Page 1 of 3 1 2 3
Part # for '71 e-body turn sig. switch? #338534
06/05/09 09:06 AM
06/05/09 09:06 AM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
Can't seem to find anything here:
http://www.mymopar.com/index.php?pid=99
Would one from an like-year a-body work?
Re: Part # for '71 e-body turn sig. switch? [Re: 2fast4yourBrain] #338535
06/05/09 10:05 AM
06/05/09 10:05 AM
New Jersey Bada Bing
bremotorsports Offline
Original number is 3488477.
Most likely 3488478 on the tag.
Superceded by 3488805.
Bill Rolik
Re: Part # for '71 e-body turn sig. switch? [Re: bremotorsports] #338536
06/05/09 01:41 PM
06/05/09 01:41 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
wondering if the RIGHT unit with thin hazzard knob and turning on by push in instead pull out like laters is available. I have found the new pieces made are the later kind, and nothing like the 70/ first half 71 kind
Re: Part # for '71 e-body turn sig. switch? [Re: bremotorsports] #338537
06/05/09 01:46 PM
06/05/09 01:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Bill Rolik
This PN is with cornering lights and is the later kind... won't fit correctly on push in hazzard kind setup what as far I know is 70 and firts 71 half... just by the thick of hazzard knob. maybe trimming will fit and of course would get the reveresed ON operation
without cornering light, ends on 04 on PN
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338538
06/05/09 02:04 PM
06/05/09 02:04 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
note the right one on MOST earliers setup ( it does appear diff PN on box ):
this is still pull out ON function
maybe the 3488477 PN is with the push in ON function
here is the later one with cornering lights with 3488805 PN
note the diff on hazzard knob
this is the new one available ( non Mopar )... note the horn switch is not anymore a roller to roll againts the horn track on wheel/adapter, now is really simply a brass stud. Later hazzard button kind
New Mopar part, with cornering light ( new 3488805 piece made ) is with same horn switch kind than the one above( not anymore a roller )
everyone without tilt wheel
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338539
06/05/09 07:14 PM
06/05/09 07:14 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
On e-bodies, I never heard of pushing IN to get the Hazards to work?!?!?!
BTW, what do you mean by "cornering lights"???
ALso, on the new ones, what's the extra wiring harness for?
Re: Part # for '71 e-body turn sig. switch? [Re: 2fast4yourBrain] #338540
06/05/09 07:40 PM
06/05/09 07:40 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the extra harness is for the cornering lights. is an extra lightning for C bodies, not used on the rest of assemblies.
70 and firts 71s Chargers used push in Hazzards I thoght Cudas/Challyes were the same since they shared LOT of parts
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338541
06/05/09 09:10 PM
06/05/09 09:10 PM
Bill Rolik
Correct. The SUPERCEDED switch for 70 cars is 3488804.
Bill Rolik
Re: Part # for '71 e-body turn sig. switch? [Re: bremotorsports] #338542
06/08/09 10:21 AM
06/08/09 10:21 AM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Bill Rolik
Bill Rolik
For 1971 cars, 3488805 will work?!?!?
Re: Part # for '71 e-body turn sig. switch? [Re: 2fast4yourBrain] #338543
06/08/09 01:45 PM
06/08/09 01:45 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the diff between 04 and 05 is just the extra harness to cornering lamps.
now, would need to confirm the knob size.
this pictured one
is supposelly correct for 70 and maybe 71s ? Maybe first 71 half ? on ebay it was on $500
knob is diff thick
Re: Part # for '71 e-body turn sig. switch? [Re: NachoRT74] #338544
06/08/09 02:46 PM
06/08/09 02:46 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Here are few pictures of a 3488477 1971 turn signal switch that was used on all non-tilt steering wheel Chrysler cars.
Notice that it has the cornering lights harness. This was taped out of the way on cars that did not have cornering lights.
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338545
06/08/09 02:48 PM
06/08/09 02:48 PM
Snoopy Offline
Snoopy  Offline
Flasher knob.
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338546
06/08/09 02:49 PM
06/08/09 02:49 PM
Snoopy Offline
Snoopy  Offline
Box
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338547
06/08/09 03:37 PM
06/08/09 03:37 PM
Snoopy Offline
Snoopy  Offline
3488804-5
Hazard Knob
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338548
06/08/09 03:38 PM
06/08/09 03:38 PM
Snoopy Offline
Snoopy  Offline
3488805 Turn Signal Switch
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338549
06/08/09 03:41 PM
06/08/09 03:41 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
amazing all the diff info and kind of switches, but basically the same
3488805 the same than 3488477, however newer pieces are without roller on horn switch stud.
then 3488804 is the same without cornering lamp harness.
But if E bodies doesn't have cornering lamps should use 3488804... right ?
then we have 2947905... right piece to 70 E body, maybe also first 71 half
then I have in B bodies the same than 2947905 but with PUSH IN to knob ON... maybe 2947503 ?
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338550
06/08/09 03:43 PM
06/08/09 03:43 PM
Snoopy Offline
Snoopy  Offline
If you have a key light like the one below, you need a 2947905 turn signal switch. If you don't, you need the 3488477 or 3488804-5 switch.
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338551
06/08/09 03:46 PM
06/08/09 03:46 PM
Snoopy Offline
Snoopy  Offline
2947905 & 2947503 Flasher Knob
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338552
06/08/09 03:53 PM
06/08/09 03:53 PM
Snoopy Offline
Snoopy  Offline
The key light fits into the area marked with the red arrow.
Re: Part # for '71 e-body turn sig. switch? [Re: Snoopy] #338553
06/09/09 02:04 AM
06/09/09 02:04 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
GREAT INFO!!! thanks.
My car does have whoever the key courtesy light, diff than that one, but steering collar have a cutout for that. I mounted recently. It had before a plastic plug to fill the cutout bolted at same point. Removed the plug and fit the light.
of course we are talking about diff years and bodies, but trying to make a further info research, about what and where was used that or this setup
Page 1 of 3 1 2 3
