would TBI be okay or is MPFI better? Thanks
Re: Let's talk Fuel Injection. Which is best? [Re: 68Bullit] #342909
06/10/09 08:38 AM
06/10/09 08:38 AM
Andrewh Online content
Andrewh  Online Content
I think it is a question of how much do you want to spend.
There is a pleathra of efi systems out there.
Megasquirt is a mostly diy system that could be done for under 1k or so.
There is a mustang 5.0 injection swap people have done for mopars for whatever the yard will let you have it for.
Don't know if edlebrock finally started making one for sb or not, but as I recall, that was well north of 2k.
MPI vs TBI will again depend on how much you have to spend. Most MPI are still batch fired regardless of what they say. As you move up the food chain, they become bank fired. Then the higher dollar ones eventually actually are port fired. But based on what I have seen, you are talking about 4k vs the 1.5 k you linked to.
Also for TBI, holley makes a commander or something like that for about 500 less than what you linked to.
You could also swap out to a magnum and use the computer stuff from a dodge truck. There are a couple threads on that already.
Or you could get the redrilled, or magnum heads and intake, if you are stuck with using your old block.
Re: Let's talk Fuel Injection. Which is best? [Re: 68Bullit] #342910
06/10/09 08:58 AM
06/10/09 08:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"Been looking on the affordable fuel injection" No such thing. For the cost of the EFI set up you could have a nice big block in the car. You think carbs are hard to set-up, try messing with the computer, bungs, sensors involved for EFI, not to mention the fab work...unless you buy a Mopar pre-fab kit and those are $$$$$$$.
Coming soon!!!!
Re: Let's talk Fuel Injection. Which is best? [Re: Mr.Yuck] #342911
06/10/09 09:52 AM
06/10/09 09:52 AM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
What exactly needs to be done for fabrication? I thought that unit was already set up for bolt-on to a SB Mopar application.....
And how much do you think it would be, total cost? What would you pay for a "nice big block?"
Re: Let's talk Fuel Injection. Which is best? [Re: 68Bullit] #342912
06/10/09 09:59 AM
06/10/09 09:59 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the efi kits are tricky and alot depends on what your looking for in terms of performance. the TBi kits are ok but really old technology. the MPFI kits are really the way to go these days. megasquirt is probably the cheapest way to go so you can scrounge parts but it requires a large DIY effort. you can put a kit together for under $1000 that will support 350 HP. obviously if you want more power then you need to pony up some more cash. the accel and fast efi kits are really nice and are as close as it comes to plug and play efi, however, you still need an MPFI intake and some fuel rails.
we can do manifold mods and fuel rails for you if your intersted.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Let's talk Fuel Injection. Which is best? [Re: 68Bullit] #342913
06/10/09 10:07 AM
06/10/09 10:07 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
The new EZ-EFI setup from FAST looks to be an easy and affordable TBI based system. System is self tuning so no laptop or tuning experience required. Complete system is under 2K but you would still need an FI fuel pump.
Re: Let's talk Fuel Injection. Which is best? [Re: 68Bullit] #342914
06/10/09 10:13 AM
06/10/09 10:13 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd guess you'd have around $2500 into the system and that's if you can do most of the work yourself. Now if you want to go w/ an old school Holley Pro-jection that's abot $1200. You could sell your 360 and get into a nice big block for around 3k. It's not like you can just slap on t he injection rails, injectors and go. You have multipul sensors, electronics and a computer to install. I'd think if you want to go injected I'd grab a complete system off a 360 magnum and go form there.
Coming soon!!!!
Re: Let's talk Fuel Injection. Which is best? [Re: Mr.Yuck] #342915
06/10/09 12:08 PM
06/10/09 12:08 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
... Just getting a little tired of tuning carbs, and all of the problems that carbs have ...
So how does buying a new bigblock solve carburetor problems???
The Affordable kit is a GM ECU and TB. I'll speak in some generalities here:
The 'standard' kit includes teh 305/350-sized TB, which is good for about 250 HP of airflow. The stock 454 TB and injectors (which they list for the 'over 360 kit') will be limited to maybe 300-325 hp based on the throttle body and injectors they use. They reprogam the chip to match the engine specs you give them. If you mod your engine too much, it may no longer perform as well. Sure, you could then adjust fuel pressure and put some specially-sized resistors on the sensors to trick the ECU, but personally I'd rather have one I could tune via a laptop.
As mentioned, Megasquirt (MS) is a good item for those that want to tune their own, or want near-infinite flexibility if they ever modify their engine down the road. MS (and probably the others, too) allow ECU 'learning' via wideband O2 sensor (that is above/beyond mere closed-loop corrections!). Try that with your carburetor! MS will allow you to control spark if you want, too – you could do fuel first and spark later (or vise versa).
Setting up the hardware, whether it be TBI or port EFI, depends on your budget, HP target and how much you are willing to do yourself. Low HP systems have lots more options (like the TBI or the Magnum beerbarrel) while higher HP gets more expensive (as usual).
68Bullit - I'm gonna PM you some info...
