Re: What trans fluid in 2000 Jeep Cherokee 4.0L?
[Re: Belvedere1]
#335715
06/02/09 06:43 AM
06/02/09 06:43 AM
Posts: 320 Dallas, TX
71_Demon
Dallas, TX
I know for a fact it dexron!!!! Thats what we use on them at the dealer!
'71 Demon 383 auto
'12 Ram 2500 6.7 Diesel
[Re: 70Duster]
#335719
06/02/09 10:56 PM
06/02/09 10:56 PM
Posts: 1,278 Mission BC
10sec440
Mission BC
If its the Aisin AW4, pull out the dipstick and look. It will say to use Dexron right on the dipstick. Use what the manufacturer of the transmission suggests as written on the dipstick, not the parts counter guy or the guy who's friend used to work at a dealership.
CORRECT!!! I thought it was a Grand Cherokee, which takes +3, sorry.
[Re: 10sec440]
#335721
06/03/09 07:03 AM
06/03/09 07:03 AM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Date: April 14, 2006
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-004-04, DATED MARCH 16, 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION.
Models: All 89 - 07 Ram Trucks (AD, BR/BE, DR/DH/D1, DC)
1989 - 1995 (AA) Spirit/Acclaim/Lebaron Sedan 1989 - 2003 (AB) Ram Van/Wagon 1989 - 1993 (AC) Dynasty/New Yorker/New Yorker Salon 1989 - 1993 (AD) Ram Truck 1989 - 1994 (AG) Daytona 1989 (AH) Lancer/Lebaron GTS 1989 - 1995 (AJ) Lebaron Coupe/Lebaron Convertible 1989 - 1990 (AK) Aries/Reliant 1989 - 1990 (AL) Horizon/Omni 1989 (AM) Diplomat/Gran Fury/New Yorker fifth Avenue 1989 - 2004 (AN) Dakota 1989 - 1994 (AP) Shadow/Sundance 1990 - 1991 (AQ) Maserati 1990 - 1993 (AY) Imperial/New Yorker Fifth Avenue 1994 - 2003 (BR/BE) Ram Truck 2004 - 2007 (CS) Pacifica 1998 - 2003 (DN) Durango 2002 - 2007 (DR/DH/D1) Ram Truck 2007 (DC) Ram 3500 Cab Chassis 1995 - 2000 (FJ) Sebring/Avenger/Talon 1996 - 2000 (GS) Chrysler Voyager (International Market) 2004 - 2007 (HB) Durango 1995 - 2000 (JA) Cirrus/Stratus/Breeze 2007 (JK) Wrangler 2001- 2006 (JR) Sebring Sedan & Convertible/Stratus Sedan 2007 (JS) Avenger/Sebring 1996 - 2000 (JX) Sebring Convertible 2002 - 2007 (KJ) Liberty 1993 - 2004 (LH) Concorde/Intrepid/Vision/LHS/New Yorker/300M 2005 - 2007 (LX/LE) 300/Magnum/Charger 1996 - 2000 (NS) Town & Country/Caravan/Voyager 1995 - 2005 (PL) Neon 2002 - 2003 (PG) PT Cruiser (International Markets) 2001 - 2007 (PT) PT Cruiser 1997 - 2002 (PR) Prowler 2001 - 2007 (RG) Chrysler Voyager (International Markets) 2001 - 2007 (RS) Town & Country/Caravan/Voyager 1997 - 2006 (TJ) Wrangler 2001 - 2004 (WG) Grand Cherokee (International Markets) Vehicles equipped with Gas engines 1999 - 2004 (WJ) Grand Cherokee 2005 - 2007 (WK/WH) Grand Cherokee 2006 - 2007 (XK/XH) Commander 1989 - 1995 (YJ) Wrangler 1996 - 1998 (ZG) Grand Cherokee (International Markets) 1994 - 1998 (ZJ) Grand Cherokee/Grand Wagoneer
NOTE: This Service Bulletin DOES NOT apply to AW-4 transmissions, Sprinter transmissions, Crossfire transmissions, MK/PM vehicles equipped with Continuously Variable Transmission (CVT) and WG vehicles equipped with a diesel engine (sales code ENF) and a W5J400 or NAG1 transmission (sales code DGJ).
Discussion: ATF+4® - (Type 9602) is being used as factory fill for Chrysler Group automatic transmissions. ATF+4® is recommended for all vehicles equipped with Chrysler Group automatic transmissions EXCEPT FOR THOSE NOTED ABOVE.
NOTE: ATF+4® must always be used in vehicles that were originally filled with ATF+4®. DO NOT USE ANY OTHER FLUID.
NOTE: ATF+4® is backward compatible with ATF+3 , ATF+2, and ATF+. Additionally, ATF+4 can be used to top off vehicles that used ATF+3, ATF+2, or ATF+.
NOTE: If ATF+4® is used to service models originally filled with ATF+3 , ATF+2, and ATF+ the fluid maintenance schedules listed for that model does not change. The service interval currently in effect for a given model should continue to be followed. Refer to the Service or Owners manual for maintenance schedule directions.
In general terms, If ATF+, ATF+2 or ATF+3 was the recommended fluid, it is now recommended to use ATF+4.
BENEFITS
Better anti-wear properties Improved rust/corrosion prevention Controls oxidation Eliminates deposits Controls friction Retains anti-foaming properties Superior properties for low temperature operation FLUID COLOR
Mopar ATF+4® has exceptional durability. However, the red dye used in ATF+4® is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4® also has a unique odor that may change with age. With ATF+4® fluid, color and odor are no longer indicators of fluid condition and do not necessarily support a fluid change.
Parts Required: Qty. Part No. Description AR 05013457AA Fluid, Transmission, ATF+4® (Type 9602), Quart AR 05013458AA Fluid, Transmission, ATF+4® (Type 9602), Gallon
Policy: Information Only
