Vibration Problem at Higher RPM's. PLEASE HELP #334651
05/31/09 08:32 PM
05/31/09 08:32 PM
Missouri
68KillerBee Offline OP
Missouri
ok, here is what all has been replaced since the vibration started...
new clutch, throw out bearing, resurfaced flywheel, heads reworked, carb rebuilt, new spark plugs, different harmonic balancer, and new motor mounts....
it happens with the clutch in and out but only at higher rpm's. at idle and a little above idle it doesn't vibrate at all.
It's a 440 with a 4 speed behind it. could something be screwed up with the cam, crankshaft, or rods and the motor still run normal (at idle)? it's been over 2 years since we've started messing with this and i just wanna go cruisin around with my dad in our 4 speeds
please ask any and all questions and i'll answer them as soon as i can.
thanks in advance
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334652
05/31/09 08:35 PM
05/31/09 08:35 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
the "different harmonic balancer" is highly suspect. Do you still have the old one to try?
and is this an internal balance motor?
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: Pacnorthcuda] #334653
05/31/09 08:42 PM
05/31/09 08:42 PM
Missouri
Missouri
we actually just switched the harmonic balancers today. it has the exact same vibration at the same rpm, which is why we rule out the harmonic balancer now.
it's a steel crank 1968 440
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: Pacnorthcuda] #334654
05/31/09 08:42 PM
05/31/09 08:42 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Fly wheel balance too. Like said above cast or forged shaft??
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: MoparforLife] #334655
05/31/09 08:43 PM
05/31/09 08:43 PM
Missouri
Missouri
forged.
we are thinking the fly wheel was balanced. may call the place tomorrow to make sure.
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334656
05/31/09 08:45 PM
05/31/09 08:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Have you had the balancer and the flywheel NEUTRAL BALANCE CONFIRMED ? I had a neutral flywheel that was resurfaced wrong , it was .020 thicker on one side vs. the other , no longer NEUTRAL balance ...
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334657
05/31/09 08:45 PM
05/31/09 08:45 PM
Missouri
Missouri
this happening with the clutch pressed in and with it out should eliminate the input shaft on the transmission right? nothing in the transmission is being turned..?
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: JohnRR] #334658
05/31/09 08:49 PM
05/31/09 08:49 PM
Missouri
Missouri
will call around tomorrow and see where I can get this checked. they did the flywheel on my car too and it works fine... but there is always human error...
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334659
05/31/09 09:24 PM
05/31/09 09:24 PM
Missouri
Missouri
also how could the flywheel just become messed up randomly. doesn't make sense how it would just become unbalanced? so far thats the best answer we have though, so the transmission will be coming out again.
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334660
05/31/09 09:27 PM
05/31/09 09:27 PM
calif
cupcake Offline
cupcake  Offline
calif
ballence motor & flywheel together dude
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: cupcake] #334661
05/31/09 09:52 PM
05/31/09 09:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
only if it's external balance , neutral balance should have no issue swapping parts that are also neutral balance .
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334662
05/31/09 09:54 PM
05/31/09 09:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
easy , someone trying to save 25 bucks and trying to do it themself or a shop that's not paying attention? All I know is I had a vibration problem , pulled the clutch and took the flywheel to get resurfaced and the shop found out it was off like that when he went to cut it and it only cut a small sliver off one side on the intial cut ...
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: JohnRR] #334663
05/31/09 09:59 PM
05/31/09 09:59 PM
Missouri
Missouri
ya, i was actually hoping you would reply to this question. i always see you trying to help people out on here . like i said i'll be looking around tomorrow to find someone that can check it.
thanks again to everyone. hopefully we can figure this thing out soon, it's getting old. car cruise coming up on friday that i wanna make with my dad.
edit: was your vibration whenever your car was running or just higher rpms or what? it starts out with nothing but then sounds like a roaring haha. only way i can explain the sound. something just isn't balanced right it seems.
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334664
05/31/09 10:04 PM
05/31/09 10:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
an engine shop can check it on their balancer , bring them the flywheel and your pressure plate , they can spin it , balance the assembly and they will mark it so you know which way to assemble it so that whole assembly is balanced , one less thing to worry about .
what type of balancer do you have ? The $$$ BHJ SFI balancer I boguht was out by a few grams .
My 383 still has a vibration issue but it was run for a number of years by the prior owner with that misbalanced flywheel .
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334665
05/31/09 11:23 PM
05/31/09 11:23 PM
wisconsin
dodger1 Offline
dodger1  Offline
wisconsin
I had a vibration from a bad 4 speeed tranny mount,also my 833 was in need of a rebuild that cuased a vibration Ive also heard the pinion angle on the rear end could be wrong cuasing a vibration . Hope you get it figured out!
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: dodger1] #334666
06/01/09 12:53 AM
06/01/09 12:53 AM
Missouri
Missouri
Thanks johnahah. hopefully we'll get it in and out this week.
while the car was up on a rack last week(getting new exhaust, headers to manifolds) i noticed the tranny mount looked kinda sideways also. while we have the transmission out we'll check out the transmission. last time we had it out, everything seemed to be fine, but we'll open it up again(after it's balanced). also this happens while sitting still so i don't think the pinion angle has anything to do with it.
thanks again
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: 68KillerBee] #334667
08/04/09 08:44 PM
08/04/09 08:44 PM
Missouri
Missouri
Rebuilt transmission, input shaft shaved off a bit, new clutch, pressure plate, flywheel.... and it's still got it. when it was just the old flywheel and bellhousing it started up and there was no vibration at all.
now what?
this transmission has been in and out at least 7 or 8 times this summer.
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: Pacnorthcuda] #334668
08/06/09 04:03 PM
08/06/09 04:03 PM
Missouri
Missouri
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: dodger1] #334669
08/06/09 04:42 PM
08/06/09 04:42 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
pinion angle would be road speed dependent, not RPM dependent.
2017 Grand Cherokee Overland
Re: Vibration Problem at Higher RPM's. PLEASE HELP [Re: patrick] #334670
08/06/09 06:09 PM
08/06/09 06:09 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
hmm hows your fan and water pump? drop the belts and give it shot, I jad a 5.0l mustang that would shake out your fillings...water pump sprung a leak, changed it smooth as a babys bottom...step one drop the accessories and try!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
