Indy legend Tunnel ram on Stage V Hemi heads????
#341531
06/08/09 05:23 PM
06/08/09 05:23 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Does it fit? I hope so, or else it means that we will have to have a sheet metal manifold built. Thats not what we are after. We will if we have to though. The indy piece looks good from the pictures that ive seen.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
Post deleted by Defbob
[Re: PUNK]
#341532
06/08/09 05:25 PM
06/08/09 05:25 PM
Re: Indy legend Tunnel ram on Stage V Hemi heads????
#341533
06/08/09 06:47 PM
06/08/09 06:47 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
best used with a spacer as the plenum is too small
![](/ubbthreads/images/graemlins/iagree.gif) Mine is set-up to use efi, and I built a spacer to help with air flow to even out the cylinders. As far as fitting Stage V heads, dunno.
![](http://i427.photobucket.com/albums/pp357/cudahalr/70HemiCuda/hemi967-1.jpg)
[Re: Mopar_Rich]
#341535
06/08/09 07:33 PM
06/08/09 07:33 PM
[Re: PUNK]
#341538
06/08/09 10:53 PM
06/08/09 10:53 PM
PUNK
Thanks guys, glad to know that it will fit and also glad to know about the plenum volume issue. That is easily fixable. Building a 572" with Raised Port Stage V Heads. Not the milleniums. Should be fun.
