Engine Temperature #332929
05/29/09 09:59 PM
05/29/09 09:59 PM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
69 GTX, stock 440, clutch fan, clean coolant, probably 160 stat as it came out of Atlanta.
My GTX runs between 200 and 220 depending on the outside temp and whether city or highway driving. I noticed that the temp rose about 10 degrees after I installed a new clutch fan.
Just wondering if this is considered too hot.
Re: Engine Temperature [Re: moparcanuk] #332930
05/29/09 10:07 PM
05/29/09 10:07 PM
Az
Crizila Offline
Crizila  Offline
Az
200 is my high water mark. I like to run my stuff between 180 and 190. If the fan clutch is a direct replacement, don't know why it would cause the temp to go up 10 degrees. Think I'd be taking it back.
Fastest 300
Re: Engine Temperature [Re: moparcanuk] #332931
05/29/09 10:11 PM
05/29/09 10:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Got a shrowd?
Re: Engine Temperature [Re: buildanother] #332932
05/29/09 10:14 PM
05/29/09 10:14 PM
Orleans, Ontario
Orleans, Ontario
Yep.
Re: Engine Temperature [Re: moparcanuk] #332933
05/29/09 10:21 PM
05/29/09 10:21 PM
probably 160 stat as it came out of Atlanta.My GTX runs between 200 and 220 I noticed that the temp rose about 10 degrees after I installed a new clutch fan.
If it does have a 160 in there I would put in a 180. You R&R'd the old clutch fan for a new one & temp rose? I would want it a bit cooler. More details on what the temp is around town & the highway and what do you have for radiator? What timing idle/curve & plug color.
Re: Engine Temperature [Re: RapidRobert] #332934
05/29/09 10:25 PM
05/29/09 10:25 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Mechanical or electric OEM gauge?
Run with the radiator cap off so as not to build up pressure and test the temp with a candy thermometer. Don't run up the temp and then remove the cap to check or yopu will likely get burnt when you remvoe the cap or at best hjust have a mess.
Re: Engine Temperature [Re: RapidRobert] #332935
05/29/09 10:44 PM
05/29/09 10:44 PM
Orleans, Ontario
Orleans, Ontario
How does timing affect temp?
22" radiator with shroud; changed the stock fixed fan for a clutch fan.
Re: Engine Temperature [Re: moparcanuk] #332936
05/29/09 11:33 PM
05/29/09 11:33 PM
IN
ahy Offline
ahy  Offline
IN
The clutch fan will slip some and give less cooling than a fixed fan. Plus, not all clutch fans are created equal - many believe the "standard duty" aftermarket clutches leave a lot on the table. "Heavy Duty" or MOPAR work best.
With a 22" radiator, you may be cutting it close to start with cooling a 440. A really good 3 or 4 row brass will do it as well as a high capacity aftermarket aluminum but the factory usually put 26" on a 440.
I'd try to return the clutch fan and exchange for a "heavy duty" or just put the fixed fan back on. Making sure you have enough timing helps also because the engine can run more efficiently and produce less waste heat.
I also like to see temps under 200 when rolling. If it creeps up at a long stop light to 205 or 210 then drops right back down when you get moving, that's OK.
My
Re: Engine Temperature [Re: moparcanuk] #332937
05/29/09 11:38 PM
05/29/09 11:38 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
What are using to measure the temp?
Re: Engine Temperature [Re: goldmember] #332938
05/29/09 11:50 PM
05/29/09 11:50 PM
Orleans, Ontario
Orleans, Ontario
The factory gauge registers between about 1 o'clock and 1:30.
My aftermarket gauge varies between approximately 200 and 220. On the open road at 60mph it runs about 200. It can go up to about 220 in stop and go traffic.
