727 LEAKING- Thinking of a shift kit. #333622
05/30/09 08:45 PM
05/30/09 08:45 PM
New Jersey
70SAT Offline OP
70SAT  Offline OP
New Jersey
Hi All- My trans is leaking.Not 100% sure, but hoping it is an easy fix. Shifts fine so maybe just one of the common leaks a 727 gets, Any thoughts on putting in a shift kit while I open her up? Is it easy to do for a weekend mechanic with regular tools? Any particular kit recommended over others? I was thinking of a Transgo Performance TF-1. Thanks.
70 SATELLITE CONVERTIBLE-SOLD frown 70 ROADRUNNER 383-4- SOLD frown
70 SATELLITE CONVERTIBLE- AGAIN !!!!! smile
---------COLT 1911A1--------
------USA ALL THE WAY-----
Re: 727 LEAKING- Thinking of a shift kit. [Re: 70SAT] #333623
05/30/09 08:58 PM
05/30/09 08:58 PM
Haslett, MI
7DRRunner Offline
7DRRunner  Offline
Haslett, MI
I had 2 slight leaks on my 70 Runner and wondered why I waited so long to tackle them ...
One was right around the dipstick area - mine was "press fit" in, and it only needed a new "O" ring
and the other spot was the gasket around the servo shaft, in which case - you don't need to pull the whole tranny to fix
Hopefully your will be an easy one
Sometimes you will see a problem around the tail shaft housing bushing seal
just tossing out some ideas
keep us posted
"Good luck on your project." 1970 Road Runner "Accellertii Incredibus"
Re: 727 LEAKING- Thinking of a shift kit. [Re: 70SAT] #333624
06/01/09 05:41 PM
06/01/09 05:41 PM
New Jersey
70SAT Offline OP
70SAT  Offline OP
New Jersey
Anyone? Ideas? Comments?
Re: 727 LEAKING- Thinking of a shift kit. [Re: 70SAT] #333625
06/01/09 06:06 PM
06/01/09 06:06 PM
scratchnfotraction Offline
trans go TF II shift kit
Re: 727 LEAKING- Thinking of a shift kit. [Re: scratchnfotraction] #333626
06/01/09 08:41 PM
06/01/09 08:41 PM
New Jersey
70SAT Offline OP
70SAT  Offline OP
New Jersey
Hi Scratch- What's the difference between the TF1, street use (which I mostly do) and the TF2, racing use. Also, I've been trying to find a components list for these kits but no luck. What parts in the tranny are actually changed? Thanks.
Re: 727 LEAKING- Thinking of a shift kit. [Re: 70SAT] #333627
06/01/09 09:34 PM
06/01/09 09:34 PM
personal preforance mostly
I like the hard shifts and full manual shift on the street
its just whats recomended most often
along with the billet servos and the eagle red clutches and coleen steels
the billit servos can be had from board member and sponser ROBMC IIRC..look for the add flashing on top of page also
CRT is the place for the kits, they are a sponser here on the board
give john a call he can help you with the ?s
look for the add at the top of the page
the trans go III kit is for full manual shift valve body
you may very well only need the tf-I shift kit
I am no guru but I am saving up for the bullit proof 727 from john at crt
A&A transmission is another here on the board thats top shelf
maybe john kunkle will chime in he is a guru also with good advice