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Let's talk Fuel Injection. Which is best? [Re: Fury Fan] #342916
06/10/09 12:21 PM
06/10/09 12:21 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
That was my thought...?
vm
Re: Let's talk Fuel Injection. Which is best? [Re: Fury Fan] #342917
06/10/09 12:23 PM
06/10/09 12:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
it doesn't but thinking you can just throw a EFi set-up together and start driving isn't logical. Plus all b-bodys should have big blocks.
Coming soon!!!!
Re: Let's talk Fuel Injection. Which is best? [Re: Mr.Yuck] #342918
06/10/09 12:56 PM
06/10/09 12:56 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
another vendor who seems to know what he's doing with the GM TBI/TPI system:
http://customefis.com/
he's modded GM computers to be able to use a flash chip, that allows for tuning on the fly, and doesn't require a chip burner.
2017 Grand Cherokee Overland
Re: Let's talk Fuel Injection. Which is best? [Re: patrick] #342919
06/10/09 01:31 PM
06/10/09 01:31 PM
IL
furious70 Offline
furious70  Offline
IL
In the process of tuning my FAST sequential system now on my Fury (Classic FAST, not XFI). I farmed out the intake conversion but did all the other work myself in my garage. It's very doable, but you need to devote some serious time to it. I have not had much chance to drive/tune the car (4 month old baby), but it's going to take some time to get it so I can do more than go around the block. Depending on where you live, you can pay to have tuning done of course.
I bought my stuff used or very good deal new over several years and pulled some favors on the fab work.
IMO it's much easier to get a carb working correctly, but I'm working towards other long range goals with mine.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Let's talk Fuel Injection. Which is best? [Re: Mr.Yuck] #342920
06/10/09 01:43 PM
06/10/09 01:43 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
x2 on the bigblock!
Yes, EFI will take a bit of tweaking, just like most any other bolt-on-part shakedown. Probably more tweaking, but tweaking can be far faster, and if done via laptop can be done any time you drive the car, without opening the hood.
One HUGE benefit I see to EFI, though, is that it is far faster and easier to make fueling/spark changes than with a carb. If you have the knowledge/experience to know what an engine needs, it is easier to modify the system than with a carb (if you're computer savvy, anyway). No rods, jets, air bleeds, choke adjustments, distributor curves – all are changed electronically (some of them while you drive!).
I have a wideband O2 gauge on one of my carbureted cars. I can tell where/when it is lean/rich, but even the smoothest tune is a compromise somewhere, either in MPG or HP or idle quality. It also loves more timing advance when cold, but fights against it when hot. I use an MSD Timing Computer with to handle that, but that’s a crude compromise, too. With EFI it's adjusted via intake air and coolant temp parameters.
Yes, it can be pretty straightforward to slap on a carb and get to work, but there's no learning or envelope-pushing involved there.
Re: Let's talk Fuel Injection. Which is best? [Re: 68Bullit] #342921
06/10/09 01:46 PM
06/10/09 01:46 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
My web site has some generic EFI information and system comparisons about EFI systems. Check it out.
www.fastmanefi.com
I also have been selling the EZ-EFI system and I have some comments about how they are doing.
Re: Let's talk Fuel Injection. Which is best? [Re: 68Bullit] #342922
06/10/09 03:30 PM
06/10/09 03:30 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Most of the complaints you have about a carb are from the lack of catalytic convertors and old school cam overlap.
I'm sold on fuel injection too but do not do it for the reasons you stated.
Re: Let's talk Fuel Injection. Which is best? [Re: 68Bullit] #342923
06/10/09 03:53 PM
06/10/09 03:53 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
in reality it would be cheaper to pay a competent carb tuner to tune what you have than it will be to install and tune an EFI setup.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Let's talk Fuel Injection. Which is best? [Re: Jerry] #342924
06/10/09 03:57 PM
06/10/09 03:57 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Mega dittos to THIS !
And maybe get a carb that is as close to FI as you can get ... a Plastic Fantastic aka ThermoQuad !!
Re: Let's talk Fuel Injection. Which is best? [Re: Jerry] #342925
06/10/09 04:10 PM
06/10/09 04:10 PM
IL
furious70 Offline
furious70  Offline
IL
x3.
If the goal is to just get it running right. EFI can be a fun project, but extends far beyond 'getting it running right'
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Let's talk Fuel Injection. Which is best? [Re: furious70] #342926
06/10/09 04:27 PM
06/10/09 04:27 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Agreed. But where to find this 'competent' person? Not at a local garage these days - so it's specialty shops only. And they need to be within driving distance, because they really ought to have the car to tune it on...
Re: Let's talk Fuel Injection. Which is best? [Re: Fury Fan] #342927
06/10/09 04:36 PM
06/10/09 04:36 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
you need to fine a dyno shop in your town. most places that have dynos have techs that can tune the cars whether it be efi or carb. ultimately efi is great for daily drivability, cold starting, weather changes, etc. but if your tuning a weekend cruiser or your street strip car and trying to get out of it by going to efi then its definitely going to be an even bigger headache than a carb. there are alot of adjustments with efi, granted they can be tuned with a laptop but if one number is off it can throw off your whole curve.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
