Exhaust Stud Sealant
#338057
06/04/09 12:38 PM
06/04/09 12:38 PM
Posts: 366 San Gabriel, CA 91775
rexus31
What is the preferred sealant to use on the exhuast stud threads to prevent leakage?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Exhaust Stud Sealant
[Re: DJVCuda]
#338062
06/04/09 02:52 PM
06/04/09 02:52 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
I agree on the teflon tape, but make sure not to get too crazy with it. You do not want pieces of it floating around in the coolant passages.
Use a high temp anti seize on the nut end of the studs, especially if stainless, to prevent any galling.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
[Re: MoparJ]
#338063
06/04/09 10:14 PM
06/04/09 10:14 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The studs have a shoulder to do the sealing but I'd smear a bit of silicone on there.
I agree that the pipe thread stuff MAY work but that's not it's intended purpose. Tape and paste are for tapered threads.
Sealing a straight thread was never meant to be done.
[Re: Magnum]
#338064
06/04/09 11:29 PM
06/04/09 11:29 PM
RapidRobert
permatex #2 in the toothpaste like tube & has about the same consistency of toothpaste
[Re: RapidRobert]
#338065
06/05/09 12:14 AM
06/05/09 12:14 AM
Posts: 1,647 IL
71383beep
IL
I use "right Stuff"... or is it Great Stuff?
Either way it comes in a caulk tube from the local auto store. It's a bit pricey, but works great for any type of gasket surface. I use it on everything.
But a dolup on the bolt smear it around, torque to spec and don't touch it for 24 hrs. after that retorque and its good to go.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: Posest]
#338067
06/07/09 11:06 AM
06/07/09 11:06 AM
rexus31
I went ahead and used the Permatex #2. Thanks for your input guys.
