Page 3 of 13 1 2 3 4 5 12 13
Re: VIN Stamping: MYTH or FACT [Re: west] #342457
06/09/09 11:44 PM
06/09/09 11:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
well at least they can use this thread to correct thier mistakes for the next attempt.
You know the ol' Motto,.....practice makes perfect!......or a Premimum Stamp set,...is preferred
Re: VIN Stamping: MYTH or FACT [Re: DAYCLONA] #342458
06/09/09 11:54 PM
06/09/09 11:54 PM
Twin Cities, MN
MN-ScatPack Offline
MN-ScatPack  Offline
Twin Cities, MN
MAN, OK, OK, you have a nice PREMIUM stamp set. We GET IT!
Sheez.
Re: VIN Stamping: MYTH or FACT [Re: anlauto] #342459
06/10/09 01:41 AM
06/10/09 01:41 AM
Is this the matching block? It was removed from the car while under warranty?
The fonts are wrong as compared to those used by the factory. The lettering is also slanted to the right about 15 degrees. With the type of stamping jig used on the assembly line, that would have been impossible.
Re: VIN Stamping: MYTH or FACT [Re: west] #342460
06/10/09 01:55 AM
06/10/09 01:55 AM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
I worked at a Plymouth dealer during HS in 77 to early 79 and I remember getting long blocks in with a riveted tag on them to ID them as warranty replacements. I do know they had a stamp set and they would stamp the pad with the VIN number. I also saw them stamp the month and year on the top pad to denote the install date. Was this required..I dont know I just know the tech we had did it. The engines I remember working with were all police Furys so maybe it was something the city wanted done. I never recall getting just a block in they were always long blocks and the claim engine would be shipped back if requested or just sent to the dump if it wasnt. Since these engines were a dime a dozen then no one messed with them.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: VIN Stamping: MYTH or FACT [Re: 70dart360] #342461
06/10/09 07:59 AM
06/10/09 07:59 AM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
So should they be a closer match?
Why would someone bother to go through the trouble? It's not like I was overly advertising looking for the original block
....I sent this question to a good friend and his answer made the most sense.
He says it depends on the asking price....
If it's $500 it's NO SCAM
if it's $5000 it's a SCAM
I got an email last night....the asking price for the bare block is $2500
CHECK OUT MY NEW WEB SITE !
Re: VIN Stamping: MYTH or FACT #342462
06/10/09 08:18 AM
06/10/09 08:18 AM
Flint, MI
Gusteve Offline
I Love the Unicorn Song!!
Gusteve  Offline
Flint, MI
That's what I was thinking. You could have a vertically mis-aligned digit, but not the entire VIN slanted like that if they were using a jig of some kind. And the fact that the pad is deeper than usual supports the argument that it was shaved.
Not to mention, it would be safe to assume that there would be a boatload of cars around with VIN #'s with the same slant as the VIN on that block, and I don't recall ever seeing one like that. Its highly unlikely that the line worker stamped that single VIN and went "Oh - its crooked, I better fix the jig" before he did the next car.
Re: VIN Stamping: MYTH or FACT**PICTURE UPDATE** [Re: anlauto] #342463
06/10/09 08:30 AM
06/10/09 08:30 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Here is my take on it...its a restamp. Why, whell, the stamping of the blocks and engines were done by a machine that had wheels where you set the number/letter combination. So you would set 0B12345 and stamp the engine and transmission. Then set to 0B12346 and do the next (assuming sequential VIN for this argument sake). So if the person setting the wheels dropped the third digit slightly (say the "1" was a little lower, then the same error would be in both places. Also, since the wheels were in a line, all the letters should be lined up. Thes are all over the place. I have seen the whole stampings crooked, but the relative spacing and alignment is always the same. This is also why you see transposed numbers show up in both places usually. Lastly, the font is off. I am no expert, but have seen a few VIN stampings, and know that that font is not right. Just my
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: VIN Stamping: MYTH or FACT [Re: DAYCLONA] #342464
06/10/09 08:39 AM
06/10/09 08:39 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
i seen a few 4 spds stamped,and then restamped, the same number,but kinda over the original one.
