spindle removal....argh! #338123
06/04/09 04:38 PM
06/04/09 04:38 PM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
Doing a disc brake conversion and some front suspension stuff since Im in there.
I am having a real hard time getting the backing plate and ball joint nuts cracked loose.
I have had them doused with PB Blaster, put heat to them, and hit them with the impact. Nothing.
Any other suggestions?
Should I just leave the heat on them for like 10 minutes. They are close to the BJ boot though, so Im a little squeemish about using too much heat.
BTW, before you ask, the cotter pins are pulled.
Re: spindle removal....argh! [Re: newbee69] #338124
06/04/09 06:13 PM
06/04/09 06:13 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
have you tried really long breaker bar with a cheater pipe on the end? either the bolts will come loose, or you'll torque the heads off them!
Impacts are a joke, even the good ones can only make around 90-100 ft lbs of torque from what I've seen. I've seen a high dollar snap on, 3/4" drive impact gun just bounce and bounce on a stuck pinion nut, but when we put a 4" long pipe wrench on the yoke and a breaker bar/cheater bar combo on the nut, it came off with ease.
**Photobucket sucks**
Re: spindle removal....argh! [Re: 70Cuda383] #338125
06/04/09 06:30 PM
06/04/09 06:30 PM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
Okay, Ill try the breaker/cheater bar method. I know what you mean about impacts. Even the good ones arent that great and I have a Harbor Freight cheap one, so Im not surprised that its not bustin loose.
Also, I got the drivers side UBJ nut off, when I get the backing plate bolts off, will the spindle come right out or do I need to take off the UBJ?
Re: spindle removal....argh! [Re: newbee69] #338126
06/04/09 06:35 PM
06/04/09 06:35 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
You should remove the UBJ taper stud BEFORE removing the knuckle - easier that way if you don't wanna destroy anything. The factory tool is like a bolt / long nut "spreader" that presses on the upper stud (nut off) and the lower stud (nut on), then one tap with a hammer (against the top of the knuckle) and it pops right out, you can rig up something with a Home Depot bolt and long hex "threaded rod connector".
Pickle forks are nasty last resort devices.
Rick
Re: spindle removal....argh! [Re: Rick_Ehrenberg] #338127
06/04/09 07:34 PM
06/04/09 07:34 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You must either have a POS gun or its worn out or no air pressure.My 10 year old SnapOn takes off most everything it hits.That and it gets used every day.On ball joint I use it with impact swivel and never had one that wont come off.Thats in rust belt Ohio.Rocky
Chrysler Firepower
Re: spindle removal....argh! [Re: therocks] #338128
06/04/09 09:53 PM
06/04/09 09:53 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
I agree, a good 1/2" drive should be pumping around 500+ ft. lbs. My little IR 3/8 drive has 350 ft. lbs. But as said above a big cheater pipe can get you to over 1000 ft. lbs.
 "GIVE ME A BIG ENOUGH LEVER AND I COULD MOVE THE EARTH"
Re: spindle removal....argh! [Re: momopar] #338129
06/04/09 10:03 PM
06/04/09 10:03 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Suppport the suspension on a jack or jack stand.
When the assembly is dangling or resting on the rubber stopper. All the "HITS" from the impact gun are absorbed instead of shocking the bolt to turn.
Re: spindle removal....argh! [Re: Magnum] #338130
06/04/09 10:23 PM
06/04/09 10:23 PM
North Chicagoland
N
newbee69 Offline OP
newbee69  Offline OP
N
North Chicagoland
Good point, Ill do that.
My impact is pretty much a POS. its a 3/8 rated at 350 ft/lbs. Ive always thought that breaker bars work better, but in this case, there is not much room for a 4' cheater pipe.
Ill get it eventually, just thought I would vent a little.
Re: spindle removal....argh! [Re: newbee69] #338131
06/08/09 05:42 PM
06/08/09 05:42 PM
SCVpolara Offline
SCVpolara  Offline
well If cant get the nuts off you will have to replace them. Here what I use http://www.sears.com/shc/s/p_10153_12605_00904772000P?keyword=NUT+SPLITTER
Works every time. A net castle nut is only a couple bucks.
