EGR tube #332423
05/29/09 12:27 PM
05/29/09 12:27 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Hi all.. I have another project to start soon and I will need to make/modify the EGR tube.. This is a custom application where a stock tube will not work and I will need an custom tube that will be flexible and still hold up to high temp exhaust gases.
I'm also concerned with how to put the proper fittings on the end of the tubing.. Thanks in advance...
Re: EGR tube [Re: Jeepmon] #332424
05/29/09 05:04 PM
05/29/09 05:04 PM
Land of Lost
flatlinedude Offline
No pulse
No pulse
Land of Lost
Steel braided fuel line is flexible and holds up to some pretty hi temps.
Carol: "Wow! He's really fast, isn't he?!" John: "Yeah... but he's stupid."
Re: EGR tube [Re: flatlinedude] #332425
05/29/09 05:05 PM
05/29/09 05:05 PM
Land of Lost
No pulse
No pulse
Land of Lost
On second thought, just ditch the EGR.
Re: EGR tube [Re: flatlinedude] #332426
05/29/09 05:09 PM
05/29/09 05:09 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
What happens if he does ?
Re: EGR tube [Re: Wedgeman] #332427
05/29/09 06:47 PM
05/29/09 06:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What are we working on?
Re: EGR tube [Re: Wedgeman] #332428
05/29/09 07:27 PM
05/29/09 07:27 PM
dead center
CHRONiklyDEMONic Offline
Demonized
Demonized
dead center
The engine may run a very small amount more lean. It's common practice to remove egr's on many a hopped up vehicles, not so much for a performance gain, but to clean up the engine bay, and have one less problematic device.
"After a Day filled with burning Rubber, you may find it time to re-tire."
Re: EGR tube [Re: flatlinedude] #332429
05/29/09 09:32 PM
05/29/09 09:32 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I know what you're talking about, but have never seen it in any stores.. Any idea where to buy it and then where do you put on the specific fittings on the end?
Re: EGR tube [Re: stumpy] #332430
05/29/09 09:33 PM
05/29/09 09:33 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Its a turbo car.. mums the word
Re: EGR tube [Re: CHRONiklyDEMONic] #332431
05/29/09 09:35 PM
05/29/09 09:35 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I'm not too concerned about the loss or gain in performance, however it does have to be able to pass those every 2 year smog checks..
Re: EGR tube [Re: Jeepmon] #332432
06/02/09 06:56 PM
06/02/09 06:56 PM
dead center
Demonized
Demonized
dead center
www.summitracing.com
Anywhere the fabricator/installer wants to put them I suppose. I doubt you'll find anything like this that is an "out of the box bolt on"... but is anything ever, really?
