Re: Duster centerlink question
[Re: JonGottaDemonDad]
#333018
05/30/09 01:42 AM
05/30/09 01:42 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
This may help http://www.bigblockdart.com/techpages/linkage.shtmlThere is a difference between a 71 and 73 centerlink as shown in the link above. However, it has nothing to do with whether it came on a /6 or a V8 car. The only A bodies that had different centerlinks for /6 and V8 cars were 66 and earlier A's.
[Re: MoparJoe]
#333019
05/30/09 01:43 AM
05/30/09 01:43 AM
mopowers
Sac, CA
Yes the centerlink is different on a /6 car, the V8 version has more droop to clear the pan.
Only on an early A (66 and earlier).
[Re: mopowers]
#333020
05/30/09 01:56 AM
05/30/09 01:56 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
67-72 /6 and V8 centerlinks are the same. And 73-76 /6 and V8 centerlinks are the same.
Common mistake and something a lot of Mopar parts guys love to take advantage of.
#333022
05/30/09 02:11 AM
05/30/09 02:11 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Is the centerlink different on a 71 slant 6 and a 73 v8 car?
Yes, they are different, but not because of the engine, but because of the year. You have already figured out the difference. They are interchangeable with the proper matching parts.
[Re: CokeBottleKid]
#333024
05/30/09 06:27 AM
05/30/09 06:27 AM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
You can run either the 68-72 steering or the 73-76 steering, but you have to use all the right generation parts. Either generation will fit the K-frame.
[Re: autoxcuda]
#333026
05/30/09 09:46 AM
05/30/09 09:46 AM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
I used to think the same thing but my /6 '73 Duster had a straight centerlink, it also had 5x4 wheels which were not supposed to be around after '72.
[Re: MoparJoe]
#333027
05/30/09 12:25 PM
05/30/09 12:25 PM
Jim_Lusk
Fresno, CA
The later centerlink is flatter because the idler and pitman enter from above, not below. Late /6 cars with drums still had small bolt pattern.
[Re: RapidRobert]
#333028
05/30/09 12:54 PM
05/30/09 12:54 PM
autoxcuda
So Cal
I've run a 73-76 Centerlink in a 68-72 K-member. I had to because I have a large spline power steering box.
When you did that did you use a 73-76 idler arm along with the large spline 73-76 pitman arm? So is the kframe end of the 2 different idler arms the same?
Yes the K-frame idler bracket location is the same. I used a 73-76: steering box, pitman, centerlink, idler
