Doug's headers for 62-65 Plymouth #332755
05/29/09 08:09 PM
05/29/09 08:09 PM
Rittman Ohio
fourgearsavoy Online tonguue OP
fourgearsavoy  Online Tonguue OP
Rittman Ohio
I want to get a new set of headers for my Savoy and I really like the fit and look of the Hedman Elite series headers.I also have seen some nice fitting headers from Doug's I like TTI but they have issues with an 11" flywheel starter position.
Any opinions
Gus
64 Plymouth Savoy
Dana 60
Re: Doug's headers for 62-65 Plymouth [Re: fourgearsavoy] #332756
05/29/09 08:44 PM
05/29/09 08:44 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
I can't vouch for Doug's headers now but way back when they were Doug Thorley's I had a set. I couldn't find a set that fit in a '63 Plymouth without hitting somewhere. Ordered a set of DT from The Rod Shop and they fit like a glove.. oh yeah..John Holt was the saleman there!
Fred
Re: Doug's headers for 62-65 Plymouth [Re: 52savoy] #332757
05/29/09 08:55 PM
05/29/09 08:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are Hedman Elite that I run but they are only a 1-3/4 tube. They fit great and I believe they make them in larger tubes also. Ron
Re: Doug's headers for 62-65 Plymouth [Re: 383man] #332758
05/29/09 10:28 PM
05/29/09 10:28 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I run the Husslers by Hedman, guess I'm not sure what the Ekites are? Have to take a look at that, but the Husslers are good headers IMHO
Re: Doug's headers for 62-65 Plymouth [Re: fourgearsavoy] #332759
05/29/09 10:57 PM
05/29/09 10:57 PM
Utah
O
orangemonster Offline
super gas
super gas
O
Utah
I am running a set of davis stepped headers,the #7 and #8 tubes exit the engine comp. and run around the frame and back under.It's like putting together a puzzle.Look cool though.
Re: Doug's headers for 62-65 Plymouth [Re: fourgearsavoy] #332760
05/29/09 11:28 PM
05/29/09 11:28 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Dougs
Re: Doug's headers for 62-65 Plymouth [Re: 52savoy] #332761
05/29/09 11:48 PM
05/29/09 11:48 PM
Fred
Headers by Dougs and Doug Thorley headers where not and are not the same company now or ever where, if my memory serves me correctly
Re: Doug's headers for 62-65 Plymouth [Re: fourgearsavoy] #332762
05/29/09 11:56 PM
05/29/09 11:56 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Gus, check with DoubleD as he has a set of the Doug's on his 65 Dodge and he is running a 4 speed too along with the EZ heads. I'm pretty sure they fit really nice.
Russ
Re: Doug's headers for 62-65 Plymouth [Re: Cab_Burge] #332763
05/30/09 12:05 AM
05/30/09 12:05 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
you may be correct. I was looking for header flanges a couple weeks ago and I did see something about 2 different Doug's but..being an ol' fart too I forget what it was about.
Re: Doug's headers for 62-65 Plymouth [Re: Cab_Burge] #332764
05/30/09 12:10 AM
05/30/09 12:10 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Fred
Doug Thorley...BECAME two companies AFTER the divorce YEARS AGO(local CO. out here).. SHE became Thorley... HE became Doug's.(the better of the two) Doug's was bought by PROTONIX(sp) I think the CO. was retained IE same people, but Doug is out now
EDIT for spelling
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Doug's headers for 62-65 Plymouth [Re: R70RUNNER] #332765
05/30/09 06:19 PM
05/30/09 06:19 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
The 2" Dougs I have are nice and fit well on my 65 dodge coronet with the EZ-1 heads with an RB block & 4-speed. I don't have an 11" clutch - just the 10.5. They are almost identical to the tti's only much better quality. I also have my motor in the stock location - if you have a newer k-frame then the Dougs probably will not work.
