Final decision on aftermarket front suspension #336064
06/02/09 08:09 AM
06/02/09 08:09 AM
detroit mich
stevehiss Offline OP
detroit mich
hi guys i finally got it narrowed down to two choices
LRT and ALTERKATION
any helpful advice to help me make my decision.i have basic tools so i don't want to have to do any fab work.
on a side note any experience with MENDEZ MOTORSPORTS (his motor won pinks all out) and RADS RACING HEADS (heads on winning motor) would be appreciated
I DARE TO BE DIFFERENT
Re: Final decision on aftermarket front suspension [Re: stevehiss] #336065
06/02/09 08:26 AM
06/02/09 08:26 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I was pleased with the alterktion front end from Riley Motor sports, the only fab I had to do since the steering coming through the fire was was not stock was to build a support for the steering shaft to the rack and get a longer steering shaft and u-joint. This front end bolted on the 63 with no problem what soever.
Alterktion front end images here!
Re: Final decision on aftermarket front suspension [Re: stevehiss] #336066
06/02/09 08:28 AM
06/02/09 08:28 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
my 2
the alter k is square tube
the LRT is round tube
if i was gonna put one on my car i would go for the LRT
a racing buddy i know "LEE on the board"has one on his duster and it runs 130 mph trap speeds with ease
also another board member "cudadon" has one that i have personally seen run and it is also dead stable at 130 mph plus
the guy who makes them has a mid 7 sec car that he built so you can have confidence he knows his stuff
plus the round tube front looks trick as hell
mendez motorsports did my motor too
last year i went to 4 cc events and won money at 3
sat in the rain at us 131
last time out at rte 66 ran a 10.12,10.11,10.11,and a 10.12 back to back
rads racing heads and mendez motorsports are good friends so you can't go wrong with these guys. i'm sure there is some rads racing heads in my motor.
WAXER
Re: Final decision on aftermarket front suspension [Re: QWK_ENUF] #336067
06/02/09 08:52 AM
06/02/09 08:52 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
the best ET with the 63 Dodge after a dozen or so passes on the 1/4 track 9.92 best MPH 135.34
Very stable at these speeds.
Either product will be a vast improvement over the OEM parts and no torsion bars to deal with.
Good luck with your upgrade
Re: Final decision on aftermarket front suspension [Re: stevehiss] #336068
06/02/09 08:58 AM
06/02/09 08:58 AM
New Smyrna Beach FL
scottb Online content
scottb  Online Content
New Smyrna Beach FL
Have you ck out Bondobobs stuff very nice also and right in Ohio
Re: Final decision on aftermarket front suspension [Re: stevehiss] #336069
06/02/09 09:19 AM
06/02/09 09:19 AM
WI.
Scotts71chall Offline
WI.
Why did you rule out magnum force k-frame?
Re: Final decision on aftermarket front suspension [Re: Scotts71chall] #336070
06/02/09 10:25 AM
06/02/09 10:25 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I run an alterkation and really like it because of the weight drop and the elimination of the torsion bars. Frees up all kinds of room under the car. I have been 9.70@137 so far in the heat. With my new radials I should run low 9.60's and the frontend has always been solid.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Final decision on aftermarket front suspension [Re: stevehiss] #336071
06/02/09 10:33 AM
06/02/09 10:33 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
I have had an AlterKtion in my "Street" car for 6 years...
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Final decision on aftermarket front suspension [Re: BBLM23] #336072
06/02/09 10:40 AM
06/02/09 10:40 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I would definitely consider Bob's front end. It uses top notch parts all the way through.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Final decision on aftermarket front suspension [Re: BBLM23] #336073
06/02/09 11:54 AM
06/02/09 11:54 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Alterktion here. 79 road runner small block hope to run 920s.i got the soild rotors instead of the drilled
Re: Final decision on aftermarket front suspension [Re: Otherlane] #336074
06/02/09 07:36 PM
06/02/09 07:36 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
I have an Alterkton for three years. Trap speed 130 mph, I am sure I could leave the wheel go after shifting to 2nd and the Dart would go straight. Also the only fab work is to drill four 3/8 holes through the frame.I also drive on the street , it drives like a new car , not a new Dart but a new car.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
