ebody 'Cuda 'vert rear quarter change...skin? full Qs?
#336144
06/02/09 12:12 PM
06/02/09 12:12 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Obviously no one repops 'vert rear quarters. So...
should one just get the skins that are out there?
Or cut down some AMD rear quarters and if so, do you cut them right below the top body line?
Or do you actually use the top portion of the quarter and cut around the 'vert well/moulding area?
I'm concerned the skins are such thin POSs and fit like garbage, but full quarters would be overkill???
I definitely do not want to cut right in the middle of the middle body line, even though the tops of the rear quarters are good. It's not like Challengers where using the top part makes sense with such a hard body line down the middle.
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs?
[Re: MLR426]
#336149
06/03/09 05:12 PM
06/03/09 05:12 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
If the top part of your quarters are good, cut and flange them below the middle body line.
logan426
ON a 'Cuda, the middle body line is right there at the top of the wheel well opening. NO way you can cut the quarter there; won't be any metal left to flange. It's not a Challenger, which is what I did for that; only used the bottom half of the repop skin.
[Re: 340SIX]
#336153
06/03/09 10:36 PM
06/03/09 10:36 PM
Posts: 298 ohio
jaycuda
ohio
I do metal and full restorations on mopar cars only at my shop in Ohio and here is how I would do it and yes AMD is the Metal I use. The top of the 1/4 is going to be cut then crimped like factory, very easy as long as you locate what I call targets point's of measuring reference on 1st the oem panel then 2nd the same on the new one and cut and crimp. Then undrill the panel at the factory spot welds along the crip area and I spot weld them back on at factory weld locations but key to a good job is always make it how it was. Anyone needing metal work done wanting spot welds feel free to call I have been putting in new metal with all spot welds now that AMD has it in stock and there is no comparison looking at all that black primer with the car spot welded like a new shell. Fast turn around time complete rotisory to parcial resto work welcome need frame rails? bring it . pick up availible Horaks Restorations a division of Frakie@dylan's 10360 st. rte 43 Streetsboro Ohio 44241 330-562-2169 ask for Jay
[Re: 340SIX]
#336154
06/03/09 11:09 PM
06/03/09 11:09 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
So on the Challenger vert you cut and flanged the old quater and did not butt weld? At what point on the orginal quater did you do it? You have a Cuda Vert as well?
Yes, on the Chally, butt-welded:
As far as 'Cuda 'vert, yeah, picked up a 383-auto, B5/white int/top, PW/AC car:
Needs trunk pan, bit of rocker work, and MAYBE (haven't taken the paint/bondo off yet) rear quarters.
[Re: 2fast4yourBrain]
#336156
06/04/09 08:19 AM
06/04/09 08:19 AM
Posts: 4,799 ILL
MLR426
ILL
logan426
Sorry I flanged above the body line,it worked fine.
logan426
[Re: koak]
#336157
06/04/09 05:52 PM
06/04/09 05:52 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Been here myself...The shape of the hardtop quarters at the base of the "c" pillar is the same as 'verts. You can verify with some carefull checking. Here is how I altered a nos hardtop quarter to fit my vert.
This pic would not fully load, can you post again?
[Re: 340SIX]
#336158
06/04/09 10:33 PM
06/04/09 10:33 PM
Posts: 591 Pa
koak
Pa
Sorry, I can't post the pics because they are too big. If you send me note, I can e-mail them to you. What I did, after allot of carefull measuring and test fitting a hardtop 1/4 to my 'vert, was, remove the existing quarters at the spot welds. I then cut the flanged section that mates to the top well, just beyond the zee bend and around the entire top of the 1/4 to the door opening off the 'vert 1/4. I then transfered the measurements to the new 1/4, in my case an nos hardtop piece, and cut the new 1/4 to match the old. I then but welded the top well flange to the new 1/4. There is also some re-forming and trimming of the area the mates to the "dutchman" panel (between the top and trunk) required. It fits perfectly. I believe that when these 1/4 were formed originally, they probably used multiple dies, and the hardtop and 'vert panels shared at lease a couple of die hits before becoming hardtop or 'vert specific. I could be wrong, but can tell you that from the top well down, except for the "dtuchman' joint, they are the same.
