Indy 440-2 and 440-3 ?
#331092
05/27/09 11:13 PM
05/27/09 11:13 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
I have both 440-3 and 440-2 Indy intakes, the -3 has the intake port dividers protruding into the clover leak under the carb., the 440-2 does not. My question is is there a 440-2 late model Indy intake that has the port dividers protruding under the carb like my 440-3? My 440-2 has the round casting for the fuel injection bungs and the 440-3 has the square casting, I think There both at the dyno shop now so I can't look at them. Last question on the 440-2, is there any performance differences between the early and late 440-2 intakes or is there such a thing?
Re: Indy 440-2 and 44-3 ?
[Re: Cab_Burge]
#331095
05/29/09 12:20 AM
05/29/09 12:20 AM
Posts: 2,521 PA
moparacer
PA
I just pulled a 440-2 with an adapter like you have CB and am more then likely wasting my time installing a 440-3 to try this weekend..... Oh well I have it and all I will be out is a set of gaskets and a spacer if it doesn't pick me up.....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Cab_Burge]
#331100
05/31/09 09:21 AM
05/31/09 09:21 AM
Posts: 2,521 PA
moparacer
PA
Mine ran basically the same with the 440-3 and the cloverleaf but picked up some mph.
Was .05 faster yesterday but the air was slightly better then last week.
I think I have fuel supply issues so have to look into that....