....Yep I done that before,....I mean, seen that before
Yes Mike after a few beers you have a steadier hand to hold the stamp still while striking it.
logan426
Re: VIN Stamping: MYTH or FACT [Re: MLR426] #342465
06/10/09 10:11 AM
06/10/09 10:11 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
dealerships' were suppose to stamp the VIN on the warranty motors.
I've never seen a shred of evidence to support that story. If anyone has any I'd love to see it (Factory Bulletins, Memo's etc.). It's possible that some dealership owners had internally unique procedures to track engine warranty work but nothing from the factory I've ever seen proof of.
This is printed in the front of every factory parts book.
IMPORTANT:
Parts Division replacement engines are supplied with blank engine number bosses only. Dealers are governed by state law on the application of engine numbers. In states where license fees are based on displacement or taxable horsepower, it will be necessary to change vehicle registration if the new replacement engine differs from the one it replaces.
Re: VIN Stamping: MYTH or FACT [Re: imfixinmopars426] #342466
06/10/09 10:17 AM
06/10/09 10:17 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
i seen a few 4 spds stamped,and then restamped, the same number,but kinda over the original one. like i said before,they didnt make these cars for us to restore 40 yrs later,so there is human error.
I have seen many 4-spds that have been double stamped by the factory, here is the #'s trans to my '71 GTX.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: VIN Stamping: MYTH or FACT [Re: Snoopy] #342467
06/10/09 10:22 AM
06/10/09 10:22 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Right Snoopy, I've seen that, but it's as clear as mud as to exactly what it means. Where does it say (specifically)that dealers are required to add the VIN sequence number to the block?
Re: VIN Stamping: MYTH or FACT [Re: Snoopy] #342468
06/10/09 10:26 AM
06/10/09 10:26 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I agree "restamped", now you can out the yo-yo trying to pass this off as legit. The pad will be a little bit deeper with another VIN next time it surfaces, maybe it'll match my car. NOT!!
Re: VIN Stamping: MYTH or FACT [Re: Snoopy] #342469
06/10/09 10:26 AM
06/10/09 10:26 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
IMPORTANT:
That edict is like the label on your pillow.
MB
Re: VIN Stamping: MYTH or FACT [Re: 70440+6bbl] #342470
06/10/09 10:37 AM
06/10/09 10:37 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
That's quite common, actually. Another that I see is transposed numerals. The VIN is, let's say, 123456 and you see 132456.
MB
Re: VIN Stamping: MYTH or FACT [Re: BulletBob] #342471
06/10/09 10:42 AM
06/10/09 10:42 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Numbers matching is numbers matching. I have yet to see any numbers out of place or crooked that were correct.
Mike, I agree, quite common... It was more of a response to the quote above
The fender tags were also placed backwards
Re: VIN Stamping: MYTH or FACT [Re: 70440+6bbl] #342472
06/10/09 10:46 AM
06/10/09 10:46 AM
I think you have your answer then, don't you?
The rationale of the guy selling is that a few "correct" numbers make a $250.00 block worth 10 times that.
Re: VIN Stamping: MYTH or FACT [Re: anlauto] #342473
06/10/09 10:50 AM
06/10/09 10:50 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
SCAM , I got the ORIGINAL UNDAMAGED block to my bee back from the guy that pulled it ... 25 bucks
Re: VIN Stamping: MYTH or FACT [Re: stumpy] #342474
06/10/09 11:20 AM
06/10/09 11:20 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
When I worked in the dealership back in the 70s the factory warrenty rep would smack the block with a hammer to damage it so it couldn't be reused and then it got scrapped. They were never reused.
That's what was supposed to happen.
Re: VIN Stamping: MYTH or FACT [Re: DAYCLONA] #342475
06/10/09 11:20 AM
06/10/09 11:20 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
So where are teh 'fender tag police' to keep this information from being posted on a public webboards???
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: VIN Stamping: MYTH or FACT [Re: ph23vo] #342476
06/10/09 12:04 PM
06/10/09 12:04 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
also notice the PAD is twice as deep as most you see... indicating its been shaved..also the font is way way off as the spacing off the trans stamp would be the same so yes this is a FRAUD dan
And there are no remnants of the original Bridgeport milling machine marks with which all pads were milled whether they were stamped at the factory or unstamped warranty replacements.
