Indy legend Tunnel ram on Stage V Hemi heads???? #341531
06/08/09 05:23 PM
06/08/09 05:23 PM
Rancho Cucamonga, Calif.
P
PUNK Offline OP
PUNK  Offline OP
P
Does it fit? I hope so, or else it means that we will have to have a sheet metal manifold built. Thats not what we are after. We will if we have to though. The indy piece looks good from the pictures that ive seen.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Post deleted by Defbob [Re: PUNK] #341532
06/08/09 05:25 PM
06/08/09 05:25 PM
Re: Indy legend Tunnel ram on Stage V Hemi heads???? #341533
06/08/09 06:47 PM
06/08/09 06:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
best used with a spacer as the plenum is too small
Mine is set-up to use efi, and I built a spacer to help with air flow to even out the cylinders. As far as fitting Stage V heads, dunno.
Re: Indy legend Tunnel ram on Stage V Hemi heads???? [Re: PUNK] #341534
06/08/09 07:10 PM
06/08/09 07:10 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
It'll bolt right on with the usual Hemi issues of clearance in the valley plate area, and required port matching.
Post deleted by Defbob [Re: Mopar_Rich] #341535
06/08/09 07:33 PM
06/08/09 07:33 PM
Re: Indy legend Tunnel ram on Stage V Hemi heads???? #341536
06/08/09 07:46 PM
06/08/09 07:46 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
THat works!
Re: Indy legend Tunnel ram on Stage V Hemi heads???? [Re: Mopar_Rich] #341537
06/08/09 10:45 PM
06/08/09 10:45 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
It will fit unless you have Stage V Millenium heads.In that case you will need to use spacers.
Re: Indy legend Tunnel ram on Stage V Hemi heads???? [Re: PUNK] #341538
06/08/09 10:53 PM
06/08/09 10:53 PM
P
PUNK Offline OP
PUNK  Offline OP
P
Thanks guys, glad to know that it will fit and also glad to know about the plenum volume issue. That is easily fixable. Building a 572" with Raised Port Stage V Heads. Not the milleniums. Should be fun.
Re: Indy legend Tunnel ram on Stage V Hemi heads???? [Re: PUNK] #341539
06/11/09 06:29 AM
06/11/09 06:29 AM
pa
572charger Offline
572charger  Offline
pa
mine fits now !!! after about 5 hrs of porting i made my indy tunnel ram fit and match up perfect to my stage V heads !!!! its for sale
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
