ebody 'Cuda 'vert rear quarter change...skin? full Qs? #336144
06/02/09 12:12 PM
06/02/09 12:12 PM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
Obviously no one repops 'vert rear quarters. So...
should one just get the skins that are out there?
Or cut down some AMD rear quarters and if so, do you cut them right below the top body line?
Or do you actually use the top portion of the quarter and cut around the 'vert well/moulding area?
I'm concerned the skins are such thin POSs and fit like garbage, but full quarters would be overkill???
I definitely do not want to cut right in the middle of the middle body line, even though the tops of the rear quarters are good. It's not like Challengers where using the top part makes sense with such a hard body line down the middle.
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 2fast4yourBrain] #336145
06/02/09 04:01 PM
06/02/09 04:01 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Not sure what to do, but save the part that is left - someone on here is always saying they should repop the rear window gutter
I would go with the fulls, I think they are thicker, and better more crisp lines...
LOT MORE MONEY THOUGH....
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 2fast4yourBrain] #336146
06/02/09 06:15 PM
06/02/09 06:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Buy the AMD full qtrs, "measure twice, cut once"......do the car right, no skins, fabricate your own convertible qtrs from the AMD's.........or pony up $7-$10K for NOS verts
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 2fast4yourBrain] #336147
06/03/09 10:40 AM
06/03/09 10:40 AM
p.a.
420duster Offline
420duster  Offline
p.a.
I'm in the same boat,can anyone say too what point the AMD full quarters are the same as a vert,what part needs fabbed, anyone got nos quarter photos to share to compare ? Thanks !
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 420duster] #336148
06/03/09 01:10 PM
06/03/09 01:10 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
If the top part of your quarters are good, cut and flange them below the middle body line.
logan426
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: MLR426] #336149
06/03/09 05:12 PM
06/03/09 05:12 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
logan426
ON a 'Cuda, the middle body line is right there at the top of the wheel well opening. NO way you can cut the quarter there; won't be any metal left to flange. It's not a Challenger, which is what I did for that; only used the bottom half of the repop skin.
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 2fast4yourBrain] #336150
06/03/09 08:30 PM
06/03/09 08:30 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
So on the Challenger vert you cut and flanged the old quater and did not butt weld?
At what point on the orginal quater did you do it?
You have a Cuda Vert as well?
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 340SIX] #336151
06/03/09 10:24 PM
06/03/09 10:24 PM
Pa
K
koak Offline
koak  Offline
K
Pa
Been here myself...The shape of the hardtop quarters at the base of the "c" pillar is the same as 'verts. You can verify with some carefull checking. Here is how I altered a nos hardtop quarter to fit my vert.
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: koak] #336152
06/03/09 10:28 PM
06/03/09 10:28 PM
Pa
K
koak Offline
koak  Offline
K
Pa
oops, pics too big. E-mail me if you would like to see the shots....
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 340SIX] #336153
06/03/09 10:36 PM
06/03/09 10:36 PM
ohio
jaycuda Offline
jaycuda  Offline
ohio
I do metal and full restorations on mopar cars only at my shop in Ohio and here is how I would do it and yes AMD is the Metal I use. The top of the 1/4 is going to be cut then crimped like factory, very easy as long as you locate what I call targets point's of measuring reference on 1st the oem panel then 2nd the same on the new one and cut and crimp. Then undrill the panel at the factory spot welds along the crip area and I spot weld them back on at factory weld locations but key to a good job is always make it how it was.
Anyone needing metal work done wanting spot welds feel free to call I have been putting in new metal with all spot welds now that AMD has it in stock and there is no comparison looking at all that black primer with the car spot welded like a new shell. Fast turn around time complete rotisory to parcial resto work welcome need frame rails? bring it . pick up availible
Horaks Restorations
a division of Frakie@dylan's
10360 st. rte 43 Streetsboro Ohio 44241
330-562-2169 ask for Jay
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 340SIX] #336154
06/03/09 11:09 PM
06/03/09 11:09 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Yes, on the Chally, butt-welded:
As far as 'Cuda 'vert, yeah, picked up a 383-auto, B5/white int/top, PW/AC car:
Needs trunk pan, bit of rocker work, and MAYBE (haven't taken the paint/bondo off yet) rear quarters.
