What shocks to use with SS springs on A-body? #341823
06/08/09 11:15 PM
06/08/09 11:15 PM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
I have a 74 Duster and I have SS springs on the rear and had to add a 3" lowering block to each side of the axle to get the ride height back to somewhat normal, but my shocks seem too short. Is this possible, and if so what shock should I run on the rear axle and what brand do you recommend?
Gary
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: What shocks to use with SS springs on A-body? [Re: twister360] #341824
06/09/09 03:26 AM
06/09/09 03:26 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Yes you need longer shocks, I use Rancho shocks which are 9 way adjustable from Calvert. Mopar performance also sells a good set which are priced less but not adjustable, I hear the ones for a stick car work better. Good luck.
Re: What shocks to use with SS springs on A-body? [Re: 68Fastback] #341825
06/09/09 09:11 AM
06/09/09 09:11 AM
Houma, Louisiana
Houma, Louisiana
Do you know what KYB shock would work on the rear and is KYB a good shock? Thanks
Re: What shocks to use with SS springs on A-body? [Re: twister360] #341826
06/09/09 10:56 AM
06/09/09 10:56 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I'm using the kyb's, i like them, i have ss springs but the car sits fine without lowering blocks
Re: What shocks to use with SS springs on A-body? [Re: ademon] #341827
06/09/09 11:03 AM
06/09/09 11:03 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
For a stock shock the application for SS springs is C-body Imperial rears or '60s-era D100 pickup fronts.
SS springs require a longer shock because they allow a lot more body separation (more vertical travel).
I would think that much of a block between the springs and axle would cancel the anti-wind-up ability of the springs.
Re: What shocks to use with SS springs on A-body? [Re: ademon] #341828
06/09/09 11:47 AM
06/09/09 11:47 AM
Houma, Louisiana
Houma, Louisiana
What type of car do you have the KYB's mounted on? I installed the SS springs on my Duster ane the rear end was way up in the air, so i added the lowering blocks and the ride height is about normal. Thanks
Re: What shocks to use with SS springs on A-body? [Re: topside] #341829
06/09/09 04:10 PM
06/09/09 04:10 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I also would lose the blocks. For proper ride height find a local spring shop to dearch your leaf spring assemblies.
The passenger side will have more arch than the driver's side. This difference should be left in there for a drag car.
If you don't like the lean, either compensate with the front torsion bar settings or tell the spring shop the left to right difference and have them dearch accordingly.
Re: What shocks to use with SS springs on A-body? [Re: Magnum] #341830
06/09/09 04:46 PM
06/09/09 04:46 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
ive tried 3 different shocks.
MP drag shocks
CE 3-way shocks
00' Dodge ram 3/4 ton shocks.
all sit about the same.
all had the same 60' time at the track.
Re: What shocks to use with SS springs on A-body? [Re: 493_DART] #341831
06/09/09 08:02 PM
06/09/09 08:02 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
What year Imperial? I need new rear shocks for my 68 Barracuda and Im running the 2800's
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: What shocks to use with SS springs on A-body? [Re: 69L78Nova] #341832
06/09/09 10:31 PM
06/09/09 10:31 PM
A collage of whims
A collage of whims
IIRC, mid-late '60s Imperial. The extended length is the big deal. You can measure the length you need by supporting your chassis, removing your shocks and letting the rear axle droop. Measure eye to eye and check what the parts counter guy hands you; they should extend past your max measurement but not bottom out at the minimum measurement. A/T cars will generally prefer a softer shock than stick cars for drag racing, so you might even want to go hit the junkyard with a 3/4" socket & ratchet and wrench.
Re: What shocks to use with SS springs on A-body? [Re: twister360] #341833
06/10/09 02:07 AM
06/10/09 02:07 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
71 demon
