Obviously no one repops 'vert rear quarters. So...
should one just get the skins that are out there?
Or cut down some AMD rear quarters and if so, do you cut them right below the top body line?
Or do you actually use the top portion of the quarter and cut around the 'vert well/moulding area?
I'm concerned the skins are such thin POSs and fit like garbage, but full quarters would be overkill???
I definitely do not want to cut right in the middle of the middle body line, even though the tops of the rear quarters are good. It's not like Challengers where using the top part makes sense with such a hard body line down the middle.