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 2fast4yourBrain] #336155
06/03/09 11:53 PM
06/03/09 11:53 PM
Canada
sam c Offline
sam c  Offline
Canada
I would remove only the roof portion off a full amd quarter.This way there's less welding .Cut the quarter where this one was welded and you should be fine
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 2fast4yourBrain] #336156
06/04/09 08:19 AM
06/04/09 08:19 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
logan426
Sorry I flanged above the body line,it worked
fine.
logan426
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: koak] #336157
06/04/09 05:52 PM
06/04/09 05:52 PM
340SIX Offline
340SIX  Offline
This pic would not fully load, can you post again?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 340SIX] #336158
06/04/09 10:33 PM
06/04/09 10:33 PM
Pa
K
koak Offline
koak  Offline
K
Pa
Sorry, I can't post the pics because they are too big. If you send me note, I can e-mail them to you. What I did, after allot of carefull measuring and test fitting a hardtop 1/4 to my 'vert, was, remove the existing quarters at the spot welds. I then cut the flanged section that mates to the top well, just beyond the zee bend and around the entire top of the 1/4 to the door opening off the 'vert 1/4. I then transfered the measurements to the new 1/4, in my case an nos hardtop piece, and cut the new 1/4 to match the old. I then but welded the top well flange to the new 1/4. There is also some re-forming and trimming of the area the mates to the "dutchman" panel (between the top and trunk) required. It fits perfectly. I believe that when these 1/4 were formed originally, they probably used multiple dies, and the hardtop and 'vert panels shared at lease a couple of die hits before becoming hardtop or 'vert specific. I could be wrong, but can tell you that from the top well down, except for the "dtuchman' joint, they are the same.
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: 2fast4yourBrain] #336159
06/04/09 11:19 PM
06/04/09 11:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Rob,......not that big of a "project",.........while I was involved in my last project with Gary and Pam Benkie, the 71 convertible GTX,....a friend "loaned" us his convertible cuda and challenger for study,.....amongs the interest in how a vert is built,....was how to convert hardtop qtrs to verts, which we had to do to the 71 B body,....also a few friends had E body verts needing qtrs,...seeing that NOS cost $7500- $10K for a pair that's a lot of cabbage!,..........making the cut, and where to measure are your first concerns,....your doing the Cuda, use the AMD hardtop skins only, no Goodmarks!.......I assume your exsisting qtrs are on the car, if not find a "donor" for this procedure,......at your local hardware store, buy the HEAVIEST grade of adhesive shelf paper,....what the wifey uses to line the kitchen shelves,......now lay this from the top fender line contouring it up the the verts well edge, trim it off so that it fully contours all the angles and curves,....if you bought the heavy gauge shelf paper, it will not distort when you remove it, plus the adhesive is very mild,...now transfer the vinyl "template" to the hardtop qtr, these are your exact cut lines,....no guessing, no FUBAR!.....to form the stepped trim area at the top of the well, a airpowered flanging tool will do the job, if you can purchase/borrow one with a 1" flange offset,....or if your extremely good with hammer and dolly, you could "bump" the offset well flange into the cut qrts top edge.....goodluck on your project
Mike
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: DAYCLONA] #336160
06/05/09 07:15 PM
06/05/09 07:15 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Thanks for the suggestions everyone!
May have to try that thick contact paper trick.
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: MLR426] #336161
06/05/09 07:52 PM
06/05/09 07:52 PM
Canada
demon Offline
demon  Offline
Canada
logan426
fine.
logan426
Flanging is an amatuer method that was acceptable in 1989,but in 2009 nobody would want that on anything but a 20 footer
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: demon] #336162
06/06/09 01:27 PM
06/06/09 01:27 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
logan426
fine.
logan426
True. Don't do flanging w/overlaps and only do butt-welds
Re: ebody 'Cuda 'vert rear quarter change...skin? full Qs? [Re: DAYCLONA] #336163
02/14/10 05:19 PM
02/14/10 05:19 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Mike
No need for the full quarters then? Just cut and butt-weld at the top just below the edge of the quarters?
