OK... I FINALLY got the valve body out and TRS(neutral safety switch) installed and valve body back in trans in my daughter's '95 Chrysler Concorde. NOW... the gear shift seems "locked" in low. It will not budge. It feels like when its locked with car in park with key off.
Without valve body in the shifter moves easily. The shifter on valve body moves freely when out of trans.
Anyone know what is going on? Why won't the shifter move from gear to gear?
I've already posted on DodgeIntrepid.net but no one seems to know what would cause this problem. Hoping someone here would know.
