Need Help With 1995 Chrysler Concorde #338091
06/04/09 03:22 PM
06/04/09 03:22 PM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
OK... I FINALLY got the valve body out and TRS(neutral safety switch) installed and valve body back in trans in my daughter's '95 Chrysler Concorde. NOW... the gear shift seems "locked" in low. It will not budge. It feels like when its locked with car in park with key off.
Without valve body in the shifter moves easily. The shifter on valve body moves freely when out of trans.
Anyone know what is going on? Why won't the shifter move from gear to gear?
I've already posted on DodgeIntrepid.net but no one seems to know what would cause this problem. Hoping someone here would know.
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Need Help With 1995 Chrysler Concorde [Re: Texas383] #338092
06/04/09 03:49 PM
06/04/09 03:49 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Sounds dumb, try stepping on the brake...
Re: Need Help With 1995 Chrysler Concorde [Re: Nukechargerboy] #338093
06/04/09 08:03 PM
06/04/09 08:03 PM
Ohio
LABBINSKI Offline
LABBINSKI  Offline
Ohio
When you istalled the valve body was the shift linkage in the same position in the valve body as was the shifter if the valve moved forward it is possible the valve body did not engage in the same gear or misaligned perhaps just a sugestion I have had it happen Brian
Re: Need Help With 1995 Chrysler Concorde [Re: Texas383] #338094
06/05/09 08:55 AM
06/05/09 08:55 AM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
Nothing moved... all rods, linkage etc is just like it was. I tried stepping on brake... stepped hard even. I can't figure out why it's doing that. On the valve body there is an electic soloenoid... what does it do?
1969 Y2 Super Bee
Re: Need Help With 1995 Chrysler Concorde [Re: Texas383] #338095
06/05/09 12:53 PM
06/05/09 12:53 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Most likely the park pawl did not go back in correctly (it is easy to do)..Pull the VB back out and make sure you have the pawl locked under the tab on the VB. You will see the tab on the bottom of the pawl that locks under the tab on the VB it HAS to be that way and straight so it lines up correctly.
There is nothing electrical that will block manual lever operation INSIDE the trans.
Rick
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
Re: Need Help With 1995 Chrysler Concorde [Re: Blown71X] #338096
06/05/09 07:03 PM
06/05/09 07:03 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Rick
That is dead on right. I always make sure it will shift the gears before I put the pan back on. Ron
Re: Need Help With 1995 Chrysler Concorde [Re: Texas383] #338097
06/06/09 10:35 AM
06/06/09 10:35 AM
Marshall TX
Texas383 Offline OP
Texas383  Offline OP
Marshall TX
I knew better than to put pan on and oil in trans before trying to see if it shifted. I will make double sure everything is aligned properly.
1969 Y2 Super Bee
