Page 3 of 3 1 2 3
Re: 727 kickdown adjustment?? [Re: John_Kunkel] #332062
07/18/14 06:21 PM
07/18/14 06:21 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I find the 727 behaves better with the adjustment being all the way forward at idle. For street driving. The upshift governor can be changed to a different RPM for WOT changes.
I want my fair share
Re: 727 kickdown adjustment?? [Re: stumpy] #332063
07/18/14 07:21 PM
07/18/14 07:21 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
Come on John, The transmissions aren't that weak. I have driven my autos since the 60s like a stick and never had a failure because of it. I probably shift them 50% of the time and I know lots of other Mopar guys thet do the same thing with no trans troubles. We all can't be lucky and getting away with out failures. I think you are a bit to worried about this.
just had to share, when I was a younger man I did rollbacks often (driving in reverse while still rolling back slam into drive and floor it) loved that dodge dart,toughest slant 6 ever,tranny never failed,sold it with 200,000 still running today just a rot box, carry on just a flash back
Re: 727 kickdown adjustment?? [Re: meepmeep70] #332064
07/18/14 08:07 PM
07/18/14 08:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Another example of doing it wrong and getting away with it versus doing it right.
Re: 727 kickdown adjustment?? [Re: John_Kunkel] #332065
07/18/14 08:40 PM
07/18/14 08:40 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
No mater what I do to the rod.....set so at WOT it has about an 1/8" of play left it doesn't move my shift point higher... Goes into 3rd at about 15 to 18 mph, if I floor it she shifts at about 4,800rpm . I always thought that the governor is the final say in shift points.
Re: 727 kickdown adjustment?? [Re: ademon] #332066
07/18/14 10:42 PM
07/18/14 10:42 PM
At WOT I think you are right
Page 3 of 3 1 2 3
