race/pump gas mix #340517
06/07/09 12:14 PM
06/07/09 12:14 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
since i will be driving the scamp on the street this year, i need suggestions and or advice as to what i can get away with on the street, motor combo is stroker smallblock, eddy heads, roller cam667 in/675ex 264/270 dur 107cl, comp springs 260lbs compression is 13/1.......i usually run VP C-12, i want to mix with 93 octane any suggestions, the car will only see prox 15 min drives, thanks mike
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: race/pump gas mix [Re: Stroker Scamp] #340518
06/07/09 03:27 PM
06/07/09 03:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run 5 gallons 110 to like 10 of 93.My 12.5 440 likes it on the street.Rocky
Chrysler Firepower
Re: race/pump gas mix [Re: therocks] #340519
06/08/09 08:48 AM
06/08/09 08:48 AM
Tuscaloosa, Alabama
speedfreak440 Offline
Tuscaloosa, Alabama
Have you ever tried TORCO Accelerator? It is a REAL octane booster not to be confused with the other crap sold through Autozone & such.
1 32oz can mixed with about 10 gal of 93 will produce somewhere around 98-99 octane, 2 32oz cans with 10 gal will produce around 104-105. I have personally used this stuff (I buy it in the 5 gal buckets) & it really works well for a street car. I had an 03 cobra with a kenne bell pushing 17psi tuned for 93, but I also had a 90 shot of spray & I would use this stuff for the spray, never had a single problem. Alot of other guys use it as well with great success.
Re: race/pump gas mix [Re: speedfreak440] #340520
06/08/09 12:08 PM
06/08/09 12:08 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I thought Torco went out of business?
Re: race/pump gas mix [Re: Quicksilver440] #340521
06/08/09 02:28 PM
06/08/09 02:28 PM
Tuscaloosa, Alabama
Tuscaloosa, Alabama
Nope, TORCO is still in business just did a little reorganizing & thank goodness cause this stuff is perfect for us boosted/sprayed street-car guys. I was a little off on my mixture earlier though 32oz will bring 10 gal of premium up 11 points, 64oz will bring it up 14 points. I suggest buying the 6-pack of 32oz cans & when you use that up start buying it in 5gal cans & use that to refill your 32oz cans. I always keep one in the trunk just in case.
Re: race/pump gas mix [Re: speedfreak440] #340522
06/09/09 12:53 AM
06/09/09 12:53 AM
pacific northwest
pacific northwest
thanks for the info, ill check into the torco stuff, just might be a trial and error thing i guess
