Re: Line Locks locking out rear wheels
[Re: B1MAXX]
#336360
08/05/09 06:27 PM
08/05/09 06:27 PM
Posts: 876 Arizona
PolyDart
Arizona
they are plummbed the "normal" way. Both outlets of the master go in one side of the metering block. both lines go out from the metering block into the inlet of the line loc, and from the out to the front/rear brakes.
Thanks for checking ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: fasteddie]
#336361
08/06/09 12:13 AM
08/06/09 12:13 AM
Posts: 4,255 State of Fascism
52savoy
State of Fascism
Some tracks prohibit line locks on the rear wheels.
Personally, I would not put a line lock on backwards to lock out the rear wheels. It is not designed for that and may cause unknown problems.
Mine is installed as per the instructions on the fronts after the proportioning valve.
Momentary button is on the shifter. I push the button, pump the brakes hard, and do my burnout. Been on the car for about 17 years and still working perfect.
This is all new to me and it sounds too confusing to mess with at the track..and what is the benefit? I've always installed mine per instructions and getting ready to put the line lock on my Savoy. It will go on the old fashion way unless someone can explain how it's better. Help me understand. Explain to me from start to finish a burnout with it plumbed that way and how it's safe?
not being sarcastic. just want to know.
[Re: 52savoy]
#336363
08/07/09 05:22 PM
08/07/09 05:22 PM
Posts: 1,756 London, England
Gavin
London, England
This is all new to me and it sounds too confusing to mess with at the track..and what is the benefit? I've always installed mine per instructions and getting ready to put the line lock my Savoy. It will go on the old fashion way unless someone can explain how it's better. Help me understand. Explain to me from start to finish a burnout with it plumbed that way and how it's safe?
As simple to install as the regular way, just reversed and in the rear line. Roll up to water box and switch the linelock on, now you have no rear brakes. Roll into water, apply brakes (only front operate), mash the loud pedal (rears will spin up, no brakes applied) do your stuff and when you want to roll out just modulate the pressure on the brake pedal for a very controllable exit. This is the main advantage. Disengage line lock. Done
Some people claim it makes it easier to leave the line lock switched on and only have front brakes when you get to the top end. Not if you fit a momentary switch like you would for a regular fitting. And even if that did happen (can't see how) you would have plenty of brakes at top end with no risk of swapping ends etc.
When it's prevented by rules then end of argument, but if not I like it and it makes sense to me.
[Re: Gavin]
#336364
08/07/09 06:27 PM
08/07/09 06:27 PM
Posts: 876 Arizona
PolyDart
Arizona
I called Hurst and they said there is no reason to reverse anything for use on the rear brakes. They had no problem with using it on the rear either.
Seems like it should work very well this way. Looking forward to trying it out.
[Re: Ron Silva]
#336366
08/07/09 10:05 PM
08/07/09 10:05 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
We are using the line lock solenoid to block pressure to the rear wheels on my brothers car. Alot of Stock and Super Stock Racers prefer this method also, which is where I first heard about it. I feel like there is more control in the burnout. I actually have the solenoid mounted at the rear of the car so that its not visible under the hood.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: B1MAXX]
#336369
08/09/09 11:26 AM
08/09/09 11:26 AM
Posts: 2,934 A shed in England
Tig
A shed in England
The reason I did it was to be able to leave off a 2-step on the floor without a transbrake. Use only one line loc for burn out flip a switch and use two for the launch.
Sorry to hijack here, I have my line locks wired like you. I've never used it, just launched of the footbrake which will hold up to 3k rpm. Was there a noticable difference in 60ft times?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
