Carter Thermoquad Rebuild Kits? #330691
05/27/09 07:29 PM
05/27/09 07:29 PM
Arizona
68CoronetRT Offline OP
Arizona
Anyone have a good source for a 9054S Thermoquad rebuild kit?
Re: Carter Thermoquad Rebuild Kits? [Re: 68CoronetRT] #330692
05/27/09 07:33 PM
05/27/09 07:33 PM
Demonsizzler here on Moparts
Re: Carter Thermoquad Rebuild Kits? [Re: 68CoronetRT] #330693
05/27/09 07:33 PM
05/27/09 07:33 PM
In the mud somewhere
dodgedude4x4 Offline
PM Demonsizzler , he can fix you right up !!
Re: Carter Thermoquad Rebuild Kits? [Re: dodgedude4x4] #330694
05/27/09 07:47 PM
05/27/09 07:47 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
but be very patient.
Re: Carter Thermoquad Rebuild Kits? [Re: 68CoronetRT] #330695
05/27/09 07:53 PM
05/27/09 07:53 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
In my experience ... no-need to buy a whole kit. Just select parts.
AND a set of brass floats.
Re: Carter Thermoquad Rebuild Kits? [Re: dOc …] #330696
05/27/09 08:27 PM
05/27/09 08:27 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
normally just O rings and bottom gasket . Upper gasket could it be too.
Brass floats if you have the phenolic ones ( what by the number mostly sure it is )
Re: Carter Thermoquad Rebuild Kits? [Re: T2R9] #330697
05/27/09 08:30 PM
05/27/09 08:30 PM
Florida STAYcation
Florida STAYcation
V E R Y much so ...
Re: Carter Thermoquad Rebuild Kits? [Re: NachoRT74] #330698
05/27/09 08:34 PM
05/27/09 08:34 PM
Florida STAYcation
Florida STAYcation
IF you just lightly tap the top and base with a small plastic hammer(after pulling all the screws out) .. both the top and bottom gaskets are normally A-OK.
Re: Carter Thermoquad Rebuild Kits? [Re: dOc …] #330699
05/27/09 09:18 PM
05/27/09 09:18 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
definitelly!!!
and then you can sink it on some light oil to get them better and reuse it!!! Some of the oil will be absorved and gasket will fit tight again!
Being outside USA I have made it LOT of times
another part that could need replacement is the acelerator pump stroke
Re: Carter Thermoquad Rebuild Kits? [Re: NachoRT74] #330700
05/27/09 09:27 PM
05/27/09 09:27 PM
Florida STAYcation
Florida STAYcation
The acc pump ? ..... I can not remember the last time I had to replace one.
Like you have realized ... it is only a very few select parts that need to be replaced .... those primary O-rings and floats.
And I am working on a BULK purchase of those .
Re: Carter Thermoquad Rebuild Kits? [Re: dOc …] #330701
05/28/09 12:37 AM
05/28/09 12:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeah, well if they were replaced some day in the past for the leather ones, they could need replacement... or if carb has been dry from looong time.
I recently discovered we would need wider pump stroke seals or diaphragms. Due the friction, cilinders began to be worn and loose pressure when stroking
I already found the replacement for O rings, on an HIDRAULIC TOOLS parts store.
Re: Carter Thermoquad Rebuild Kits? [Re: 68CoronetRT] #330702
05/28/09 12:44 AM
05/28/09 12:44 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
I've gotten all my kits from the local Car Quest folks.
Re: Carter Thermoquad Rebuild Kits? [Re: dOc …] #330703
05/28/09 12:47 AM
05/28/09 12:47 AM
Arizona
Arizona
I'll take it apart and see what kind of shape everything is in. It has been sitting for a couple of years now and had to be primed to get it to start.
I always figure buying individual parts usually adds up to the price of a kit.
Re: Carter Thermoquad Rebuild Kits? [Re: 440trk] #330704
05/28/09 01:06 AM
05/28/09 01:06 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeap, up there, not the same down here
in fact I have been able to get couple of UNCOMPLETE kits I for cheap... but GUESS WHAT PARTS WERE "MISSED" ?
Re: Carter Thermoquad Rebuild Kits? [Re: NachoRT74] #330705
05/28/09 10:02 AM
05/28/09 10:02 AM
Florida STAYcation
Florida STAYcation
How do they fit ? ..... and do they at all restrict flow ?
Re: Carter Thermoquad Rebuild Kits? [Re: dOc …] #330706
05/28/09 11:44 AM
05/28/09 11:44 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I found them same size than originals, square profile, not round like any regular O ring. I think I can get you the PN around, and maybe is an Universal PN... is a little bit more "rubber" or spongie feeling, than the hard rubber of original O rings, so they could be more reusable than original ones than once squeezed, they don't seal back anymore like the first time.
Re: Carter Thermoquad Rebuild Kits? [Re: NachoRT74] #330707
05/28/09 11:53 AM
05/28/09 11:53 AM
Florida STAYcation
Florida STAYcation
Sounds good Nacho .... you would be helping A LOT of guys out. There are some people in the TQ-World that are charging AS MUCH as 5$ for a pair of those !!
Have you put a set of caliphers on each O-ring? .. how do they compare exactly ?
Re: Carter Thermoquad Rebuild Kits? [Re: dOc …] #330708
05/29/09 07:35 PM
05/29/09 07:35 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
That could be handy!
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Carter Thermoquad Rebuild Kits? [Re: DynoDave] #330709
05/29/09 08:07 PM
05/29/09 08:07 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
FWIW - if your carb still has its number-tag, a rebuild kit is easy to source. He might even ship overseas, maybe you need to pay in US$?
Larry Isgro Carburetors
Wantagh, New York
(516) 783-1041
I've been using him for years, average kit plus shipping is around $35-40 and he's always been right on the money.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Carter Thermoquad Rebuild Kits? [Re: 67SATisfaction] #330710
05/29/09 09:21 PM
05/29/09 09:21 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes mine on car is a 6322... I have had about 7 used TQ carbs where I have removed usefull parts like links, bowls bodies, metering rods, floats, needles and seats, etc... any part reuseable. At the end I have keeped about 4 ( plus the one on my car ) what 3 are small bore size in primaries and one big bore size as far I remember. I have been able to drive the parts to get a decent working carb. Have repaired 3 of them on leaks. Of course no one of the repairs has been a PRO repair, just an amateur fix and try. I think beside the one on my car what is decent but still I think can get it better, no one is still in PERFECT working conditions, but will keep trying.
I have collected about 4 rebuilt kits from diff setups ( 1 Napa/Echlin, 3 Hygrade ), some of those won't work, some yes, mostly has been uncomplete. Of course On all these years my stock has been reducing, so I keep the parts were mounted just in case.
There is a guy selling the right kit to my 6322 carb right now down here ( higrade 657C ) but he wants an eye for it. Fortunatelly nobody wants those carbs or are able to "fix them" ( thats why I have end "learning" about ) so at the end everything falls in my hands somehow.
Demomsizzler has been helpfull too quite often when I have asked something about.
I forgott to check the invoice I have for the O rings I got, but will make and will try to take a pic.
I have not measured them with a caliper, but they are allmost the same when making a visible comparision...
