called ARP about the SB main stud / oil pump clearance #33813
01/05/07 08:15 AM
01/05/07 08:15 AM
Anonymous OP
Anonymous OP
I have the usual main stud clearance problem on the main stud by the oil pump. The first person I talked to at ARP said to use bolts in those holes then I was put on hold and another guy told me I could not use bolts since it was align bored. He said to cut down the stud, remove the washer and trim the pump as needed but to be careful not to take too much off the pump. I wish there was a better cure for this but this looks like the only solution. ARP should warn buyers about this problem.
Hey guy's, I just wanted to add a little more info. Last night I trimmed the stud and clearenced the pump about .020 and that was still not enough so I had to trim about two threads off the 12 point stud nut to finally get enough clearence. Also if you use an oil pump gasket it will give a little more clearence as well. Just for the heck of it I cut my old oil pump down to see how much room there was to grind and there really is not that much so I would not take off more than .020".
Re: called ARP about the SB main stud / oil pump clearance #33814
01/05/07 09:09 AM
01/05/07 09:09 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Used a bolt in the kids.No problems.You would think for the price they could make it right.Rocky
Chrysler Firepower
Re: called ARP about the SB main stud / oil pump clearance [Re: therocks] #33815
01/05/07 09:44 AM
01/05/07 09:44 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
ARP Bolts w/no washer doesnt fit on my 360.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: called ARP about the SB main stud / oil pump clearance [Re: GoodysGotaCuda] #33816
01/05/07 09:51 AM
01/05/07 09:51 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
he said STUD w/out a washer....
Re: called ARP about the SB main stud / oil pump clearance [Re: DJVCuda] #33817
01/05/07 09:54 AM
01/05/07 09:54 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yes i know. I can read too.
The first person I talked to at ARP said to use bolts in those holes...
Doesnt say if the ARP guy said stock or their bolts...
2020 RAM 1500
Re: called ARP about the SB main stud / oil pump clearance [Re: GoodysGotaCuda] #33818
01/05/07 09:56 AM
01/05/07 09:56 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Re: called ARP about the SB main stud / oil pump clearance [Re: DJVCuda] #33819
01/05/07 09:56 AM
01/05/07 09:56 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Re: called ARP about the SB main stud / oil pump clearance [Re: GoodysGotaCuda] #33820
01/05/07 10:01 AM
01/05/07 10:01 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used a stock bolt.Its been together for 7 years and no problems.Rocky
Chrysler Firepower
Re: called ARP about the SB main stud / oil pump cleara [Re: therocks] #33821
01/05/07 10:14 AM
01/05/07 10:14 AM
Berlin, Germany
Flo Offline
Flo  Offline
Berlin, Germany
when I ran into the metioned issue, I sat down for a beer and thought about it throughoutly and decided to go the stud without washer way... maybe my engineering degree was eventually worth something
1967 Fury III 4door HT tiny 318, late model roller block, bored and stroked to 344
Re: called ARP about the SB main stud / oil pump cleara [Re: Flo] #33822
01/05/07 10:34 AM
01/05/07 10:34 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
12pt nut kit and I trim the stud. no sweat..
Re: called ARP about the SB main stud / oil pump cleara [Re: moper] #33823
01/05/07 11:49 AM
01/05/07 11:49 AM
USA
74DS Offline
74DS  Offline
USA
I had same problem .. called ARP and was told to use a bolt in place of stud .. had to pay for the bolts .. I insisted several times that they take another look at there kit so others will not have same problem ... I think it fell on deaf ears !
Re: called ARP about the SB main stud / oil pump cleara [Re: moper] #33824
01/05/07 11:54 AM
01/05/07 11:54 AM
North Austin
KnuckleDuster Offline
North Austin
Trimming the stud didn't give enough clearance in my case and Tim (70Dart360) and I were worried about how much he could safely grind the pump,so after much debate and advice,I went with the advice I got from Ryan J (of Shady Dell Speed Shop)and Steve Bagwell's old crewchief at the shop where I had the machine work done(Dixie Performance Machine-formerly Barnett's engine shop) and used an ARP bolt in that one hole with no washer.Dixie actually did the align hone with all the studs in,I would think if it was a problem they would have told me to bring it back in for another hone,or at least advised me not to run it that way,considering thier shop's good reputation.
Moper,you even said to run a bolt in my case.
The guy I talked to at ARP had not a clue about the oil pump issue with Chrysler smallblocks.
Tim still had to grind the pump a little
Re: called ARP about the SB main stud / oil pump cleara [Re: KnuckleDuster] #33825
01/05/07 12:07 PM
01/05/07 12:07 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
this should be TECH ARCHIVE MATERIAL!!!!!
Re: called ARP about the SB main stud / oil pump cleara [Re: KnuckleDuster] #33826
01/05/07 01:16 PM
01/05/07 01:16 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I remember that post
I said above is what I do...lol. Not everyone does what I do. Nor should everyone...
