race/pump gas mix
#340517
06/07/09 12:14 PM
06/07/09 12:14 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
since i will be driving the scamp on the street this year, i need suggestions and or advice as to what i can get away with on the street, motor combo is stroker smallblock, eddy heads, roller cam667 in/675ex 264/270 dur 107cl, comp springs 260lbs compression is 13/1.......i usually run VP C-12, i want to mix with 93 octane any suggestions, the car will only see prox 15 min drives, thanks mike
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: race/pump gas mix
[Re: Stroker Scamp]
#340518
06/07/09 03:27 PM
06/07/09 03:27 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I run 5 gallons 110 to like 10 of 93.My 12.5 440 likes it on the street.Rocky
Chrysler Firepower
[Re: Quicksilver440]
#340521
06/08/09 02:28 PM
06/08/09 02:28 PM
Posts: 99 Tuscaloosa, Alabama
speedfreak440
Tuscaloosa, Alabama
I thought Torco went out of business?
Nope, TORCO is still in business just did a little reorganizing & thank goodness cause this stuff is perfect for us boosted/sprayed street-car guys. I was a little off on my mixture earlier though 32oz will bring 10 gal of premium up 11 points, 64oz will bring it up 14 points. I suggest buying the 6-pack of 32oz cans & when you use that up start buying it in 5gal cans & use that to refill your 32oz cans. I always keep one in the trunk just in case.
[Re: speedfreak440]
#340522
06/09/09 12:53 AM
06/09/09 12:53 AM
Stroker Scamp
pacific northwest
thanks for the info, ill check into the torco stuff, just might be a trial and error thing i guess
