Exhaust Stud Sealant #338057
06/04/09 12:38 PM
06/04/09 12:38 PM
San Gabriel, CA 91775
rexus31 Offline OP
rexus31  Offline OP
What is the preferred sealant to use on the exhuast stud threads to prevent leakage?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Exhaust Stud Sealant [Re: rexus31] #338058
06/04/09 01:21 PM
06/04/09 01:21 PM
New Mexico
alraton Offline
alraton  Offline
New Mexico
I coat the stud threads with orange silicon.
Re: Exhaust Stud Sealant [Re: alraton] #338059
06/04/09 02:14 PM
06/04/09 02:14 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
any rtv or sealant, just let it setup overnight before adding coolant to the mix... IMO
Re: Exhaust Stud Sealant [Re: DJVCuda] #338060
06/04/09 02:17 PM
06/04/09 02:17 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I've used teflon TAPE not teflon in a tube
Re: Exhaust Stud Sealant [Re: GTXKen] #338061
06/04/09 02:33 PM
06/04/09 02:33 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
teflon is a thread lubricant, to help pipe threads achieve proper torque. It may seal , it may not, its not designed to seal threads.
Re: Exhaust Stud Sealant [Re: DJVCuda] #338062
06/04/09 02:52 PM
06/04/09 02:52 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
I agree on the teflon tape, but make sure not to get too crazy with it. You do not want pieces of it floating around in the coolant passages.
Use a high temp anti seize on the nut end of the studs, especially if stainless, to prevent any galling.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Exhaust Stud Sealant [Re: MoparJ] #338063
06/04/09 10:14 PM
06/04/09 10:14 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The studs have a shoulder to do the sealing but I'd smear a bit of silicone on there.
I agree that the pipe thread stuff MAY work but that's not it's intended purpose. Tape and paste are for tapered threads.
Sealing a straight thread was never meant to be done.
Re: Exhaust Stud Sealant [Re: Magnum] #338064
06/04/09 11:29 PM
06/04/09 11:29 PM
permatex #2 in the toothpaste like tube & has about the same consistency of toothpaste
Re: Exhaust Stud Sealant [Re: RapidRobert] #338065
06/05/09 12:14 AM
06/05/09 12:14 AM
IL
71383beep Offline
71383beep  Offline
IL
I use "right Stuff"... or is it Great Stuff?
Either way it comes in a caulk tube from the local auto store. It's a bit pricey, but works great for any type of gasket surface. I use it on everything.
But a dolup on the bolt smear it around, torque to spec and don't touch it for 24 hrs. after that retorque and its good to go.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Exhaust Stud Sealant [Re: 71383beep] #338066
06/05/09 10:11 PM
06/05/09 10:11 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Right Stuff is what I have used in the past also.
Re: Exhaust Stud Sealant [Re: Posest] #338067
06/07/09 11:06 AM
06/07/09 11:06 AM
rexus31 Offline OP
rexus31  Offline OP
I went ahead and used the Permatex #2. Thanks for your input guys.