#336159
06/04/09 11:19 PM
06/04/09 11:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Rob,......not that big of a "project",.........while I was involved in my last project with Gary and Pam Benkie, the 71 convertible GTX,....a friend "loaned" us his convertible cuda and challenger for study,.....amongs the interest in how a vert is built,....was how to convert hardtop qtrs to verts, which we had to do to the 71 B body,....also a few friends had E body verts needing qtrs,...seeing that NOS cost $7500- $10K for a pair that's a lot of cabbage!,..........making the cut, and where to measure are your first concerns,....your doing the Cuda, use the AMD hardtop skins only, no Goodmarks!.......I assume your exsisting qtrs are on the car, if not find a "donor" for this procedure,......at your local hardware store, buy the HEAVIEST grade of adhesive shelf paper,....what the wifey uses to line the kitchen shelves,......now lay this from the top fender line contouring it up the the verts well edge, trim it off so that it fully contours all the angles and curves,....if you bought the heavy gauge shelf paper, it will not distort when you remove it, plus the adhesive is very mild,...now transfer the vinyl "template" to the hardtop qtr, these are your exact cut lines,....no guessing, no FUBAR!.....to form the stepped trim area at the top of the well, a airpowered flanging tool will do the job, if you can purchase/borrow one with a 1" flange offset,....or if your extremely good with hammer and dolly, you could "bump" the offset well flange into the cut qrts top edge.....goodluck on your project
Mike
[Re: MLR426]
#336161
06/05/09 07:52 PM
06/05/09 07:52 PM
Posts: 1,179 Canada
demon
Canada
logan426
logan426
Flanging is an amatuer method that was acceptable in 1989,but in 2009 nobody would want that on anything but a 20 footer
[Re: demon]
#336162
06/06/09 01:27 PM
06/06/09 01:27 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
logan426
logan426
True. Don't do flanging w/overlaps and only do butt-welds
[Re: DAYCLONA]
#336163
02/14/10 05:19 PM
02/14/10 05:19 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Mike
No need for the full quarters then? Just cut and butt-weld at the top just below the edge of the quarters?
#336165
02/14/10 09:38 PM
02/14/10 09:38 PM
Posts: 8,495 Candler,NC / Myrtle Beach, SC
JDMopar
Mike
No...I think he meant full quarters instead of skins, even though he said skins Use the heavy contact paper to make a pattern of the shape of the opening around the conv top.
[Re: 68SportSatvert]
#336177
02/15/10 02:59 AM
02/15/10 02:59 AM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Musclecar Restoratins did a Cuda' convertible restoration and has a ton of good reference pics for doing what you're talking about.
Looks like they used skins, although could have been done before full quarters were out:
Hmmm...seems if I use the original tops of the quarters, and keep the flange for the well chrome, I still have some butt-welding to do w/full quarters.
Just seems like for 'verts, full quarters may not totally neccessary as I'm sure AMD skins can't be all that bad. Same gauge of metal and crisp body line down the middle as the full quarters???
[Re: JDMopar]
#336179
02/15/10 08:57 AM
02/15/10 08:57 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike
...Sorry Rob, I meant full AMD qtrs, not skins, skins are for patch panels, which IMHO are obsolete; seeing full qtrs are avaliable,...when I mentioned earlier to use contact paper, that was to template from the exsisting convertibles upper sheetmetal from the cuda's hipline, basicaly the top "deck" section that defines the vert qtr from the hardtop, the contact paper template allows you to transfer the exact cut/shape required from the verts qtrs to the AMD hardtop qtrs without a lot of cut and error,....I'd leave a little extra where the belt trim goes, as you'll need to form that area, and it will "shrink" the deminson somewht because of the step required on the verts belt edge,....use a air powered flanging tool to create the step, there's many profiles avaliable for flanging panels, even if you need to modify/machine the dies, or you could really "backyard" it by making your own manual dies using a pair of HD vise grips and homemade offset dies from steelstock,....flanging hardtop qtrs is pretty much what I did on the 71 GTX vert project to accept custom made moulding/albeit it was fashioned after E bodie profile but altered for the 71 B Bodie
IMHO using the full qtr, and moding it, you'll have a factory fit/finish rather than a cut/splice mess of additional welding,....and the AMD skins are thicker .045 vs .030 (factory)...and the AMD body lines are very nice
Mike
[Re: DAYCLONA]
#336181
02/15/10 09:07 AM
02/15/10 09:07 AM
Posts: 18,157 Mass
DAYCLONA
Mass
