Challenger What's This Hole For? #342149
06/09/09 12:36 PM
06/09/09 12:36 PM
cataclysm80 Offline OP
I'm test fitting stuff on my 70 Challenger and was wondering what's this hole for? It's in the windshield channel on the bottom. There's one on each side of the car. They appear to get covered by the windshield spacing blocks. Is it just for drainage? Hole is marked with RED arrow in pics.
Tav
Re: Challenger What's This Hole For? [Re: cataclysm80] #342150
06/09/09 12:39 PM
06/09/09 12:39 PM
another pic with the windshield spacing block...
Re: Challenger What's This Hole For? [Re: cataclysm80] #342151
06/09/09 12:41 PM
06/09/09 12:41 PM
With the windshield spacing block in its proper location (hole under block not visible, but marked with arrow)
Tav
Re: Challenger What's This Hole For? [Re: cataclysm80] #342152
06/09/09 12:46 PM
06/09/09 12:46 PM
While I'm at it, What's this hole in the door for? (marked with RED arrow in pic) It's on each door.
Tav
Re: Challenger What's This Hole For? [Re: cataclysm80] #342153
06/09/09 01:11 PM
06/09/09 01:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I thought I saw a picture recently reguarding the hole in the door. I think there is an adjustment of the door latch or maybe the window track that you access with an allen wrench through the hole. I could be way off on that one...I just remember seeing something like that recently. Maybe I was dreaming.
Re: Challenger What's This Hole For? [Re: burdar] #342154
06/10/09 01:07 PM
06/10/09 01:07 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes just looked with a flashlight there is an allen head bolt that's accessed thru this hole. What it does I have no clue.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Challenger What's This Hole For? [Re: HemiRick] #342155
06/10/09 03:11 PM
06/10/09 03:11 PM
WI
RestoRick Offline
RestoRick  Offline
WI
It adjusts how quickly the outside door handle starts to activate the mechanism.
Windshield lower pinchweld hole- probably for
the metal style glass "stand", like used under the backlite. That's my best guess anyway..
Rick
Re: Challenger What's This Hole For? [Re: RestoRick] #342156
06/10/09 03:57 PM
06/10/09 03:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Is that hole in the door just a 70 thing or is it present in all years? I know the 70 has a slightly different design than the other years as far as outward apperence anyway.
Re: Challenger What's This Hole For? [Re: burdar] #342157
06/10/09 05:05 PM
06/10/09 05:05 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Oh Man!! I was sweating bullets there for a minute. I had no knowledge of the windshield spacer blocks. I removed the windshield a while back but have not cleaned up that area yet. I didn't recall seeing them but just went out and saw them. Glad I saw this before the car got blasted.
Joe
65 Barracuda
70 Challenger
Re: Challenger What's This Hole For? [Re: burdar] #342158
06/10/09 08:16 PM
06/10/09 08:16 PM
The door in that picture is not a 70 door. I think it's off a 71 or maybe 72. My drivers side door is a 70 door. both doors have the hole.
Should the hole be filled with a plug or something?
Tav
Re: Challenger What's This Hole For? [Re: jrwoodjoe] #342159
06/10/09 08:19 PM
06/10/09 08:19 PM
Joe
My rear window had the metal type spacers, and it also had rubber blocks on the sides and on the top. I still have them. I've also seen rear windows installed without them during restoration without a problem
Tav
Re: Challenger What's This Hole For? [Re: cataclysm80] #342160
06/10/09 09:37 PM
06/10/09 09:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I don't ever remember seeing any kind of spacer blocks on my 73. It is a vynal top car though. Does that make a difference?
Re: Challenger What's This Hole For? [Re: burdar] #342161
06/10/09 10:05 PM
06/10/09 10:05 PM
California
sixpaktoogo Offline
sixpaktoogo  Offline
California
My 70 Challenger convertible has three or four holes in the same area that look to have been made from the underside with some sort of metal punch or awl. The punch, or what ever was used, looks to have been tapered to a point, making the metal stick up. I believe this was done to hold the windshield blocks in place? Both my 70 Cudas have the same thing as well.
Re: Challenger What's This Hole For? [Re: cataclysm80] #342162
03/10/12 11:26 PM
03/10/12 11:26 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Tav
That would be bad since 1970 doors are unique. The cat whiskers use clips in 70, screws in 71 and up.
Re: Challenger What's This Hole For? [Re: sixpaktoogo] #342163
03/11/12 12:00 PM
03/11/12 12:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The hole is in the door is as suggested, for door latch release adjustment. It's in all doors regradless of application or year. Use a 3/16" allen wrnech to adjust. There was no plug in it
hole in the lower windshield frame , no idea
Re: Challenger What's This Hole For? [Re: Morty426] #342164
03/26/12 01:09 AM
03/26/12 01:09 AM
Good Point, Thanks. I figured that out during all of my test fitting, and solved the problem by making a template off the drivers door and using it, along with a drill bit & dremel tool, to make the oval holes in the passenger door for the 1970 style clips. Followed up with a test fit of the new cat whiskers. Now the car will accept a full 1970 set as it should. It took a little while, but still faster, cheaper, and easier than finding a different door.
Tav
