I pulled this from
www.E85forum.comthis is 440Jim's set up
I modified a Holley 950HP carb. So far this is what I am running:
PMJ – .129" (drilled)
SMJ – .129" (drilled)
Power Valve – 3.5
PVCR -- .070"
IFR between 0.032 and 0.040 (not changed from original gas)
IAB -- .063
HSB -- .028
Cross channel to booster -- .157"
anti-siphon -- stock
eholes -- .029", plugged, .029"
Accel pumps are both 30cc
pump cams -- pink
squirters -- .037(front), 0.040(rear) (hollow screws)
0.130" SS needle and seats
7 psi fuel pressure at idle (6 WOT)