Re: Engine Temperature [Re: moparcanuk] #332939
05/30/09 12:14 AM
05/30/09 12:14 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I whole heartly recommend REDLINES WATER WETTER, avaliable at most Autozones,....use it with FRESH antifreeze,......I'd recommend you flush out the green stuff if your running it,...and use Zerex G-05,....it's not that crappy Dexcool crap that will clog your engine,......Zerex is formulated for engines that use "green" anti freeze,.....you could use the water wetter (8-10 OZ.) with traditional Green antifreeze, ...but you really see a drastic change with a 50/50 water/Zerex G-05 mix with Redlines water wetter added,............my wingcars run HOT, obviously from the reduced grille area in traffic,.....I've played with everything,......the only thing I've seen offering an imediate change, altering nothing else, but a complete fluid change, is what I discribed above,.....I been running Zerex G-05 for over 5 yrs with no issuses of overheating, corrosion, etc,.....I would only recommend something I have performed or practiced on my own vehicles
Re: Engine Temperature [Re: moparcanuk] #332940
05/30/09 12:18 AM
05/30/09 12:18 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
If your gauge is electric,I would compare it to a thermometer. Many aftermarket electrics are not close.
Re: Engine Temperature [Re: goldmember] #332941
05/30/09 01:06 AM
05/30/09 01:06 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
As said earlier, Timing and A/F will also effect temp. more enitial timing will make you run hotter at idle. Leaner will run a little hotter. Does it cool down while on the freeway? If it does, then you have a fan issue. If it stays hot (or gets hot) on the freeway, then you have a coolant flow, or radiator problem.
With all that said, it does not suprise me at all that a 440 running a 22" radiator is having issues.
Re: Engine Temperature [Re: DAYCLONA] #332942
05/30/09 01:09 AM
05/30/09 01:09 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I've never heardof the Water Wetter. What is it supposed to do?
1981 Dodge D150 360 auto
Re: Engine Temperature [Re: basketcase] #332943
05/30/09 01:18 AM
05/30/09 01:18 AM
Orleans, Ontario
Orleans, Ontario
The Build Sheet has 53 under RAD. That code is for a 22" radiator.
Re: Engine Temperature [Re: basketcase] #332944
05/30/09 01:43 AM
05/30/09 01:43 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dave,
Water Wetter is an additive that basicaly helps eliminate "steam pockets" that develope in a running engine that cause water flow restrictions, or even blockage, esp. in the heads, where cooling is crucial,....the additives coat the internal passages, almost like an "armor all" for the cooling jackets, keeping them "wet/slick", so that when steam pockets are produced, and superheated, or heatsoaked in an area, they don't create a heated air pocket, restricting water flow, and creating high operating temps,....
There's a few brands of Water Wetters out there, some are just junk Snake oils,....but the Redline truly does work,.......when I first tried just the Zerex G-05 antifreeze I had an instant 20 degree drop in running temp, constistantly,....adding the Redline water wetter (8-10 OZ) was good for an addition 10-15 degrees,....so without any other cooling mods, just a fluid change, and additive, my running temps went fron the usual 220 degrees in traffic to 180-190 tops in traffic, even on the hottest days
Re: Engine Temperature [Re: DAYCLONA] #332945
05/30/09 02:48 AM
05/30/09 02:48 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The temps the OP listed are too hot in my book.
Like the one guy said, you can narrow it down to fan or radiator, make a note of what you are seeing.
I would add an aftermarket gauge for now just to see exactly what is going on.
Are you sure the radiator is clean inside and out? Mopars had tons of sand in them from the factory and that can build up after a long time or especially after a long high speed blast...don't ask me how I know
I want my fair share
Re: Engine Temperature [Re: basketcase] #332946
05/30/09 11:29 AM
05/30/09 11:29 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Some 440's do have heating issues others don't.
I was 2nd owner of a 69 Chrysler 300 four door with a factory 440 HP engine, it had a 22 inch, 2 row radiator with a shroud, no air cond., it would go all day long in any kind of driving and never run hot.
The original owner ordered the car with the HP 440 engine so he could tow a good sized camp type trailer, which he did every summer.
Re: Engine Temperature [Re: DAYCLONA] #332947
05/30/09 11:58 AM
05/30/09 11:58 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Dave,
Thanks Mike, off to the Zone. I'll let you know how it works.
Re: Engine Temperature [Re: basketcase] #332948
05/31/09 09:25 PM
05/31/09 09:25 PM
Orleans, Ontario
Orleans, Ontario
I removed the clutch fan and reinstalled the fixed blade fan. I then drove to a local car show about 30 miles away. The temp needle didn't move off of 190.
I checked the clutch fan and found that it appears to be functioning properly. It is very stiff and not easy to turn by hand.
Just wonder if anyone else has had a 10 or more degree increase in engine temp after going to a clutch fan.
