Mustang T5 in a small block A-Body... clues #336569
06/02/09 07:24 PM
06/02/09 07:24 PM
dead center
CHRONiklyDEMONic Offline OP
Demonized
Demonized
dead center
I'm sure it's been done but I'm having no luck finding anything using the search function.
I'd like to use my old lakewood bellhousing, I don't mind drilling/hacking it up. I haven't researched this much.
Issues I can think of, bearing retainer diameter/length, t/o bearing, input shaft length or lack of, input shaft diameter/pilot bushing?
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: Mustang T5 in a small block A-Body... clues [Re: CHRONiklyDEMONic] #336570
06/02/09 08:18 PM
06/02/09 08:18 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Oe other factor you should consider is strength. Any stock T5, even a WC T5 is weak at best. You dont list the rest of your drivetrain combo, but unless the car is just a driver I wouldnt waste my time. That trans is a bomb waiting to go off when you start gas shifting or running it hard.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Mustang T5 in a small block A-Body... clues [Re: 69L78Nova] #336571
06/02/09 08:37 PM
06/02/09 08:37 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would be looking at something else I have had the WC T5's in the shop destroyed behind so pretty lame Rustanges
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Mustang T5 in a small block A-Body... clues [Re: dusturbd340W5] #336572
06/02/09 08:46 PM
06/02/09 08:46 PM
dead center
Demonized
Demonized
dead center
This is for just a mild budget friendly daily driver.
Re: Mustang T5 in a small block A-Body... clues [Re: CHRONiklyDEMONic] #336573
06/02/09 09:13 PM
06/02/09 09:13 PM
Kissimmee Fl.
Kissimmee Fl.
if your not beating on it hard it will be Okay
Re: Mustang T5 in a small block A-Body... clues [Re: dusturbd340W5] #336574
06/02/09 10:30 PM
06/02/09 10:30 PM
dead center
Demonized
Demonized
dead center
I have a car that gets beat on regularly. This application is less powerful than a stock 5.0, and not only that I won't be powershifting it or doing any sticky tire 6000rpm clutch dumps on my way to work... maybe on my way home after work.
No not really, but anyways, POS transmission or not, can it be done within reason?
Re: Mustang T5 in a small block A-Body... clues [Re: CHRONiklyDEMONic] #336575
06/03/09 12:14 AM
06/03/09 12:14 AM
Renton, WA
GreenBlurr Offline
super gas
GreenBlurr  Offline
super gas
Renton, WA
Yes it can be done, but it costs a good chunk of money (and then some) for the required parts. And then youre still left in the end with a T-5 thats filled with glass parts and shifts like dog poo.
What do you need a 5th gear for anyways? your tires too short?
Re: Mustang T5 in a small block A-Body... clues [Re: CHRONiklyDEMONic] #336576
06/03/09 08:22 AM
06/03/09 08:22 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
OzHemi has one in his OzCharger and it fit pretty well. Still reqired some trimming to the trans x-member, but it looks like it turned out well. I wouldn't hesitate to use one in my Valiant - 300 real HP (260 at the rear wheels), and 3600#. For swapping, I'd look at the 1999+ units, as they have the longest input shafts, and most are rated at ~300 lb-ft. IMHO, they're a great transmission, and there are only a lot of failure stories because there are SOOOO MANY of them out there. How many Mustangs lead an easy life?
Clair
Re: Mustang T5 in a small block A-Body... clues [Re: Clair_Davis] #336577
06/03/09 12:02 PM
06/03/09 12:02 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Actually, after the run of the Fox body (1993), the T-45 was used in the SN-95 body style starting in 1994. It is a little better than the basic T5
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Mustang T5 in a small block A-Body... clues [Re: GreenBlurr] #336578
06/03/09 04:02 PM
06/03/09 04:02 PM
dead center
Demonized
Demonized
dead center
Thanks Clair, but don't the newer transmissions have an integral bell?
Elaborate on the cost please. Remember I have a bellhousing already, and can score a good trans for a dirt cheap trade. The rest of the hardware should be cake, just making it work is what I'm trying to get info on.
Commuting. And I like them.
Re: Mustang T5 in a small block A-Body... clues [Re: CHRONiklyDEMONic] #336579
06/03/09 08:57 PM
06/03/09 08:57 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
This thread should answer most of your questions, the ford spec tko and t-5 installation would be very similar.
http://www.moparts.org/Tech/Archive/clutch/25.html
Re: Mustang T5 in a small block A-Body... clues [Re: CHRONiklyDEMONic] #336580
06/13/09 08:25 PM
06/13/09 08:25 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
CHRONik,
The GT's an mod-motor cars DO use integral bell T-45's, as has been mentioned. The V-6 Mustangs from 1999 up to some point continued to use the T-5, at least according to some info that I got from Tremec. These are the 3.8L cars One of the nice things about these boxes is that they have a longer input, so they tend to work better in a Mopar swap. They're rated at 300 lb-ft continuous, so I think they'd last just fine in a driver situation. There are also HD gear sets out there if you NEED to upgrade, and plenty of aftermarket support for rebuild and other upgrade goodies.
Keep us posted if you go down that road. If I didn't already have a Toyota trans to work with, I'd be working on a T-5, too.
Clair
Re: Mustang T5 in a small block A-Body... clues [Re: Clair_Davis] #336581
06/15/09 05:42 AM
06/15/09 05:42 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Get yourself a T45 instead. They come in 96 and up GT's and Cobras, not hard to find. Those 4.6DOHC's ('specially the 99's) make more power than most Mopar small blocks and do NOT live easy lives, and most hold up pretty well.
Keisler supposedly make s a kit for the T45 in a Mopar now, its cheaper than the TKO kit, but still a bit o money. Maybe you can buy everything but the tranny? I've been thinking about this swap for my Challenger, and i asked them about it but they said they make the kit to mate the engine, but not the kit to install it in the car. Shifter location is off or something like that.