Re: Doug's headers for 62-65 Plymouth [Re: DoubleD] #332766
05/30/09 07:26 PM
05/30/09 07:26 PM
Rittman Ohio
Rittman Ohio
Dave alot of Doug's headers I have seen are fender well design and thats how they list them on the website.You don't happen to remember where you got them or what the part number is do you? I really would like to see them if thats possible. I still have the factory K-member but I am using one of AndyF's motor plates.
Gus
64 Plymouth Savoy
Dana 60
Re: Doug's headers for 62-65 Plymouth [Re: fourgearsavoy] #332767
05/30/09 11:04 PM
05/30/09 11:04 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
They are #D452 I got them at summit - I should have them back in the car tomorrow - I had the motor out to fix an annoying oil leak
Re: Doug's headers for 62-65 Plymouth [Re: DoubleD] #332768
05/31/09 09:17 AM
05/31/09 09:17 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Stay away from the 2 1/8" Hookers if you have heads with raised exhaust ports. I made mine fit but had to modify 2 tubes on the left side. My mottor is on a plate so I could put it where ever I wanted. They still wouldn't make it. I had to twist the #1 tube to miss the steering shaft.
Doug
Re: Doug's headers for 62-65 Plymouth [Re: dvw] #332769
05/31/09 09:21 AM
05/31/09 09:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I had to dimple the #3 tube for torsion bar clearance. I may cut and twist it as well. I'm undecided. The right side fit perfect.
Doug
Re: Doug's headers for 62-65 Plymouth [Re: DoubleD] #332770
05/31/09 08:29 PM
05/31/09 08:29 PM
I wish I had this header info. a few weeks ago. I am not very happy with SUMMIT right now as they did not show ANY headers for a 65' Coronet with a RB in their on-line look up, nor did calling them turn up any headers. After firefighter3931 linked this thread to me this morning, I checked with the posted numbers and sure enough, Summit has them. After calling them and raising hell about it they offered to ship out the new Doug's set without S&H fees. The story goes much deeper, but I will tell you I am DONE with SUMMIT.
If anyone here knows someone at Summit that gives a damn enough to try to change my mind about this you can give them my email address. cor.500@verizon.net
Sorry for the rant guys and gals. I don't post much here, but I do read allot and have been a member for many moons.
Steve P.
Re: Doug's headers for 62-65 Plymouth #332771
05/31/09 09:18 PM
05/31/09 09:18 PM
Rittman Ohio
Rittman Ohio
Yes sometimes everyone gets the "Summit experience"
I have been escorted out of the store before when had a "spirited" conversation with the counter idiot.
Glad you were able to get the number you needed though
There is a member here that works at a Summit
Gus
64 Plymouth Savoy
Dana 60
Re: Doug's headers for 62-65 Plymouth #332772
05/31/09 09:19 PM
05/31/09 09:19 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
To make life easy when installing the D452's remove your drag link and raise the engine up on the passenger side about two inches - then slide the header up from underneath. The drivers side you can slip right in from underneath without the starter inplace - then you have to fiddle getting the starter in not impossible but two people make it go easy. You have to use the mini-starter by the way. Other than that they are an easy header to put in! Thanks to Max-Maniac today for all the help -I should be back up and running in a couple of weeks.
Re: Doug's headers for 62-65 Plymouth [Re: DoubleD] #332773
05/31/09 09:34 PM
05/31/09 09:34 PM
I have fought headers on my 65' with an RB block and 572-13 raised port heads..The 2-1/8 Hookers are on it now but like Dave said fabbing is a must on the left side to make them fit...Dave you will have to drop down the #2 tube 1" to clear starter..
Re: Doug's headers for 62-65 Plymouth [Re: DoubleD] #332774
06/02/09 08:41 PM
06/02/09 08:41 PM
Rittman Ohio
Rittman Ohio
Well I bought the D452's today and all I can say is I love the way they look.Nice packaging and no chance for them to get dinged up or finish rubbed off during shipping if you need that.Now all I have to do is get the heads on the block and engine in the car.
Thanks guys
Gus
64 Plymouth Savoy
Dana 60
