Re: Carter Thermoquad Rebuild Kits?
[Re: 68CoronetRT]
#330692
05/27/09 07:33 PM
05/27/09 07:33 PM
RapidRobert
Demonsizzler here on Moparts
[Re: T2R9]
#330697
05/27/09 08:30 PM
05/27/09 08:30 PM
Posts: 30,489 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
but be very patient.
V E R Y much so ... ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: NachoRT74]
#330698
05/27/09 08:34 PM
05/27/09 08:34 PM
dOc …
Florida STAYcation
In my experience ... no-need to buy a whole kit. Just select parts.
AND a set of brass floats.
![](/ubbthreads/images/graemlins/iagree.gif)
normally just O rings and bottom gasket . Upper gasket could it be too.
Brass floats if you have the phenolic ones ( what by the number mostly sure it is )
IF you just lightly tap the top and base with a small plastic hammer(after pulling all the screws out) .. both the top and bottom gaskets are normally A-OK.
[Re: dOc …]
#330699
05/27/09 09:18 PM
05/27/09 09:18 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
definitelly!!! and then you can sink it on some light oil to get them better and reuse it!!! Some of the oil will be absorved and gasket will fit tight again! Being outside USA I have made it LOT of times ![](/ubbthreads/images/graemlins/thumbs.gif) another part that could need replacement is the acelerator pump stroke
[Re: dOc …]
#330703
05/28/09 12:47 AM
05/28/09 12:47 AM
Posts: 1,047 Arizona
68CoronetRT
Arizona
I'll take it apart and see what kind of shape everything is in. It has been sitting for a couple of years now and had to be primed to get it to start. I always figure buying individual parts usually adds up to the price of a kit.
[Re: NachoRT74]
#330705
05/28/09 10:02 AM
05/28/09 10:02 AM
dOc …
Florida STAYcation
I already found the replacement for O rings, on an HIDRAULIC TOOLS parts store.
How do they fit ? ..... and do they at all restrict flow ?
[Re: dOc …]
#330706
05/28/09 11:44 AM
05/28/09 11:44 AM
NachoRT74
Valencia, España
I found them same size than originals, square profile, not round like any regular O ring. I think I can get you the PN around, and maybe is an Universal PN... is a little bit more "rubber" or spongie feeling, than the hard rubber of original O rings, so they could be more reusable than original ones than once squeezed, they don't seal back anymore like the first time.
[Re: dOc …]
#330708
05/29/09 07:35 PM
05/29/09 07:35 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
The acc pump ? ..... I can not remember the last time I had to replace one. ![](/ubbthreads/images/graemlins/laugh2.gif)
Like you have realized ... it is only a very few select parts that need to be replaced .... those primary O-rings and floats.
And I am working on a BULK purchase of those .
That could be handy! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DynoDave]
#330709
05/29/09 08:07 PM
05/29/09 08:07 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
FWIW - if your carb still has its number-tag, a rebuild kit is easy to source. He might even ship overseas, maybe you need to pay in US$?
Larry Isgro Carburetors Wantagh, New York (516) 783-1041
I've been using him for years, average kit plus shipping is around $35-40 and he's always been right on the money.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#330710
05/29/09 09:21 PM
05/29/09 09:21 PM
NachoRT74
Valencia, España
yes mine on car is a 6322... I have had about 7 used TQ carbs where I have removed usefull parts like links, bowls bodies, metering rods, floats, needles and seats, etc... any part reuseable. At the end I have keeped about 4 ( plus the one on my car ) what 3 are small bore size in primaries and one big bore size as far I remember. I have been able to drive the parts to get a decent working carb. Have repaired 3 of them on leaks. Of course no one of the repairs has been a PRO repair, just an amateur fix and try. I think beside the one on my car what is decent but still I think can get it better, no one is still in PERFECT working conditions, but will keep trying.
I have collected about 4 rebuilt kits from diff setups ( 1 Napa/Echlin, 3 Hygrade ), some of those won't work, some yes, mostly has been uncomplete. Of course On all these years my stock has been reducing, so I keep the parts were mounted just in case.
There is a guy selling the right kit to my 6322 carb right now down here ( higrade 657C ) but he wants an eye for it. Fortunatelly nobody wants those carbs or are able to "fix them" ( thats why I have end "learning" about ) so at the end everything falls in my hands somehow.
Demomsizzler has been helpfull too quite often when I have asked something about.
I forgott to check the invoice I have for the O rings I got, but will make and will try to take a pic.
I have not measured them with a caliper, but they are allmost the same when making a visible comparision...
